Use partial fractions to find the sum of the series
The problem involves finding the sum of an infinite series using partial fractions. The series is expressed as a summation from n=1 to infinity of the function 5/(n(n+1)(n+2)).
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the use of partial fraction decomposition and express difficulties in identifying a pattern or convergence in the series. There are questions about the implications of diverging terms on the overall series convergence.
Some participants have offered hints and guidance regarding the reorganization of terms to reveal cancellations. There is an ongoing exploration of the series behavior, with no explicit consensus reached on the solution.
Participants note that the original partial fraction expansion was incorrect, leading to confusion. There is also mention of the nth term test for divergence, and the discussion includes references to external tools for convergence checks.
JFUNR
Use partial fractions to find the sum of the series: [itex]\Sigma[/itex]n=1 to infinity [itex]\frac{5}{n(n+1)(n+2}[/itex]
Partial Fraction breakdown: [itex]\Sigma[/itex] [itex]\frac{5}{2n}[/itex]+[itex]\frac{5}{2(n+2)}[/itex]+[itex]\frac{5}{(n+1)}[/itex]
When I tried to cancel terms out, it is erratic and no pattern seems to emerge. It is not geometric so using a/(1-r) isn't possible. When I separated the terms, each diverges based on the nth term test. According to the all-knowing wolfram-alpha, the series converges to 5/4...I feel as if I am missing something big in my attempts at solving this one? any help?
Your partial fraction expansion is incorrect.
RGV
RGV
ah that was a typo, the partial fraction expansion I have in my attempts is...[itex]\frac{5}{2n}[/itex]+[itex]\frac{5}{2(n+2)}[/itex]-[itex]\frac{5}{n+1}[/itex]
I still have the same issue..
Edit : Whoops you had the right expansion I didn't see your post there.
There will be a pattern you will notice, but a more important question to ask yourself is : Suppose your sum is going from 1 to infinity. Let's say you're summing some A+B+C which are all composed of a variable n ( the variable you are summing of course ). If one of A, B, or C diverges, does the whole series diverge?
Hint 1: [tex]\sum_{n=1}^{\infty} f(n) = \lim_{N \to \infty} \sum_{n=1}^{N} f(n)[/tex]
Hint 2: [tex]\sum_{n=1}^{N} \frac{1}{n+2} = \left( \sum_{n=1}^{N+2} \frac{1}{n} \right) - \frac{1}{1} - \frac{1}{2}[/tex]
reindex second and third sums.
and notice you get a whole lot of cancelation.
How do you mean?
JFUNR said:
How do you mean?
He means that you should write it out in detail and see what happens.
RGV
RGV
by all means...enlighten me..where's the pattern...
([itex]\frac{5}{2}[/itex]+[itex]\frac{5}{6}[/itex]-[itex]\frac{5}{2}[/itex])+([itex]\frac{5}{4}[/itex]+[itex]\frac{5}{8}[/itex]-[itex]\frac{5}{3}[/itex])+([itex]\frac{5}{6}[/itex]+[itex]\frac{5}{10}[/itex]-[itex]\frac{5}{4}[/itex])+([itex]\frac{5}{8}[/itex]+[itex]\frac{5}{12}[/itex]-[itex]\frac{5}{5}[/itex])+([itex]\frac{5}{10}[/itex]+[itex]\frac{5}{14}[/itex]-[itex]\frac{5}{6}[/itex])+([itex]\frac{5}{12}[/itex]+[itex]\frac{5}{16}[/itex]-[itex]\frac{5}{7}[/itex])+([itex]\frac{5}{14}[/itex]+[itex]\frac{5}{18}[/itex]-[itex]\frac{5}{8}[/itex])+...+
while some terms do cancel, I do not see a patter out of the first 7 terms...but like I said...enlighten me
Do you really need someone to tell you that
[tex]\sum_{k=1}^N \frac{1}{2k} = \frac{1}{2} \sum_{k=1}^N \frac{1}{k}\;?[/tex]
RGV
The pattern may indeed be a little difficult to see like this, but notice, for example, that [itex]\frac{5}{6}+\frac{5}{6}-\frac{5}{3}=0[/itex] and [itex]\frac{5}{8}+\frac{5}{8}-\frac{5}{4}=0[/itex].
To formally reorganize the sum so that the cancellations become obvious, first look at the finite sum and apply the second hint I gave you to both the 5/(2(n+2)) and -5(n+1) terms. After reorganizing the finite sum to get the desired cancellations, take the limit as N->infinity.
  • · Replies 22 ·
