What is the maximum speed on a dry road curve?
The maximum speed for a standard passenger car (2000 lbs) navigating a banked curve on a dry road with a coefficient of kinetic friction of 0.6 is calculated to be 92.67 mi/hr. The curve has a radius of 0.8 miles and is banked at an angle of 15 degrees. The analysis utilizes Newton's 2nd Law, considering both centripetal force and friction. The derived equation mg*sin(θ) = μN is essential for determining the maximum speed under these conditions.
  • Understanding of Newton's 2nd Law
  • Knowledge of centripetal force concepts
  • Familiarity with friction coefficients
  • Ability to perform unit conversions (e.g., lbs to kg, miles to meters)
  • Study the effects of varying the coefficient of friction on maximum speed calculations
  • Learn about the dynamics of banked curves in physics
  • Explore the implications of different vehicle weights on curve navigation
  • Investigate real-world applications of these calculations in highway safety design
Physics students, civil engineers, traffic safety analysts, and automotive engineers will benefit from this discussion as it provides insights into the dynamics of vehicle motion on curved paths.
shwoll
I have been having trouble with this problem for quite awhile now, and I am wondering if anyone could offer some help...
I figured out part one...that the x direction forces must equal each other (mg sin theta = m*v^2/R) but i am completely lost on the second part. Number 6. Thanks!
5. [1pt]
Because of your physics background, you have been hired as a member of the team the state highway department has assigned to review the safety of freeways. This week you are studying a freeway in New Jersey which has a curve that is essentially 1/8 of a circle with a radius of 0.8 miles. The road has been designed with a banked curve so that the road makes an angle of 15 degrees to the horizontal throughout the curve. To begin the study, the head of your department asks that you calculate the maximum speed for a standard passenger car (2000 lbs) to complete the turn while maintaining a horizontal path along the road. He asks that you first consider the case of an ice-covered road with negligible friction. When you have completed that calculation, he wants you to do the case of a dry, clear road where the coefficient of kinetic friction is 0.6 and the coefficient of static friction is 0.7 between the tires and the road. This will give the team the two extremes of driving conditions on which to base the analysis.
Speed with icy road:
Correct, computer gets: 1.30E+02 mi/hr
6. [1pt]
Speed with dry road:
Newton's 2nd Law
Not so fast. The forces in the x-direction must add up to equal [itex]m a_c = m v^2/r[/itex]. What forces act on the car? In the "no friction" case, there are only two forces. Friction adds a third force. (Which way does the friction act?)
You'll also need to realize that vertical forces are in equilibrium.
To calculate the maximum speed for a dry road, we need to consider both the centripetal force and the force of friction. The centripetal force is provided by the horizontal component of the car's weight, which is equal to mg*sinθ, where m is the mass of the car, g is the acceleration due to gravity, and θ is the angle of the banked curve (in this case, 15 degrees). This force must be equal to the force of friction, which is equal to μN, where μ is the coefficient of kinetic friction and N is the normal force.
Therefore, we can set up the equation: mg*sinθ = μN.
To find the normal force, we can use the fact that the vertical component of the car's weight must be balanced by the normal force: mg*cosθ = N.
Substituting this into our original equation, we get: mg*sinθ = μ(mg*cosθ).
Simplifying, we get: tanθ = μ.
Plugging in the values for μ (0.6) and θ (15 degrees), we get: tan(15) = 0.6.
Solving for θ, we get: θ = 8.53 degrees.
Now, we can use the equation for centripetal force (mv^2/R) to solve for the maximum speed: mg*sinθ = mv^2/R.
Plugging in the values for m (2000 lbs converted to kg), g (9.8 m/s^2), θ (8.53 degrees), and R (0.8 miles converted to meters), we get: 2000*9.8*sin(8.53) = (2000*v^2)/(0.8*1609.34).
Solving for v, we get: v = 92.67 mi/hr.
Therefore, the maximum speed for a dry road with these conditions is 92.67 mi/hr.
  • · Replies 20 ·
  • · Replies 19 ·
