Electromagnetic Cores: Finding the Right Materials for Your Magnet
  • Context: High School
  • Thread starter Thread starter lprekon
    Electromagnetic
This discussion focuses on building an effective electromagnet using a 5V power supply and emphasizes the importance of core material and design. The core should ideally be made of ferromagnetic materials such as iron or nickel, which are strongly attracted to magnets. Key factors influencing electromagnet strength include the current supplied, the number of wire turns around the core, and the size of the core to prevent saturation. Proper construction techniques, such as using magnet wire and minimizing resistance, are critical for optimal performance.
  • Understanding of electromagnetism principles
  • Familiarity with Ohm's Law
  • Knowledge of ferromagnetic materials
  • Experience with basic electrical components and breadboarding
  • Research the properties of ferromagnetic materials for electromagnet cores
  • Learn about current delivery and safety features in power supplies
  • Explore techniques for winding wire efficiently around a core
  • Investigate the effects of core saturation on electromagnet performance
Electronics enthusiasts, hobbyists building electromagnets, and students studying electromagnetism will benefit from this discussion.
lprekon
I'm trying to build a small electromagnet of a 5v breadboard i had set up, but I've run into some troubles. It doesn't work, and I'm trying to figure out if I just need to pump more current through it or if the core I'm using is made of the wrong materials. Does it have to be straight up iron? Or will anything attracted to a magnet work? Is there a way to tell if something would work or not?
Any metal that is strongly attracted to a magnet should work. This indicates that it contains either iron or nickel in significant proportion and is therefore ferromagnetic.
The strength of the electromagnet will depend on:
1 - how much current you can deliver from your 5V source. Be aware that a few turns of copper wire around a core is essentially shorting out your 5V supply. As a safety feature, many power supplies will stop producing current if their output is shorted (current foldback).
2 - The number of turns around your core. Use lots of turns. Use magnet wire and something like an electric screwdriver, or other spinning tool, to minimize the labor. But be aware that too much wire will restrict current due to Ohm's law.
3 - Use a big core. Magnetic cores will saturate at some point and provide no further gain in strength. The larger your core, the more "Ampere-turns" (current times number of turns) you can deliver before saturation.
Good luck
  • · Replies 42 ·
  • · Replies 43 ·
  • · Replies 22 ·
  • · Replies 31 ·
