Can saltwater and light bulbs create electricity?
  • Thread starter Thread starter mutzy188
    Light
The discussion revolves around the feasibility of using saltwater to create electricity, specifically in the context of lighting a bulb. Participants explore the underlying chemical and electrical principles, including the concept of galvanic cells and the conditions necessary for generating a current.
  • One participant notes that saltwater conducts electricity but questions whether simply inserting bulb wires into saltwater would light the bulb.
  • Another participant explains that a potential difference is required to light the bulb, which saltwater alone does not provide, as it would keep the leads at nearly the same potential.
  • A participant suggests that connecting one lead of the bulb to a battery while placing the other in saltwater could light the bulb.
  • One participant inquires about the possibility of making saltwater function like a battery to power devices.
  • Another participant introduces the concept of a galvanic cell, explaining that using dissimilar metals as electrodes in saltwater could generate electricity, although the current may be too low to effectively light a bulb.
  • There is a mention of safety concerns regarding electrocution when using batteries in conjunction with saltwater.
Participants express differing views on the effectiveness of saltwater in generating electricity and the conditions necessary for lighting a bulb. There is no consensus on the feasibility of using saltwater alone as a power source.
The discussion includes assumptions about the electrical properties of saltwater and the safety of using batteries in such experiments. The effectiveness of the proposed methods remains uncertain, and the limitations of the current generated by the galvanic cell are acknowledged.
mutzy188
Hi everyone. Today in chemistry we saw this really cool video about different chemical reactions and learned that saltwater conducts electricity :smile: . I have one of those light bulbs that came out of a flashlight and it has 2 wires coming out of it. If I had some saltwater and stuck the wires of the bulb in the water would the bulb light? would I get electrocuted? If so how can I do this so I won't get electrocuted? Also does anyone know how much power saltwater produces?
~Thanks
To light the bulb you need a current, this means there must be a potential difference across the leads of the bulb. Sticking the bulbs in salt water does not imply a potential difference. Quite the opposite since the salt water is a good conductor, the leads will be at very nearly the same potential. Similar to connecting a wire directly from one lead to the other, this is not how you light the bulb.
Now, If you were to place 1 lead in salt water and connect the other to a battery. You could light the bulb by putting the OTHER side of the battery in the water.
Likewise, if you are in salt water holding one side of the battery (or some other power source) and the other side of the source is connected to the salt water you will become part of the circuit, under the right (wrong?) conditions this can be fatal.
Is there a way I can make the saltwater like a battery? Can I make it so the saltwater powers stuff?
Integral, I think what mutzy's seen is a galvanic cell.
Mutzy, you can (theoretically) light your bulb!
Well, almost. If you connect one wire to a copper plate, and the other to a zinc plate, and dip those in the water, you'll have created a galvanic cell. It's not actually the saltwater itself providing the electricity, it's the difference in what's called the "electrode potentials" of the two (dissimilar) metals you use as "electrodes". You'll have made a very simple battery.
You won't get electrocuted, (if I've understood you right and you're not using any other power source) and because such a low current is generated you will probably struggle to even light a bulb. You might have seen "potato clocks" for sale in toy shops; this is how they work except they use potatoes instead of saltwater. I will point out again that the energy is NOT coming from the potato/salt water/copper sulphate solution/electrolyte.
  • · Replies 22 ·
  • · Replies 18 ·
  • · Replies 16 ·
  • · Replies 19 ·
