| New Reply |
Objective questions regarding "projectile motion - 2 dimension". |
Share Thread | Thread Tools |
| Aug18-12, 01:12 PM | #18 |
Recognitions:
Objective questions regarding "projectile motion - 2 dimension".ehild |
| Aug19-12, 09:46 AM | #19 |
On solving , I get : E = (X2/(cos2θcos2z + sin2θsin2z - 2cosθcoszsinθsinz)) + (X2/(cos2θcos2y + sin2θsin2y - 2cosθcosysinθsiny)) + 2X2sinθ/(cos2θcoszcosy - sinθcosθcoszcosy - sinθsinzcosθcosy + sin2θ sinzsiny) Am I going correct ? |
| Aug19-12, 09:54 AM | #20 |
Recognitions:
I do not know what you are doing. What are y and z??????
ehild |
| Aug19-12, 11:07 PM | #21 |
Other projectile makes angle zo with line AB. So it makes angle (θ + z ) with x axis. Note : Line AB itself makes angle θ (in degrees) with x axis. |
| Aug19-12, 11:14 PM | #22 |
Recognitions:
Do you know y and z?
I do not think expanding the expression of E had any sense. Introducing the angles with respect to AB does not make the solution easier. You know the two angles with respect to the horizontal in terms of (X,Y), coordinates of the point to be hit by the projectile. Y=Xtan(θ). If v is the initial speed, [tex]\tan(\phi_1)=\frac{v^2 +\sqrt{v^4-g^2 X^2-2v^2 gY}}{gX}[/tex][tex]\tan(\phi_2)=\frac{v^2 -\sqrt{v^4-g^2 X^2-2v^2 gY}}{gX}[/tex] The times of flight are [tex]t_1=\frac{X}{v\cos(\phi_1)}[/tex] and [tex]t_2=\frac{X}{v\cos(\phi_2)}[/tex]. Proceed. ehild |
| Aug19-12, 11:37 PM | #23 |
E = (X2)(2g2X2 + 2v4 + 2C)/(v2)(g2X2) + 2sinθ √(((Z+2v2√C)/g2X2))(Z-2v2√C)/(g2X2)) where , Z = g2x2 + v4 + C C = v4−g2X2−2v2gY Don't know how to latex ! :( |
| Aug20-12, 01:02 AM | #24 |
Recognitions:
Check your parentheses.
So you need to expand the terms X2/(v2cos2φ). Using that cos2φ=1/(1+tan2φ, [tex]\frac{x^2}{v^2\cos^2(\phi)}=\frac{x^2}{v^2} \left(1+\tan^2(\phi)\right)[/tex] Substituting the expression [tex]\tan(\phi)=\frac{v^2\pm C}{gX}[/tex] You get [tex]1+\tan^2(\phi)=\frac{v^4\pm 2 v^2C+(v^4-g^2X^2-2v^2gY)+g^2X^2}{g^2X^2}=\frac{2v^4\pm 2 v^2C-2v^2gY}{g^2X^2}[/tex] Now substitute [tex]1+\tan^2(\phi_1)=\frac{2v^2(v^2+ C-gY)}{g^2X^2}[/tex] for t12and [tex]1+\tan^2(\phi_2)=\frac{2v^2(v^2- C-gY)}{g^2X^2}[/tex] for t22 into the expression for E. ehild |
| Aug21-12, 08:30 AM | #25 |
Ah so ,
t12 = 2(v2+C-gY)/g2 t22 = 2(v2-C-gY)/g2 2t1t2sinθ = 4sinθ√(v4 + g2Y2 + 2v2gY - C2)/g2 So Expression E = [2(v2+C-gY) + 2(v2-C-gY) + 4sinθ√(v4 + g2Y2 + 2v2gY - C2)]/g2 Ok , so how to prove this expression really is independent of θ ? |
| Aug21-12, 09:12 AM | #26 |
Recognitions:
You see that +C cancels with -C in the first part. As for the expression under the square root, substitute C2 = v4−g2X2−2v2gY and simplify.
ehild |
| Aug22-12, 12:19 PM | #27 |
![]() So simplifying E = [2(v2+C-gY) + 2(v2-C-gY) + 4sinθ√(v4 + g2Y2 + 2v2gY - C2)]/g2 further , I get , E =[4v2 - 4 gY + 4sinθ√(g2Y2 + g2X2 + 4v2gY)]/g2 tanθ = Y/X So , expression E reduces to , E =[4v2 - 4 gXtanθ + 4sinθ√(g2X2tan2θ + g2X2 + 4v2gXtanθ)]/g2 Which again is simplified to , E =[4v2 - 4 gXtanθ + 4sinθ√(g2X2sec2θ + 4v2gXtanθ)]/g2 Shall I continue ahead ? Please tell if I'm on correct path. Thanks. |
| Aug23-12, 12:58 AM | #28 |
Recognitions:
[tex]2 t_1 t_2 \sin(\theta)=\frac {4 \sin(\theta)}{g^2}\sqrt{(v^2-gY+C)(v^2-gY-C)}=\frac {4 \sin(\theta)}{g^2}\sqrt{(v^4-2gYv^2+g^2Y^2-C^2)}[/tex] |
| Aug23-12, 08:41 AM | #29 |
So , all I've gotta do is to simplify the expression E = [2(v2+C-gY) + 2(v2-C-gY) + 4sinθ√(v4 + g2Y2 - 2v2gY - C2)]/g2 Thus I reduce this expression by putting C2 = v4−g2X2−2v2gY to E =[4v2 - 4 gY + 4sinθ√(g2Y2 + g2X2 )]/g2 Again substituting Y/X for tanθ , expression E reduces to , [4v2 - 4 gXtanθ + 4sinθ√(g2X2tan2θ + g2X2 )]/g2 Which again is reduced to , [4v2 - 4 gXtanθ + 4sinθ. gXsecθ]/g2 Which is simplified again to , [4v2 - 4 gXtanθ + 4gXtanθ]/g2 And lastly we get , 4v2/g2 which is of course independent of θ ! Thanks ehild ! Thanks for efforts !(I'll post some problems of friction soon !) |
| New Reply |
| Thread Tools | |
Similar Threads for: Objective questions regarding "projectile motion - 2 dimension".
| Objective+Scientific Differences Between "Good"Floods and "Bad"Floods? Need Help | General Engineering | 0 | ||
| Projectile Motion "best angles" | Introductory Physics Homework | 1 | ||
| Quick "Equations of Motion" questions (2). Rxn time; deceleration | Introductory Physics Homework | 4 | ||
| A few problems on "MOTION IN ONE DIMENSION" | Introductory Physics Homework | 5 | ||
| [SOLVED] Objective criteria for something being a "force" | General Physics | 0 | ||
