| New Reply |
thermo-ish diffusion/wave equation - metal plate and temperature difference |
Share Thread | Thread Tools |
| Jul31-12, 11:33 AM | #1 |
The edges of a thin plate are held at the temperature described below. Determine the steady-state temperature distribution in the plate. Assume the large flat surfaces to be insulated. If the plate is lying along the x-y plane, then one corner would be at the origin. The height of the plate would be 1m along the y-axis and the length would be 2m along the x-axis. The edge along the y-axis is being held at 0 C. The edge along the x-axis is being held at 0 C. The edge parallel to the x-axis is being held at 0 C. The edge parallel to the y-axis is being held at 50sin(pi*y) C. 2. Relevant equations So I'm assuming this question is actually just a diffusion equation or a wave equation, because that's what the rest of our homework was on. Alpha2uxx=ut and u(x,t)=X(x)T(t)=(C1coskx+C2sinkx)e-K2alpha2t+C3+C4x 3. The attempt at a solution So I tried to solve this like the wave equations and it seems to just be blowing out of proportion and not making sense... Also... I think we need to consider a thrid position variable here, we need x,y AND t. I don';t know how to do this at all :( |
| New Reply |
| Thread Tools | |
Similar Threads for: thermo-ish diffusion/wave equation - metal plate and temperature difference
| Large wave number region of difference method of diffusion | Engineering, Comp Sci, & Technology Homework | 0 | ||
| Solving diffusion equation using finite difference method | Nuclear Engineering | 0 | ||
| Solving the diffusion equation finite difference technique | Differential Equations | 0 | ||
| The temperature distribution on metal plate is given by.... | Calculus & Beyond Homework | 2 | ||
| the difference between the Heat and Diffusion equation ?!! | Differential Equations | 2 | ||
