How is the curvature of a curve related to the chain rule?
  • Context: Graduate
  • Thread starter Thread starter Cyrus
    Curvature
The discussion revolves around the relationship between curvature and the chain rule in the context of parametrizing curves. Participants explore how curvature can be expressed in terms of different parameters, specifically arc length and time, and the implications of reparametrization on the application of the chain rule.
  • One participant questions the application of the chain rule in expressing curvature in terms of arc length versus time, suggesting that the definitions of the variables may lead to confusion.
  • Another participant argues that it is acceptable to treat the relationship between arc length and time as interchangeable for well-behaved functions, emphasizing the flexibility of the chain rule.
  • Some participants express disagreement about the correct interpretation of the relationship between the parameters, with one asserting that reparametrization requires treating time as a function of arc length, not the other way around.
  • There is a discussion about the notation used in textbooks, with participants noting that ambiguous notation can lead to misunderstandings regarding functional dependence.
  • One participant attempts to clarify the relationships between the tangent vector expressed in terms of arc length and time, indicating that both representations can be converted into one another through proper application of the chain rule.
Participants express differing views on the correct application of the chain rule and the relationships between the parameters involved. There is no consensus on the interpretation of the curvature expressions or the validity of the chain rule in this context, indicating ongoing debate.
Participants note that the discussion is complicated by the use of notation in textbooks, which may not clearly convey the relationships between the variables involved. There is also mention of the need for careful consideration of functional dependence when reparametrizing.
Cyrus
A quick question. In stewart, the curvature is defined as:
[tex]\kappa = \abs(\frac{dT}{ds})[/tex]
and it says that:
"The curvature is easier to compute if it is expressed in terms of the parameter t instead of s, so we can use the Chain Rule to write:
[tex]\frac{dT}{dt}=\frac{dT}{ds} \frac{ds}{dt}[/tex]
and
[tex]\kappa= \abs(\frac{dT}{ds}) = \abs(\frac{dT/dt}{ds/dt})[/tex].
I don't see how they used the chain rule on that problem, normally, it is T(t).
So T is a function of time, (t) directly. Are they saying that they replaced the variable t, in terms of the varaible s. S, which is arclength, is a function of t. So I suppose the rewrote t, as a function of s instead. The same as saying, [tex]y=x^2[/tex] or you could also say, [tex]x=+/-\sqrt(y)[/tex].
And they pluged this in where (t) used to be in T(t). So now it is written as:
T(s), but s(t), so it is like saying T(s(t)) ?
Also, did they just solve the first fraction dT/dt =dT/ds ds/dt by dividing both sides by ds/dt in order to get, dT/ds= (dT/dt)/(ds/dt). Is it correct to multiple and divide by ds/dt like that?
so when you do the chain rule you get, dT/dt = dT/ds * ds/dt ?
On another note, I am taking dynamics now, and it is quite amazing how I looked at three books, physics 1, dynamics, and calc 3, and found three different ways of finding the acceleration vector, the dynamics and physics book do almost the same approach with diagrams of vectors, and the math book quite nicely does the same thing without every using a picture. Neat, I think.
Yes,that's the advantage of using differentials.U can ALMOST multiply & divide through them at will.There are some "miserable" exceptions,of course,but in this case,no...
Daniel.
Let me ask this again, because I see something I may have done wrong.
Normally the tangent is in terms of t, T(t).
Now, we also know that arc length is a function of time, t as well:
s=s(t).
But if we reparametrize the tangent in terms of s, instead of t, that means we have to rewrite arc length as t in terms of s, and subsitute that in for t. In other words, we have to chagne s=s(t), into t=t(s). And we can plug THIS back in for t in the tangent.
So the tangent should now become T(t(s)). Right?
So now its a function of s. So when we do the chain rule, how come it is not written as:
[tex]\frac{dT}{ds} = \frac{dT}{dt}\frac{dt}{ds}[/tex]
They both give the same anwser if you move around the ds/dt term, but I think the way the book arrived to the anwser is incorrect. s is not a function of t, i.e s != s(t), because it is the other way around, t is a function of s, t=t(s). Which is why i strongly disagree with their use of the chain rule.
dT/dt= dT/ds ds/dt, nonono!? :biggrin: How can you say ds/dt like that, s is no longer a function of t, s is the variable now, and t is the dependent variable on s.
Thanks for your help.
It doesn't really matter for well-behaved functions (diffeomorphisms) if it's s(t) or viceversa.That's another advantage of the chain rule.
Daniel.
Im sorry, I see what your saying, but I don't understand what you mean by that.
How does it make sense to talk of dT/ds ds/dt, when s is not a function of t? I agree that s=s(t) for arc length, but when you reparametirize the tangent vector in terms of s, you have to change from s=s(t) into t=t(s), if you want to replace the t's with s's. So then ds/dt becomes meaningless, no?
