Linear momentum confusion(help required)
The discussion revolves around the conservation of momentum in collisions, particularly focusing on whether momentum can be conserved along the line perpendicular to the line of collision when external forces, such as gravity, are acting on the system. Participants explore the implications of the impulse approximation and the conditions under which momentum conservation applies.
  • One participant questions the statement from a textbook regarding momentum conservation along the perpendicular direction during collisions, citing the presence of gravitational force as a concern.
  • Another participant asserts that momentum is always conserved, noting that unbalanced forces act during collisions but suggesting that the effects of these forces can often be ignored if the collision duration is short enough.
  • It is mentioned that the impulse approximation allows for neglecting external forces during the collision, but the definition of "short enough" is debated, particularly in complex scenarios like car crashes.
  • Some participants clarify that momentum can be conserved in separate components, even when external forces are present, as long as the system is defined correctly.
  • One participant emphasizes that if only the two colliding projectiles are considered, the vertical momentum is not conserved due to the external gravitational force acting on them.
  • A later reply suggests that if the Earth is included in the system, then the momentum of the entire three-body system (two projectiles and the Earth) can be conserved.
  • Participants express uncertainty about how to adjust momentum equations when considering the Earth as part of the system.
Participants do not reach a consensus on the conditions for momentum conservation in the presence of external forces. There are competing views on how to define the system and whether momentum can be conserved in the vertical direction during collisions.
Limitations include the dependence on the definition of the system being analyzed (e.g., whether to include the Earth) and the ambiguity surrounding the duration of collisions in relation to external forces.
rick2395
There is a line written in my physics textbook it says " For any type of collision momentum can be conserved before and after the collision about the line of collision and and about the line perpendicular to the line of collision" . Well i got a question here can we always conserve momentum about the line perpendicular to the line of collision?
Since all this time i knew we could only conserve momentum about the line where no net force is acting.
If two projectiles collide head on in mid air then along the vertical direction i.e along the line perpendicular to the line of collision "mg" is acting Hence net force is not ZERO. So how ?
Welcome to PF;
Momentum is always conserved.
Note - in a collision there are unbalanced forces all over the place ... each object in the collision may change it's momentum, therefore it must have experienced an unbalanced force.
Hence net force is not ZERO. So how?
How ... what?
Note: if a projectile falls towards the Earth due to the Earths gravitational pull, the momentum gained is balanced by equal and opposite gain by the Earth being attracted by the projectile.
One usually assumes that the duration of the collision is short enough that the effect of outside forces (such as gravity) can be ignored during the collision (the contact forces are much greater). This is called the 'impulse approximation' in many textbooks.
That too :) though it is not uncommon for students to face questions involving quite lengthy complicated collisions like car-crashes... then it boils down to what counts as "short enough".
I was concerned at the idea that momentum may not be conserved during the action of an unbalanced force. However, for the colliding-projectiles example, it would be very common to take a "very short collision time" approach and we wouldn't normally factor in the momentum change for the Earth.
The passage that confuses rick2395 is trying to tell him that the components of the total momentum are conserved separately.
Basically as far i am concerned MOMENTUM CAN BE CONSERVED ALONG A DIRECTION WHERE NO NET EXTERNAL FORCE IS ACTING but in the example of the two projectiles force mg of both the particles acts downwards and there is no force to balance them(Unlike if they would have been place on a surface because then the force mg would have been negated by the normal reaction) so a net force mg + mg=2mg is acting along the vertical direction, and i can still conserve momentum along the vertical direction?
rick2395 said:
Basically as far i am concerned MOMENTUM CAN BE CONSERVED ALONG A DIRECTION WHERE NO NET EXTERNAL FORCE IS ACTING but in the example of the two projectiles force mg of both the particles acts downwards and there is no force to balance them(Unlike if they would have been place on a surface because then the force mg would have been negated by the normal reaction) so a net force mg + mg=2mg is acting along the vertical direction, and i can still conserve momentum?How?
I'm not sure what the issue is here.
The momentum along the vertical direction is not conserved in your case IF you only consider your system as being the two particles only! The fact that there is an external force acting on the two particles in the vertical direction tells you that the momentum of the 2 particles are not going to be conserved. Your text is describing a system in which no external net force is acting on that system. This is not the case here for the 2 particles.
If you consider the system as being the 2 particles plus the earth, then yes, the momentum of that 3-body system is conserved.
Zz.
i get that.
What changes do i have to make in writing the equation(momentum equations)
if i take into consideration the Earth as well??
rick2395 said:
i get that.
Why can't you just deal with the horizontal component and ignore the vertical component? What is it that you are trying to find?
Zz.
  • · Replies 53 ·
  • · Replies 26 ·
