| New Reply |
Subtracting LUB and GLB to approach function |
Share Thread | Thread Tools |
| Aug5-12, 11:17 AM | #1 |
I am trying to understand the equation U-L<ε as part of a proof. I have attached the original problem, [102], as well as the hints page. 2. Relevant equations [tex] \sum\limits_{v=1}^n M_v(x_v-x_{v-1})-\sum\limits_{v=1}^n m_v(x_v-x_{v-1})<\epsilon [/tex] 3. The attempt at a solution [tex] \sum\limits_{v=1}^n M_v(x_v-x_{v-1})-\sum\limits_{v=1}^n m_v(x_v-x_{v-1})=\sum\limits_{v=1}^n (M_v-m_v)(x_v-x_{v-1}) [/tex] So we have the length of the interval times the distance between the upper and lower bounds all added together. I'm not really strong on upper and lower bounds. I don't see how exactly we ensure that this will be less than epsilon. I have solved a simpler problem where I let the function we were squeezing be everywhere increasing, and then instead of upper and lower bounds I used right and left end points. Then for a given epsilon I was able to choose k intervals such that [tex] \frac{b-a}{k}(f(b)-f(a))<\epsilon [/tex] |
| Aug6-12, 01:38 PM | #2 |
Recognitions:
Hey Arcana!
![]() It's been a long time that you posted questions. You will need some more information on ##M_v, m_v, x_v## to solve that. Do you have any? |
| Aug6-12, 06:19 PM | #3 |
What kind of information? Is that a "I should think about those things" kind of question, or a "you actually do need more information" kind of question?
| Aug6-12, 06:24 PM | #4 |
Recognitions:
It's: "I actually do need more information".
Although I have to admit that I did not look at your attachments (too much work). With the information you provided in your opening post, the problem cannot be solved. |
| Aug6-12, 06:29 PM | #5 |
[edit]Oh fiddlesticks that isn't right...
| Aug6-12, 06:34 PM | #6 |
Recognitions:
That looks much better (except for the typos).
Can it be that x is greater or equal to m, instead of less or equal? But... what is the question? |
| Aug6-12, 06:37 PM | #7 |
| Aug6-12, 06:39 PM | #8 |
Recognitions:
What... you don't like typing latex?
Edit: Perhaps you can summarize in one sentence? |
| Aug6-12, 06:40 PM | #9 |
Not on my iPad...
It's already a beautiful PDF :) |
| Aug6-12, 06:42 PM | #10 |
Recognitions:
Ah well, that will have to wait.
I'm off to bed.
| Aug6-12, 06:43 PM | #11 |
M is th least upper bound and m is the greatest lower bound f a function f(x). The sum with M is the upper sum and the m sum is the lower sum.
What you got against PDFs anyway? The whole problem and solution are basically given in the PDF, I'm just trying to understand the solution. |
| Aug6-12, 06:44 PM | #12 |
No problem, it's not urgent :)
| Aug6-12, 10:30 PM | #13 |
| Aug7-12, 08:14 AM | #14 |
| Aug7-12, 04:08 PM | #15 |
Recognitions:
Hmm, I took a look... but these problems and their solutions don't look very sharp... at least not to me.
Apparently you're supposed to prove the existence of ##\psi(x), \Psi(x)## given f(x) and any ε>0 with ##\psi(x) \le f(x) \le \Psi(x)##. But... I would just pick ##\psi(x) \overset{def}{=} \Psi(x) \overset{def}{=} f(x)##. Those would do the job. I don't really understand why they have to introduce ##M_v## and ##m_v##. But perhaps that's just because I'm missing some context here. And if you really want to use step functions with some partition... then each of those summations are defined to approach the integral of f(x) due to the definition of the Riemann integral. So you can always find each one with its summation less than say ε/2, which would do the job. As I said, these problems with their solutions are really fuzzy as I see it. I prefer texts that are a bit sharper and more to the point. |
| Aug7-12, 04:41 PM | #16 |
Thanks for taking a look, ILS. What do you mean "find each one with its summation less than ε/2"? For example, the upper sum will be larger than f(x), so how can it be less than ε?
| Aug7-12, 04:45 PM | #17 |
Recognitions:
What you have, is that:
$$\lim_{n \to \infty} \sum^n M_v (x_v - x_{v-1}) = \int f(x) dx$$ This means that for any ##\epsilon > 0## there exist equidistant partitions and N with: $$\forall n > N: |\int f(x) dx - \sum^n M_v (x_v - x_{v-1})| < \epsilon / 2$$ assuming that ##M_v \in f([x_{v-1}, x_v))## for each v. |
| New Reply |
| Thread Tools | |
Similar Threads for: Subtracting LUB and GLB to approach function
| Which approach is nicer? UK MEI approach? American approach? | Academic Guidance | 0 | ||
| Green's function approach using Lebesgue integration | Differential Equations | 59 | ||
| Green Function approach is more physical? | High Energy, Nuclear, Particle Physics | 1 | ||
| Intiutive approach to Green's function for SE | Quantum Physics | 1 | ||
| Distribution function approach to error propagation | Set Theory, Logic, Probability, Statistics | 5 | ||