Sure.But it's all about reparametrization.For example,if u have the curve s=s(t),then the curvature will be
[tex]K(t)=K(s(t))[/tex]
If u chose another parameter "u",for example
[tex]K(u)=K(s(u))[/tex]
Daniel.
To be pedantic:
Let "s" and "t" be related through:
[tex]s=f(t), t=f^{-1}(s)[/tex]
Expressed in terms of "s", the tangent vector may be called [tex]\vec{T}_{s}(s)[/tex]
wheras expressed in terms of "t", we have [tex]\vec{T}_{t}(t)[/tex]
The two functions [tex]\vec{T}_{s},\vec{T_{t}}[/tex] must satisfy the relations:
[tex]\vec{T}_{s}(f(t))=\vec{T}_{t}(t), \vec{T}_{s}(s)=\vec{T}_{t}(f^{-1}(s))[/tex]¨
Thus, you have:
[tex]\frac{d\vec{T}_{s}}{ds}=\frac{d\vec{T}_{t}}{dt}\frac{dt}{ds}, t=f^{-1}(s)[/tex]
and
[tex]\frac{d\vec{T}_{t}}{dt}=\frac{d\vec{T}_{s}}{ds}\frac{ds}{dt}, s=f(t)[/tex]
Daniel.
But that is incorrect daniel, you can't just put s(t) in place for t like that. s(t) might be something like [tex]s(t)=t^3[/tex], so you can't just put in s(t), everywhere you see at t in T(t), because, in this case, s is related to [tex]t^3[/tex] not t. Thats my dilema.
Perhaps you should take a closer look at my response.
Your dilemma is real, and based on a sloppy and ambiguous notation met in textbooks.
Hopefully, what I've written, clears up a bit.
That's what i call a functional dependence (explicit or/and implicit) and i don't recall claiming that the K function be SURJECTIVE... :wink:
Daniel.
:approve: Thanks, you guys are my heros. I wish I was a math TITAN like you guys,
arildno said:
To be pedantic:
Thus, you have:
and
Ah, I think I see what you mean now. Do you mean that for [tex]t= f^{-1}(s))[/tex], you are calling that t=t(s), which is where the dt/ds comes from?
and the same applies for the s=f(t), you mean s=s(t), which is where the ds/dt comes from.
Does this:
[tex]\vec{T}_{s}(f(t))=\vec{T}_{t}(t) [tex],<br /> correspond to this:<br /> [tex]\frac{d\vec{T}_{t}}{dt}=\frac{d\vec{T}_{s}}{ds}\frac{ds}{dt}, s=f(t)[/tex][/QUOTE]<br /> <br /> and this: <br /> [tex]\vec{T}_{s}(s)=\vec{T}_{t}(f^{-1}(s))[/tex]<br /> correspond to this:<br /> [tex]\frac{d\vec{T}_{s}}{ds}=\frac{d\vec{T}_{t}}{dt}\frac{dt}{ds}, t=f^{-1}(s)[/tex]<br /> <br /> I think you put them in reverse order from the equality you had above it, so I am not sure if that is the correspondance or not.<br /> <br /> In words, does this say that suppose we know the tangent vector in terms of arclength, s, from the getgo, then we can convert it into terms of t. Or vise versa, if we know the tangent in terms of time, t, we can change it to arclength. <br /> <br /> The thing is, thoughout the book, everything is in terms of t, so it did not seem natural to start with s, and work my way to t. Up until then, everything had been done in terms of t, and we worked our way to s. Maybe that's partly been the problem.[/tex][/tex]
You've right, I reversed the order, but you seem to have figured it out.
It was perhaps somewhat unfortunate of me to use the word "tangent vector" here , since the relations I set up, are of course, entirely general, independent of the particular interpretation of it (that is, it holds for any representation of a vector function in either of two variables which can be set in bijective correspondence to each other).
Got it. My math book wanted to show that dT/dt = (dT/ds)/(ds/dt), and I thought that I could prove it as well, by another method. I defined an inverse function of s as, t=t(s), so then it would be clear that dS/dt=(dT/ds)(dt/ds), and I THOUGHT, that if I made it as ds/dt=(dT/ds)/(ds/dt), I would arrive at the same anwser, since I just put the fraction in the denominator but flipped it, they two are equivalent: dS/dt=(dT/ds)(dt/ds)=ds/dt=(dT/ds)/(ds/dt), but on review that seems like a big NO NO, because dt/ds is NOT a fraction, so I cannot divide by the inverse like that. The reason that the other way, dT/dt, works is because I am dividing both sides by the entire fraction. I believe the only way my alternative method would be valid is if I could prove that
[tex]ds/dt=(dt/ds)^{-1}[/tex], but then, why bother when the first way is so much simpler, and does not require a proof. I should just not worry about writting the tangent in terms of t and converting to s, because there may be situations where it is most natural to write the tangent vector in terms of s, and not t, but either way, I should arrive at the same anwser. (provided that the function s=s(t) can be separated to t=t(s) ).
