Can x/y approach any real on the real line?
  • Context: Graduate
  • Thread starter Thread starter cragar
    Set
The discussion revolves around whether the set of fractions formed by the ratio of two prime numbers, x/y, can be dense on the real line. Participants explore the implications of allowing negative primes and the potential density of these fractions in relation to the rationals and the reals.
  • Some participants propose that the set x/y, where x and y are any primes, could be dense on the real line, especially if negative primes are included.
  • Others suggest that proving density might be complex and could involve assuming exceptions to derive contradictions.
  • One participant notes that the set may resemble the rationals but excludes certain fractions like 1/k, raising questions about the completeness of the set.
  • Another participant argues that the set misses many rational numbers, particularly those of the form p/q^n where p and q are distinct primes.
  • Some participants discuss using the existence of primes between n and 2n to construct proofs of density, considering how to approximate any real number using prime fractions.
  • There are suggestions to adapt methods used to prove the density of rationals in the reals, involving careful selection of primes and natural numbers.
  • One participant introduces the Prime Number Theorem as a potential tool for proving density, while expressing caution about computational accuracy.
  • Another proposes constructing sequences of fractions to approximate specific values like 1/2, while noting the necessity of infinitely many primes in such constructions.
  • Concerns are raised about ensuring that both components of a fraction can be prime simultaneously, with references to Dirichlet's Theorem and the challenges it presents.
Participants express a range of views on the density of the set x/y, with no consensus reached. Some agree on the potential for density, while others highlight significant challenges and exceptions that complicate the argument.
Limitations include unresolved assumptions about the nature of primes and the specific conditions under which density may hold. The discussion also reflects varying levels of mathematical rigor and completeness in the proposed arguments.
cragar
if i have this set x/y where x and y can be any prime. is this dense on the real line.
and we will allow x to be negative so we can cover the negative side of the reals.
It seems like it would be. how would i prove that x/y can approach any real?
Hmmm. It seems very likely that they are dense. Proving it might not be that easy though: there MIGHT be some exception. The first thing I would try is assume there is such an exception and see whether that leads to a contradiction. Or maybe proving that they are dense on the rationals would be good enough, since the rationals are dense on the reals.
Well, it seems the only problem you may have is with the fractions 1/k.
Don't you basically get the rationals with the set {x/y: x,y prime} except for {1/k}?
After all, you reduce the rationals {p/q: p,q integer} by eliminating common terms;
you actually eliminate redundancy, but you end up with the same thing: so all you
need, I think , is to deal with density in [0,1/2].
Not at all. You actually miss a bunch of rational numbers. For example, you miss all rational numbers of the form p/qn where p,q are distinct primes and 1 < n.
Right, my bad. I jumped in too quickly.
Me too. My 'proof' of the result actually fails.
could we maybe use the fact that there is prime between n and 2n where n is a natural number.
That seems to be the right approach to me. I imagine the best way to go about it would be some sort of quasi-constructive proof, where we take an arbitrary real number and use the above fact (or something like) to show that a prime fraction exists in any neighbourhood of x.
we could try something similar to how they prove the rationals are dense in the reals.
given any two reals a and b we pick n large enough so that
[itex]\frac{1}{n}<b-a[/itex] then we take the next prime after n and we call it k.
so now we have a prime on the bottom. ok and now we will pick m such that it puts us in between a and b. m is a natural number but not a prime for sure. But we know there is prime between m and 2m. but we may have skipped over b. but we could make the denominator bigger to give us more options for m.
Right, I have been thinking about a method to (see if it is possible ) to do this. But, with
my method, the (numbers in the) fractions become way too large. So, say, we want to
approximate 1/2 within 1/100: so my idea is : consider the set {n/2n} (clearly not
a ratio of primes ), and consider, for fixed n, the ratios:Pr:= {(n-1)/(2n-1), (n+1)/(2n+1),
(n+1)/(2n-1)(n-1)/(2n+1)}, }. If both numerator and denominator are prime, we get
a good approximation:| 1/2 - (n-1)/(2n-1) |= 1/(2n-1) -->0 as n becomes large; similar for other ratios. For
example, with 1/2 itself,
we can consider : 29/59=(30-1)/(60-1), 31/61, 73/37 , 157/79 ,... as approximations.
If we know there are infinitely-many n in the prime-ratio set Pr . Problem is that ,
while there are infinitely-many primes, we cannot guarantee right away ( may need an
additional argument) that the primes beyond a certain point are of this type. I think
this is feasible, but I'm being careful given my previous error.
Let (x,y) be an open interval in the real numbers with 0 < x < y. The Prime Number Theorem implies that limq→∞[π(qy)-π(qx)] = ∞ and this means that for a sufficiently large prime q, there exists a prime p such that qx < p < qy. Then x < p/q < y as desired.
Unless I messed up on the computation of limq→∞[π(qy)-π(qx)], then this proof should work fine.
What do you think about my idea:
What do you think about my argument?
My idea is , e.g., for x=1/2, to construct the set :
{1/2,2/4,...,2n/4n,...}
Then, to each term in the sequence , we add/subtract 1 to each numerator and
denominator, so , e.g:
1/2 --> 2/3, 2/1 , 0/1, 0/3
2/4 --> 3/5, 3/3, 1/3, 1/5 ,
etc.
Each of these terms is a potential ratio of primes, and a good approximation to 1/2,
with the caveat that primes of this type must be infinitely-many.
I thought about a similar approach to yours yesterday, but I came across too many difficulties trying to make everything work. The problem is that for a fixed rational number p/q it is difficult to ensure that there are infinitely many n for which both np-1 and nq-1 are prime. Using something like Dirichlet's Theorem you should be able to show that there are infinitely many n with np-1 prime and infinitely many n with nq-1 prime, but this (unfortunately) says nothing about n for which both of them are prime. There might be a clever way around this or there might be some theorem which guarantees the existence of infinitely many such n, but with my very limited knowledge I obviously know of neither.
Thanks for the input, Jgens.
  • · Replies 17 ·
  • · Replies 21 ·
