| New Reply |
Black Holes - the two points of view. |
Share Thread | Thread Tools |
| Aug11-12, 08:34 AM | #18 |
Here are some other explanations and points of view....I have saved these in my notes from other discussions in these forums.
As Wald says, models...but that is a GUESS on my part. |
| Aug11-12, 08:45 AM | #19 |
Others have already given you several places to look. If those aren't enough you could also look at my own contributions in previous threads, e.g. Stupider-er Twins Question about the Rindler metric Questions about acceleration in SR, post #13 onwards |
| Aug11-12, 08:53 AM | #20 |
Mike...really good discussions so far here.....
My reading SO FAR leads me to conclude there are not more exact formulations....we don't know how to solve EFE equations in an irregular, curved and lumpy spacetime. Mike: You might find this in Wikipedia an interesting adjunct to Kip Thorne's description {I looked it up to get insight on what Kip Thorne meant}: http://en.wikipedia.org/wiki/Eddingt...in_coordinates where it points out: So while there is a type of time 'singularity' at the Schwarzschild radius, uniqueto those coordinates, I can think of three cases where it is NOT present: a free falling observer in those SAME coordinates, in the Eddington-Finklestein coordinates, and as I think has already been mentioned in this discussion, Kruskal-Szekeres coordinates. So my own {novice} view is that between the different coordinate dependent descriptions and local versus global considerations, I have not yet come across any single, universal all encompassing perspective that is absolute. |
| Aug11-12, 09:01 AM | #21 |
| Aug11-12, 09:06 AM | #22 |
Mike,
There is a closely related discussion here which you might find interesting: Unruh effect and lessons regarding reality http://www.physicsforums.com/showthread.php?t=625633 [I'm pretty sure this was previously blocked......anyway, now is open again as I post here. "reality" is a not a good word to bring up as it quickly devolves into philosophy.] The essence of this discussion revolves around that fact an an inertial observer and an accelerating observer have different spacetimes,one flat, one curved, hence different apparant degrees of freedom, hence different observations. What this actually means appears open to some debate.... Sound familar??? |
| Aug11-12, 01:51 PM | #23 |
TIME WARPS, by Kip Thorne.... I'll post if I can find it.... As I recall from other sources, the original horizon description is now called 'apparent' Horizon as discovered by Roger Penrose; Stephen Hawking did not like that coordinate dependent description, especially it's instantaneous discontinuous jumps when matter/energy was absorbed, and developed a complementary viewpoint, I believe the one routinely utilized today, the absolute horizon... Others in these forum have discussed further distinctions, and one of them is that the [apparent] horizon jumps in anticipation of matter crossing the horizon. I believe this is analogous to the instantaneous appearance of the apparent horizon during the initial formation of a BH when it appears and cloaks the singularity; in contrast, Hawking's absolute horizon is created at the center of a new forming BH and moves smoothly to the stars surface as it impodes meeting the apparent singularity at the Schwarzschild radius. |
| Aug20-12, 02:57 AM | #24 |
Naty1 and Greg, I really appreciate the time you have put in to try and educate me, but I remain unconvinced. I have read Kip Thorne’s book, and am very aware of his dilemma - after mentioning all the calculations I quoted, he concludes that Black Holes would take an infinite time to form, and then he gets on to Wheeler, and decides to suppress that thought and go along with majority opinion.
