| New Reply |
CGS and SI Units |
Share Thread | Thread Tools |
| Aug4-12, 04:51 PM | #1 |
CGS and SI Units
So I understand that converting between CGS and SI units is no easy task when you look at the general form of each equation in electromagnetism, as you can't simply relate the two systems given they have different ways of looking at what is a derived unit and what is fundamental. But once you've used either system's set of equations to solve a problem, is there an easy conversion at that point (once all you've got is some number with certain dimensions sitting in front of you)?
Additionally, what are we to make of two systems have completely different sorts of units for quantities like charge or current? It seems very different from the simply types of conversions between mechanical units like length (eg mile to kilometer). The equations surely tell us the same thing, but if each piece has different units in corresponding equations, isn't that a bit odd? |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Aug4-12, 04:57 PM | #2 |
Mentor
I think the answer to your first paragraph is "yes." If you have some physical quantity that is expressed as a number along with associated units in cgs, there should be just a straightforward conversion from that to a number with units in mks.
Your second paragraph puzzles me. Specifically I'm unsure of what you mean when you say "different sorts of units." Different unit systems always have "different" units for the same type of physical quantity. In SI units, force is measured in newtons, and in cgs, it's measured in dynes (I think). So...what exactly is the issue? |
| Aug4-12, 07:07 PM | #3 |
Recognitions:
There isn't a single set of "CGS units" for electromagnetism. There were at least 4 different sets of units used at different times and for different purposes.
The equations all have the same basic forms, except the constants ##4\pi##, ##\epsilon_0##, ##\mu_0## and ##c## occur in different places, and ##\epsilon_0## and/or ##\mu_0## are 1 by definition in the some sets of CGS units. |
| Aug5-12, 10:42 AM | #4 |
CGS and SI Units
Well, perhaps to give a better example, in Gaussian units resistivity is measured in seconds and resistance in sec/cm. This strikes me as odd in the same way-- the SI units do not imply that resistivity has units of time, and resistivity isn't a measure of time, so it's odd (although I get that the unit system is still consistent) to measure the quantity as such.
| Aug5-12, 10:56 AM | #5 |
Well it's true that many familiar quantiies had different dimensions in the CGS and MKS systems and even different within the different CGS systems.
So you will not find easy conversions. For example in the emu system resistance has the dimensions μ0LT-1 but in the esu system it has dimensions ε0-1L-1T As regards Gauss In the MKS system the total electric flux across a closed surface is numerically equal to the charge enclosed. In the esu system the flux is 4π times the charge enclosed. |
| Aug5-12, 11:21 AM | #6 |
Unless I'm mistaken doesn't flux in SI units have units of volt*meters? If so, how can flux equal charge?
| Aug5-12, 11:43 AM | #7 |
Mentor
If you think that's whack, consider the system of "natural units" used by particle physicists. In this unit system, they arrange things so that many of the fundamental physical constants are equal to unity (for convenience). In particular, one system is set up so that c = ##\hbar## = k = 1. Setting c = 1 means that length and time have the same dimensions. But setting c = 1 also means that energy and mass have the same dimensions, and setting ##\hbar## = 1 means that energy has dimensions of time-1. So we have energy = mass = time-1 = length-1. So, in this unit system, everything can be measured in the same physical unit: the electron-volt (eV) which is a unit of energy. |
| Aug5-12, 11:48 AM | #8 |
So Studiot wasn't talking about SI when he mentions MKS, then?
| Aug5-12, 11:51 AM | #9 |
Mentor
| Aug5-12, 12:35 PM | #10 |
I was using the MKS system in its widest sense.
