Definition of friction coefficients in a t-pipe
The discussion focuses on the definition of friction coefficients in a t-pipe configuration, specifically addressing the discrepancies in literature regarding these coefficients. The friction coefficient for the side branch is expressed as \(\frac{\Delta p_{sb}}{\frac{1}{2} \rho v_{c}^{2}}\), while the coefficient for the straight passage is \(\frac{\Delta p_{st}}{\frac{1}{2} \rho v_{c}^{2}}\). The user seeks clarification on how the pressure differences \(\Delta p_{sb}\) and \(\Delta p_{st}\) are defined, particularly whether \(\Delta p_{sb}\) represents the difference between the initial pressure in the side branch and the final pressure in the merged stream. Empirical data from pipe fitting manufacturers is suggested as a resource for accurate values.
  • Understanding of fluid dynamics principles
  • Familiarity with pressure loss calculations in piping systems
  • Knowledge of friction coefficient definitions
  • Experience with empirical data analysis in engineering
  • Research "Friction coefficients in fluid dynamics" for foundational knowledge
  • Explore "Pressure loss calculations for tee fittings" for practical applications
  • Investigate "Empirical data sources for pipe fittings" to find reliable manufacturer data
  • Learn about "Flow dynamics in branching pipes" to understand complex flow interactions
Engineers, fluid dynamics researchers, and professionals involved in piping system design and analysis will benefit from this discussion, particularly those focused on optimizing flow efficiency in t-pipe configurations.
Appa
Hiah,
I've got a question concerning a t-pipe configuration and the corresponding friction coefficient values because there are two different friction coefficients stated in literature. Let's assume we have a simple t-pipe where the main passage is larger than the side branch. The friction coefficient for the side branch is defined as [itex]\frac{\Delta p_{sb}}{\frac{1}{2} \rho v_{c}^{2}}[/itex] where [itex]v_{c}[/itex] is the initial velocity of the main passage flow. The friciton coefficient for the straight passage is then defined as [itex]\frac{\Delta p_{st}}{\frac{1}{2} \rho v_{c}^{2}}[/itex] .
This would be all hunky-dory except that I have no idea how the two pressure differences [itex]\Delta p_{sb}[/itex] (sb stands for side branch) and [itex]\Delta p_{st}[/itex] are defined. Is the former, for instance, just the difference between the initial pressure in the side branch and the final pressure in the merged stream? Could anyone offer any insight on this?
Cheers.
  • · Replies 31 ·
  • · Replies 45 ·
  • · Replies 29 ·
10K
