How Does Capacitance Change with Multiple Dielectric Materials in a Capacitor
The discussion revolves around the concept of capacitance in capacitors that contain multiple dielectric materials. Participants are exploring how the presence of different dielectrics affects the capacitance formula, particularly in the context of a standard parallel plate capacitor.
  • Conceptual clarification, Mathematical reasoning, Problem interpretation
  • The original poster questions how capacitance is calculated when multiple dielectric materials are present, specifically whether the area they occupy influences the formula. Other participants discuss modifications to the capacitance formula and potential integration of Maxwell's equations, while also considering the implications of different dielectric constants on the overall capacitance.
Participants are actively engaging with the topic, with some providing mathematical insights and others expressing understanding of the concepts discussed. There is a recognition of the complexity introduced by multiple dielectrics, and guidance has been offered regarding the equivalent capacitance for capacitors with different dielectric materials.
There is an assumption that the capacitors in question are standard flat parallel plate capacitors, and discussions include considerations of thickness and dielectric constants. The original poster's inquiry suggests a lack of clarity on how to approach the problem with multiple dielectrics.
xcutexboax
Hey Guys,
I was just doing a question on capacitance and i was wondering since capacitance is usually determined by a fixed formula which is dependent on the di electric material that is contained within a capacitor.. However it struck me that a capacitor does not neccesarily contain only one kind of material. How does the expression of the formula changes if a capacitor can contain more than one kind of di-electric materials... pls enlighten me... IS it based on the area they occupy? ThAnks. :confused:
IIRC, for multiple dielectric capacitors, you would simply use the modification of one of Maxwell's equations, namely: [tex]V = \int{\kappa\overrightarrow{E} \cdot d\overrightarrow{s}[/tex]. In this case, you integrate over the thickness of one capacitor, then over the thickness of the other capacitor, then add the two results to find the electric potential across the plates.
If I was referring to the formula C=k*epsilon*A/d where k is the dielectric constant of the material, how does finding the potential change the above expression? I mean if a capacitor can contain like 3 dielectric materials of different k, how does it affect the above expression/formula? =)
If you have a capacitor with two distinct materials as dielectrics in between the plates with dielectric constants [itex]\kappa_1[/itex] & [itex]\kappa_2[/itex] (and assuming you're dealing with a standard, flat parallel plate capacitor here), if the thickness of material one is the same as that of material two (let's say a thickness of [tex]d[/tex]), then the equivalent capacitance is given by [tex]C_{eq} = \frac{C_1 C_2}{C_1+C_2}[/tex], where [tex]C_1 = \frac{\kappa_1 \epsilon_0 A}{d}[/tex], and same for [tex]C_2[/tex]. Of course, in this case, I'm taking the actual plate-distance to be [tex]2d[/tex]. :wink:
Oh i finally understand... u took the capacitor like a circuit which contatins other "capacitors". Marvellous... Okie thanks for the tip.
  • · Replies 17 ·
  • · Replies 20 ·