SI is based on the Rationalised MKS system, mainly by some changes to the names of the units. Let us say that a charge of n coulombs is enclosed by a ball of area a sq metres. The electric flux density is n/a coulombs per sq metre. So the total electric flux is n/a *a = n coulombs. I am sorry that my previous post didn't make it clear I meant the total flux (as required by Gauss, to which I did refer). Were you referring to the electric field intensity ? |
| Aug5-12, 01:31 PM | #11 |
Recognitions:
In the SI Maxwell's equations (in the vacuum) read
[tex]\vec{\nabla} \times \vec{E}=-\partial_t \vec{B}, \quad \vec{\nabla} \cdot \vec{B}=0,\\ \vec{\nabla} \times \vec{B} -\frac{1}{\epsilon_0} \partial_t \vec{E}=\mu_0 \vec{j}, \quad \vec{\nabla} \cdot \vec{E}=\frac{1}{\epsilon_0} \rho.[/tex] According to the last equation, by integration over a volume and using Gauß's Theorem, [tex]\int_{V} \mathrm{d}^3 \vec{x} \vec{\nabla} \cdot \vec{E} = \int_{\partial V} \mathrm{d}^2 \vec{A} \cdot \vec{E}=\frac{1}{\epsilon_0} \int_{V} \mathrm{d}^3 \vec{x} \rho=\frac{Q_V}{\epsilon_0}.[/tex] The flux of the electric field through a closed surface equals the charge up to the permeability of the vacuum, [itex]\epsilon_0[/itex] which is an arbitrary conventional factor to match the units of electricity with those of mechanics. This is the very reason, why the SI makes electromagnetics look so difficult ;-)). |
| Aug5-12, 01:42 PM | #12 |
the electric flux density is defined as the vector D = ε E. Thus the total electric flux is given by the surface integral as ψ = ∫∫DndS this may be related by Gauss' theorem to the charge as ψ = Q, the total charge enclosed by the surface. |
| Aug5-12, 02:06 PM | #13 |
Mentor
| Aug5-12, 02:32 PM | #14 |
D and E are the conventional symbols for these vectors. D is a confusing name because there is no flow (flux) of anything, but there it is. However D, unlike E depends only on the free charges. E also depends upon the polarisation charges (in a dielectric of course). |
| Aug5-12, 05:23 PM | #15 |
Fair enough, but my question really concerns units. Let's take the natural units example because it shows my point better.
How can we say, for instance, time and length have the same units? We don't measure these dimensions the same way, with the same instruments, or for the same purpose. How can this represent a useful physical idea without taking away a huge amount of information? |
| Aug5-12, 06:09 PM | #16 |
Mentor
Example: suppose we find a unit system where the unit of distance is judiciously chosen so that it turns out that c = 1 (distance unit)/s. If we're measuring time in seconds, what we're really saying is that when a displacement x = 1 unit, it's actually equal to c*(1 second). It's equal to the distance that light travels in 1 second. So really, we're measuring distance in light-seconds, and the conversion factor is c = 1 light-second/second. But rather than writing 1 light-second/second, it's more convenient to just say that c = 1 second/second = 1 (dimensionless). So we say that we "measure distance in seconds", and it is understood that what this means is that 1 "second of distance" is the distance covered by light in a travel time of one second. So now, anywhere where you see c in an equation, you can just omit it, because it is equal to 1. This is really convenient in relativity, where what you experience entirely as an interval in space (or entirely as an interval in time) could be experienced partially as a space interval and partially as a time interval by another observer who is in motion relative to you. The underlying physical reality is spacetime (both observers agree about the length of the interval in spacetime), so it makes sense to treat distance and time on the same footing and measure them in the same units. So, for the equation E = mc2, we'd just write E = m, since c = 1. When we say that the rest mass of a particle is 1 GeV, it's understood that what we mean is that the mass of the particle is such that its rest energy would be 1 GeV. Even if c weren't equal to 1, you could always express the rest mass as 1 GeV/c2. So, due to mass-energy equivalence, it's pretty handy (and makes sense) to have a unit system where c = 1, and we don't have to worry about the distinction. |
| Aug5-12, 06:21 PM | #17 |
Mentor
Practical example: in this unit system, all velocities are dimensionless, since both distance and time are measured in seconds. So, let's say we have object that is moving with speed v = 0.45. What does this mean? It means that the object covered 0.45 "seconds of distance" in 1 second of time. 0.45 seconds of distance is the distance that light would have travelled in 0.45 seconds. So, this object took a whole second to cover the distance that light would have covered in only 0.45 seconds. Clearly this object is moving at only 45% the speed of light.
| New Reply |
| Thread Tools | |
Similar Threads for: CGS and SI Units
| converting radiometric units (W/m^2) to photometric units (Lux) | Advanced Physics Homework | 0 | ||
| m.k.s. units. | Classical Physics | 1 | ||
| Converting units in scientific notation to other units. | Precalculus Mathematics Homework | 5 | ||
| FAQ:What's the differences between Radiometric Units and Photometric Units? | Introductory Physics Homework | 2 | ||
| Maxwell related equations converted from MKSA units to Gaussian units | Classical Physics | 2 | ||