I just bring this back up from the dead, so that perhaps you can respond to it and give me your thoughts arildno,
Thanks, cyrus
All-right:
Let:
f and its inverse necessarily obeys the relations (since they are inverses of each other)
[tex]f(f^{-1}(s))=s, f^{-1}(f(t))=t[/tex]
Differentiate, by using the chain rule:
[tex]\frac{df}{dt}\frac{df^{-1}}{ds}=1,\frac{df^{-1}}{ds}\frac{df}{dt}=1[/tex]
But suppress now the f-notation, and we have the pleasing result:
[tex]\frac{ds}{dt}\frac{dt}{ds}=1[/tex]
which is what you seek.
I don't understand what you mean by supress the f-notation, or how you got the fraction below, could you explain that please. And also, when we do it this way, we are assuming there is an inverse function that relates s and t, but is it always going to be true in general that s is related to t in a way that they can be separated like that?
Let [tex]\vec{r}(t)[/tex] be a parametrization of a curve . Then, the arc-length "s" is given by the integral (when the curves starts at t=0):
[tex]s=\int_{0}^{t}||\frac{d\vec{r}}{d\tau}||d\tau[/tex]
(That is, in our case f(t) is the integral at the right-hand side).
But, note that f'>0, that is f is a strictly increasing function.
This is sufficient to ensure that an inverse exists.
arildno said:
All-right:
Let:
Man, this post goes back. I am re-reading this and its making even more sense than the first time I read it. I seem to follow all your work fine. The only part I got stuck was when you said
"Differentiate, by using the chain rule:
[tex]\frac{df}{dt}\frac{df^{-1}}{ds}=1,\frac{df^{-1}}{ds}\frac{df}{dt}=1[/tex]"
where did the =1 come from. That would imply that you just did:
d/ds *(s)
Does this notation make sense? It just seems weard for some reason. Typicaly, it is chage of y, WRT change in x, or dy/dx. Rate of change of s with respect to s doesn't make much sense. S doesn't make s change.
Actually, I gues it does make sense if you call s f(s)=s then you would have
df(s)/ds, which would be 1.
Okay, I'll try to add a bit of words here to my previous posts:
1. Whenever "t" is regarded as the independent variable, the corresponding s-values is given by s=f(t)
2.Whenever "s" is regarded as the independent variable, the corresponding t-values is given by [tex]t=f^{-1}(s)[/tex]
3. f and f^{-1} are inverses of each other, that is:
[tex]f(f^{-1}(s))=s,f^{-1}(f(t))=t[/tex]
4.Now, take the first identity under 3., and differentiate both sides with respect to "s".
Use the chain rule on the left-hand side, whereas the right-hand side reduces to [tex]\frac{d}{ds}s=1[/tex]
Yeah, I get steps 1-3. It was just the very last part of step 4 that looked odd, [tex]\frac{d}{ds}s=1[/tex]
This is the first time I have seen a derivative written in this way. Its always been a different variable in the numerator and deonominator, or at least a function of the variable in the denominator, df(s)/ds or dy/ds. (Something Along those lines)
It is a quite common notation; you'd better get used to it!
For example, you will often encounter in differentiation tables the following expression:
[tex]\frac{d}{dx}x^{n}=nx^{n-1}[/tex]
Ok, cool. Your right. I always thought the proper way would be to say y=f(x)=x^n. and then you would have d/dx(y=f(x)=x^n) = dy/dx= d/dx(x^n) = nx^(n-1). But now that I look at the table of integrals in the back of the book I see what your saying.
Finally you write.
Let be a parametrization of a curve . Then, the arc-length "s" is given by the integral (when the curves starts at t=0):
Specifically you say,
Why does this insure that an inverse exists, and why do we know that f'>0 ? We have a magnitude, but it might happen to turn into a complex root for some values of t. Or is that not possible?
P.S. where did you get that proof for inverse derivatives, did you just come up with it from the top of your head, if so wow, that's good stuff! :-)
Ah, I looked at my math book where they do the proof you put. No offense, but I think I am right in this case, because they say in the proof, let f(x)=x^n. This allows you do use the differential operator properly, since you would have df(x)/dx = d/dx x^n. So we would have to say f(s)=s. Or more correctly, f(s)=s=f(t). Does that sound agreeable to you arildno?
Saying f(s)= s is agreeable. Saying f(s)= s= f(t) certainly is not[\b] "more correctly"!
If f(s)= s, then f(t)= t (and f(a)= a, f(b)= b, etc.).
Why can't I say that? f(s)=s , and s=f(t), so why can't I say f(s)=s=f(t) by combining them?
If you say f(t)=s then we have f(5) = s and f(6)=s see? But you have already defined the function f so that f(s)=s which would mean f(5)=5 and f(6)=6. So we have s=5 and s=6, which is a contradiction.
