How to Compile PROPEP for 32 Bit Systems?
  • Thread starter Thread starter jelanier
    Bit
The discussion revolves around the challenges of compiling the PROPEP program, originally written in FORTRAN for 32-bit systems. Participants explore various compiler options, compatibility issues, and necessary code modifications to successfully compile and run the program on modern systems.
  • Jim seeks assistance in compiling PROPEP for 32-bit systems, noting that he can compile it using IBM FORTRAN version 1.00 but encounters errors with G77.
  • Some participants suggest that the errors may be trivial and emphasize the importance of familiarity with FORTRAN for resolving compilation issues.
  • Jim clarifies that he is not looking to update the executable but rather to compile the existing source code, mentioning specific function calls that are no longer supported.
  • One participant reports success in compiling a related file, JANCREAT.FOR, using G95, while noting issues with PROPEP due to file I/O and input/output changes required for G77.
  • Jim reports that he successfully compiled PROPEP using G95 after making several edits, but encounters issues with the output file format and parsing.
  • Another participant suggests compiler options to initialize local variables and allocate them in static storage, which may align with the behavior of the original IBM compiler.
  • Jim later confirms that using specific compiler flags with G95 improved the output, although he still faces issues with the output file's last section.
Participants express differing experiences with various compilers and the specific changes needed to compile PROPEP. There is no consensus on a single solution, as multiple approaches and challenges are discussed.
Participants mention specific code modifications and compiler flags, but the discussion does not resolve the underlying compatibility issues or the exact nature of the errors encountered. The dependency on specific compiler versions and settings is noted, along with the potential for unresolved file I/O issues.
jelanier
I am trying to compile PROPEP for 32 bit systems. (Martin-Marietta FORTRAN program for chemical equilibrium)
It was originally written for IBM professional FORTRAN version 1.00
I can compile with the IBM 1.00, so I know my source code is valid.
I have tried G77 with loads of errors. Does anyone have any suggestions to try?
The 16 bit will not run on Win7 64. I have written a GUI for PROPEP and I would like to update the executable.
http://www.chemroc.com/programs/GDL_Propep120.zip
Thanks,
Jim
Technology news on Phys.org
Nope, it does not look to me like you are trying to update the executable, instead, it sounds like you are trying to re-compile it without having to bother updating it!
If you are going to use a more modern compiler than the one that was used originally...I think you'd better clean up those errors...I bet they are all very trivial given than Fortran is a very noble language and very backwards compatible...
...you just need to know Fortran, if you don't, get somebody who does...otherwise, you are going to find yourself asking question after question after question
No, I meant what I said. I was trying to compile the same source code to a 32bit executable.
The question was if there was a backward compatible compiler. I have edited FORTRAN source before to change syntax or calls that are no longer valid. This is the case here with calls like:
CALL GETTIM (IHR,IMN,ISEC,IHUN). This is apparently no longer supported. I have edited it to remove those errors.
I am still having problems with the executable. This is a complex program and I don't want to re-write it.
here is the source:
www.chemroc.com/programs/pepsrc.zip
Thanks,
Jim
Well, JANCREAT.FOR compiles just fine...and seems to run, too. It generates a file over 6000 lines long.
PROPEP.FOR as attached still has the gettim and getdat functions; once removed, this program compiles just fine, too. There seems to be a missing input file: setup.pep, though.
I am using g95 in mingw in Windows XP
Interesting. I had the same experience with JANCREAT.FOR. It compiled just fine and created the JANNAF.DAF file. This was with G77 (MINGW)
I am having lots of problems with propep however. I changed the date/time issue, also had to add 2 characters to the read PEPCODED.DAT (I guess G77 didn't like the CR/LF)
I had to change some 'con' input/output...but still no joy.
This is a link to all the files needed to run propep.
www.chemroc.com/programs/propep16bit.zip
Place all these files in same folder. It includes the propep.exe 16bit.. Run propep.exe, the PRINT.TXT is the output file. The input file has already been made. (You can see why I created a VB GUI for this program as linked in my original post :) )
I am curious if your G95 compile works. You could just replace the propep.exe with your compiled version. I get an exit and error message after I hit enter.
Thanks,
Jim
I GOT IT!
I am using G95 now. Lots of things had to be edited. (file I/O issues) It outputs with an extra space before each line now so I will have to change my parsing in GDL_propep..but that I can handle easily :)
I will be putting the new version of GDL_propep up on my website as soon as I am done with the parsing changes.
