New Reply
Rate of change of Air Temp through a Copper Tube
Share Thread Thread Tools
Aug12-12, 02:43 PM   #1
I need to find out the temperature change of air going through a chilled copper tube. The air will be traveling through 15 feet of tubing at a rate of 1 liter/second. The copper tube is chilled to 20 degrees F by a refrigeration unit and the air is 90 degrees F when it enters the tube. What will be the temperature of the air when it exits the tube?
How can I calculate this.
Thanks.
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
New Reply
Thread Tools
Similar Threads for: Rate of change of Air Temp through a Copper Tube
Thread Forum Replies
How to calculate rate of change of temperature of air going through tube General Physics 0
Copper tube and magnet? Introductory Physics Homework 3
newton rate of temp. change Introductory Physics Homework 1
calculating temp rise in copper wire Electrical Engineering 12
final temp of copper ball Introductory Physics Homework 1
