Principal curvature used in a contact problem
  • Context: Graduate
  • Thread starter Thread starter MechEng2010
    Contact Curvature
The discussion revolves around understanding the application of principal curvatures in a theoretical contact problem involving two surfaces. Participants explore the mathematical formulations related to curvature and its implications for the contact mechanics of the surfaces.
  • One participant seeks clarification on how principal curvatures apply to their contact problem, specifically regarding the determination of R1 and R2, and the planes associated with them.
  • Another participant explains that curvature is the reciprocal of the radius, suggesting this may be a source of confusion.
  • A further reply describes the process of determining principal curvatures by considering the normal to the surface and the intersection of planes containing this normal, noting that the principal curvatures correspond to maximum and minimum values as the plane is rotated.
  • It is mentioned that the planes of principal curvature are orthogonal and that curvature in intermediate planes can be computed from the principal curvatures and the angle they make with the principal curvature planes, although the specific formula is not provided.
  • Another participant adds that while the first body has the same tangent plane and normal at point P, the planes yielding minimum and maximum curvature for the second body may differ, introducing the angle phi as a significant factor in the analysis.
Participants express varying levels of understanding regarding the application of principal curvatures, and while some concepts are clarified, no consensus is reached on the specific methods for determining R1, R2, and their associated planes.
Participants have not resolved the mathematical steps necessary to fully understand the relationship between the principal curvatures and the contact problem, and there are dependencies on definitions that remain unclear.
MechEng2010
Hi,
I am trying to understand a theoretical problem involving the contact between two surfaces. I have uploaded a screen shot of the mathematical formulations of the solution.
I understand most of the solution, except the principal curvatures. I have tried to look up principal curvature, but still not sure how is applied to this problem.
I would really appreciate any help for the mathematicians out there.
https://dl.dropbox.com/u/47274064/Prin_curve_1.JPG
Thanks.
Curvature is the reciprocal of the radius. Is that what is confusing you?
Thanks Mandlebra, that much I understood.
I am just trying to understand how and why R1, R2, the planes of R1, R2 and the angle [itex]\Phi[/itex] come into this. I guess my questions are more specifically:
1) How do you determine what R1 and R2 are?
2) How do you determine the plane of R1 and R2?
Would really appreciate some advice or explanation on this.
Thanks.
Not sure if this helps...
Take the normal N to the surface at point P. Now take any plane containing the normal. The intersection of the plane with the surface produces a line with some curvature at P. As you rotate the plane about N, the curvature reaches a minimum and a maximum, possibly of opposite sign. These are the principal curvatures. The planes containing them will be orthogonal. I believe the curvature in any intermediate plane through N can be computed from the principal curvatures and the angle this plane makes to the planes of principal curvature, but I don't the formula.
Forgot to mention phi. The other body will have the same tangent plane at P and thus the same normal. But the planes through it which give the min and max curvature for that body will not in general be the same. Phi is the angle between the two bodies' max curvature planes (and thus also the angle between their min curvature planes).
  • · Replies 21 ·