Thanks for the help
Jim
I spoke too soon :(
The output file is bad in the last section. t has something to do with my use of 'CONIN$' and 'CONOUT$'
I can't figure it out yet.
my latest:
www.chemroc.com/programs/pep32.zip
Jim
Compiled latest propep.for provided...output file mostly the same as the one provided, except for the last section:
Code:
 **********PERFORMANCE:  FROZEN ON FIRST LINE, SHIFTING ON SECOND LINE**********
 IMPULSE   IS EX      T*      P*      C*    ISP*  OPT-EX  D-ISP      A*M   EX-T
 -1217.1  0.0000     15.********     1.0            0.00    9.0 -0.00019    36.
   325.5     NaN     NaN    1.00 41437.1     NaN    1.00  611.6  1.28820  2001.
If this is an "old" program, I'll take a guess: find the compiler options to initialise all local variables to 0, allocate all variables in static storage instead of on the stack.
Neither of those is "standard Fortran" now, but there's a fair chance that's what your original IBM compiler did.
Compiled with:
g95 -fzero -fstatic PROPEP.FOR
output seems to be o.k., now.
Code:
[SIZE="3"]1                   Run using June 1988 Version of PEP,
  Case  1 of  1      1 Jan 1901 at  1: 0: 1. 1 am
   CODE                                   WEIGHT    D-H  DENS      COMPOSITION
    137 AMMONIUM PERCHLORATE (AP)        690.000   -602  0.07040    1CL  4H   1N   4O
     63 ALUMINUM (PURE CRYSTALINE)       160.000      0  0.09760    1AL
    541 IRON OXIDE                        10.000  -1230  0.18400    3O   2FE
    846 R45M                             140.000    -30  0.04330  667C 999H   5O
 THE PROPELLANT DENSITY IS 0.06790 LB/CU-IN OR  1.8794 GM/CC
 THE TOTAL PROPELLANT WEIGHT IS 1000.0000 GRAMS
 NUMBER OF GRAM ATOMS OF EACH ELEMENT PRESENT IN INGREDIENTS
   38.862015 H    10.263423 C     5.872490 N    23.754751 O
    5.930319 AL    5.872490 CL    0.125235 FE
 ****************************CHAMBER RESULTS FOLLOW    *****************************
  T(K)  T(F)  P(ATM)   P(PSI) ENTHALPY  ENTROPY   CP/CV     GAS   RT/V
 3314. 5507.   68.02  1000.00  -431.88  2286.95  1.1788 36.406    1.868
 SPECIFIC HEAT (MOLAR) OF GAS AND TOTAL=    9.493   12.158
 NUMBER MOLS GAS AND CONDENSED=  36.4060   2.8283
  11.99570 H2         9.80925 CO         5.10377 HCl        4.31460 H2O
   2.93053 N2         2.82795 Al2O3*     0.96127 H          0.45132 CO2
   0.27287 Cl         0.14655 HO         0.14592 AlCl       0.08655 FeCl2
   0.05432 AlCl2      0.03639 AlOCl      0.03180 Fe         0.01129 AlHO2
   0.01039 AlHO       0.00920 NO         0.00836 AlCl3      0.00688 O
  4.00E-03 FeCl      3.06E-03 AlO       2.20E-03 Al        1.48E-03 FeO
  1.08E-03 FeH2O2    1.00E-03 CHO       9.77E-04 O2        7.85E-04 Al2O
  7.81E-04 NH3       5.72E-04 Cl2       5.32E-04 CNH       5.11E-04 AlH
  3.91E-04 COCl      2.22E-04 NH2       1.37E-04 HOCl      1.23E-04 CH2O
  1.09E-04 N         9.44E-05 OCl       7.68E-05 NH        7.16E-05 FeCl3
  6.58E-05 Al2O2     3.24E-05 CNHO      2.06E-05 NHO       1.90E-05 AlO2
  1.43E-05 HO2
 THE MOLECULAR WEIGHT OF THE MIXTURE IS   25.488
 ****************************EXHAUST RESULTS FOLLOW    *****************************
 2001. 3142.    1.00    14.69 -1217.09  2286.95  1.2043 35.590    0.028
 SPECIFIC HEAT (MOLAR) OF GAS AND TOTAL=    8.988   10.812
 NUMBER MOLS GAS AND CONDENSED=  35.5902   2.9652
  12.66665 H2         9.60784 CO         5.61067 HCl        3.94054 H2O
   2.96481 Al2O3&     2.93596 N2         0.65476 CO2        0.12434 FeCl2
   0.03489 H          0.01147 Cl         0.00111 HO         0.00052 Fe
  1.70E-04 AlCl3     7.91E-05 AlCl2     7.14E-05 AlCl      4.96E-05 FeCl
  4.45E-05 NH3       4.15E-05 FeH2O2    3.40E-05 AlOCl     2.00E-05 FeCl3
  1.86E-05 NO
 THE MOLECULAR WEIGHT OF THE MIXTURE IS   25.937
   254.3  1.1857   3033.   38.59  5079.9            9.13  478.0  0.15792  1711.
