New Reply
Combinatorial chem - Stills binary code tag system
Share Thread Thread Tools
Jul29-12, 01:15 PM   #1
In my med chem book:
http://books.google.ie/books?id=Qe9l...system&f=false
they talk about a method of tagging in which you attach aryl halides to the linker then use gas chromatography to get a "bar code" which tells you what building blocks were used to synthesize each compound. I don't get it at all. Are these aryl halides attached to the link in a sequence or is it just a single aryl halide attached to a linker at a time? How can these aryl halides tell you what building block was used at what stage? For example, in table 5.3 they show you an example of an encoding system and they say T1 for glycine, T2 for alanine and T1 + T2 for serine. How would they attach T1 and T2 to the same resin bead? Does this method only work for tiny libraries? For example how would you apply this method to library of tripeptides made up of 20 different amino acids? You would need loads of different aryl halides.
PhysOrg.com
PhysOrg
chemistry news on PhysOrg.com
>> Explainer: What are chemical weapons?
>> Scientists develop advanced biological computer
>> Biofilms move electrons long distances across two distinct layers, even under starving conditions
New Reply
Thread Tools
Similar Threads for: Combinatorial chem - Stills binary code tag system
Thread Forum Replies
How come we haven't advanced since binary code? Programming & Comp Sci 13
Code : Binary Search Tree C++ Programming & Comp Sci 7
What are all the possible 5-digit binary code combinations? Mechanical Engineering 7
Need help with binary tree code Engineering, Comp Sci, & Technology Homework 2