I am very aware of the relativity of realities. The fact is that a spaceman falling into a Black Hole REALLY DOES fall in in a short time, in HIS time frame, but he REALLY DOESN’T in OUR distant observer frame. Neither view is an illusion. Neither “appears to”. They are both valid descriptions of what REALLY happens. Birkoff’s Theorem proves that the space outside a spherically symmetrical Black Hole follows Schwarzschild’s metric, and EVERY calculation using Schwarzschild’s metric has given the same result. The calculation has also been done for spinning Black Holes, but I cannot recall the reference. Eddington-Finklestein coordinates also resolve to Schwarzschild coordinates outside the event horizon, so they make no difference. As an example of where Kip Thorne gets it wrong, The best physical interpretation is that, although we can never actually see someone fall through the event horizon (due to the infinite redshift), he really does. As the free-falling observer passes across the event horizon, any inward directed photons emitted by him continue inward toward the center of the black hole. Any outward directed photons emitted by him at the instant he passes across the event horizon are forever frozen there. So, the outside observer cannot detect any of these photons, whether directed inward or outward. “Really does”? This assumes one frame is valid and the other an illusion, and that is rubbish. He then describes the observed redshift as purely resulting from the difficulty photons have escaping, and totally ignores the gravitational time dilation. Naty1, you say Schwarzschild coordinates include a flat asymptotic spacetime [that's not realistic]; FLRW assumes a perfectly homogeneous and isotropic spacetime and everyone here agrees the FLRW model does NOT apply to galactic scales....One has to also wonder how precise it is on cosmological scales...but that is not especially important for this discussion. So many replies say the Schwarzschild solution is not accurate, but no one has proved that it gives the wrong answer, or shown me another one which can be proved to be more accurate and gives a different result for gravitational collapse. As I understand it, Schwarzschild only requires that the spacetime be flat and asymptotic at infinity. I doubt that Earth’s gravity and movement would affect the calculation. I’m beginning to think the only reason for rejecting the Schwarzschild calculations is that they say Black Holes don’t exist (at least not yet, in our time frame). When describing Event Horizons expanding, one must always remember what space-time frame you are using. These events may occur locally, but gravitational time dilation means that in a remote time frame time is stopped at the Event Horizon. This means nothing happens. If you don't accept this, then you need to provide another equation relating time dilation to gravity near a Black Hole. Mike |
| Aug22-12, 11:42 PM | #25 |
Sorry, I lost track of this thread for a while so I am catching up with my responses:
“According to the clocks of a distant observer the radius of the contracting body only approaches the gravitational radius as t -> infinity.” That does *not* say that the black hole does not exist. It only says something about the clocks of the distant observer. If you look at all the other quotes you gave in context, they all say the same thing. None of them say that the black hole does not exist. In fact, the Oppenheimer-Snyder paper from Physical Review, that you quoted, explicitly says, IIRC, that there is a region of spacetime inside the horizon, and that the collapsing matter falls through that region to a curvature singularity at r = 0. |
| Aug22-12, 11:53 PM | #26 |
| Aug23-12, 06:21 AM | #27 |
Mentor
| Aug23-12, 08:39 AM | #28 |
I think that the following has been cited twice here, but it doesn't make any sense to me:
“What would happen if you fall in? As seen from the outside, you would take an infinite amount of time to fall in, because all your clocks – mechanical and biological – would be perceived as having stopped’' - Carl Sagan “Cosmos”, 1981 I would think that if I (being "outside") perceive that your clocks stop due to your speed and gravitational potential far away from me, this has no effect whatsoever on my clocks. Thus it can have no effect on the Earth time that I estimate it will take for you to fall in. And inversely, for you it will look as if you faster and faster accelerate into the black hole - the final descent happens in nearly no proper time. If anyone can explain my misunderstanding, I would be very grateful.
| Aug23-12, 11:04 AM | #29 |
Unless I've misunderstood your question, that's all there is to it, isn't it? |
| Aug23-12, 03:04 PM | #30 |
| Aug23-12, 07:17 PM | #31 |
| Aug24-12, 08:23 AM | #32 |
| Aug24-12, 07:42 PM | #33 |
Harrylin, you cannot at any stage "infer" that DrGreg fell into the black hole. After carrying out his researches very close to the Event Horizon he might have fired his rockets and come back to join us for tea and to discuss his observations.
Only when he falls through the EH can he say it has happened. But we cannot translate this event into our coordinate system (time frame) because we land up with t = infinity. So we external observers can never say something has fallen into a Black Hole, only that it will, and that it does in its local timeframe. Now if you take this a step or two further, we find that Xwatl, from the planet Wortl, who started falling intro a Black Hole 10,000 years ago, also hasn't reached the EH in our time frame, and neither has that gas cloud that the BH started eating a billion years ago. In fact, nothing has ever falllen into a Black Hole, in our timeframe, so we can never say it has happened. Mike |
| Aug24-12, 09:01 PM | #34 |
| New Reply |
| Thread Tools | |
Similar Threads for: Black Holes - the two points of view.
| Using Black holes to view our solar system | General Astronomy | 1 | ||
| Black holes, white holes and expansion of Universe | Cosmology | 7 | ||
| Points in space and black holes | General Astronomy | 7 | ||
| White Holes are time-reversed black holes? | General Physics | 29 | ||
| Re: White Holes are time-reversed black holes? | General Physics | 0 | ||