   261.4  1.1550   3089.   39.00  5128.8   197.3   10.06  491.3  0.15944  2001.
Code:
  Case  1 of  1      1 Jan 1901 at  1: 0: 1. 1 am[/size]
Except that it's not Y2K compliant! :smile:
I have it uploaded to my website with GUI. I see you re-compiled also :)
The time/date I need to fix. I did a quick fix that will not work. I was just trying to get past the easy stuff.
I used:
g95 -fstatic propep.for -o propep.exe
Anyway, you can try it from
www.chemroc.com
Thanks everyone,
Jim
Here is my latest source code and associated files. Don't laugh at what I did to the time/date stuff. I will fix it. (You will probably beat me :) )
http://www.chemroc.com/programs/propep32.zip
I also included a batch file that runs the compile.
Thanks,
Jim
OK, I fixed the time with the newer syntax. It seems OK now. Thanks for the help guys...
My new version with GUI is @ www.chemroc.com
This is what I did to fix the time:
ORIGINAL FORTRAN IBM VERSION 1.00
SUBROUTINE DATETIME (TODAY,CURTIM)
INTEGER*2 IDAY,IMO,IYR,IHR,IMN,ISEC,IHUN
CHARACTER*3 MONTH(12)
CHARACTER*2 IAM,IPM,IAMPM
CHARACTER*11 TODAY
CHARACTER*14 CURTIM
DATA MONTH /3HJan,3HFeb,3HMar,3HApr,3HMay,3HJun,3HJul,3HAug,
1 3HSep,3HOct,3HNov,3HDec/, IAM /2HAm/,IPM /2HPm/
C CALL ROUTINES FOR DATE AND TIME
IAM='am'
IPM='pm'
IAMPM = IAM
IF (IHR.LT.12) GO TO 10
IHR=IHR-12
IAMPM=IPM
10 CALL GETDAT (IYR,IMO,IDAY)
IF (IYR.LT.1000) IYR=IYR+1900
IF (IHR.EQ.0.AND.IAMPM.EQ.IPM) IHR=12
WRITE (CURTIM,1) IHR,IMN,ISEC,IHUN,IAMPM
WRITE (TODAY,2) IDAY,MONTH(IMO),IYR
RETURN
1 FORMAT (i2,':',i2,':',i2,'.',i2,' ',A2)
2 FORMAT (I2,' ',A3,' ',I4)
END
EDITED FOR G95 COMPILER
integer,dimension(8) :: values
CHARACTER*11 TODAY
CHARACTER*14 CURTIM
CALL DATE_AND_TIME(VALUES=VALUES)
IAM='am'
IPM='pm'
IHR=VALUES(5)
IMIN=VALUES(6)
ISEC=VALUES(7)
IHUN=VALUES(8)
IHUN=IHUN/10
IAMPM = IAM
IHR=IHR-12
IAMPM=IPM
10 IYR=VALUES(1)
IMO=VALUES(2)
IDAY=VALUES(3)
WRITE (CURTIM,1) IHR,IMIN,ISEC,IHUN,IAMPM
RETURN
END
Even uglier when editing for G77. It works, but I'll bet there is an easier way.
FORTRAN is not my native language, but I can eventually find my way around :)
Jim
TIME DATE Section Edited for G77
CHARACTER(LEN = 8) :: DateINFO ! ccyymmdd
CHARACTER(LEN = 4) :: cYR, cMO*2, cDay*2,cHUN*2
CHARACTER(LEN = 10) :: TimeINFO ! hhmmss.sss
CHARACTER(LEN = 2) :: cHR, cMIN, cSEC*6
CHARACTER*11 TODAY
CHARACTER*14 CURTIM
INTEGER*4 IDAY,IMO,IYR,IHR,IMIN,ISEC,IHUN
CALL DATE_AND_TIME(DateINFO, TimeINFO)
IAM='am'
IPM='pm'
cHR=TimeINFO(1:2)
read (cHR,'(I2)') IHR
cMIN=TimeINFO(3:4)
read (cMIN,'(I2)') IMIN
cSEC=TimeINFO(5:6)
read (cSEC,'(I2)') ISEC
cHUN=TimeINFO(8:9)
read (cHUN,'(I2)') IHUN
IAMPM = IAM
IHR=IHR-12
IAMPM=IPM
10 cYR=DateINFO(1:4)
read (cYR,'(I4)') IYR
cMO=DateINFO(5:6)
read (cMO,'(I2)') IMO
cDAY=DateINFO(7:8)
read (cDAY,'(I2)') IDAY
RETURN
END
15K
  • · Replies 37 ·
