Division By Zero: Why Do People Call it Infinity?
The discussion revolves around the concept of division by zero and why some individuals refer to it as infinity. Participants explore the implications of this notion within mathematics and physics, examining definitions, terminology, and the utility of limits in various contexts.
  • Some participants assert that division by zero is not defined in the real numbers, emphasizing that referring to it as infinity is incorrect.
  • Others suggest that calling division by zero infinity may stem from loose terminology or specific contexts in higher mathematics.
  • One participant mentions that limits can provide useful approximations in physics, even if mathematically division by zero is not defined.
  • Another viewpoint highlights that while division by zero is not defined, using it as infinity can lead to practical predictions in physical applications.
  • Some argue that the inability to measure infinity makes it impractical for scientific and engineering contexts.
  • A participant questions the consistency of definitions in mathematics and physics regarding division by zero.
  • There is a mention of the distinction between mathematical definitions and their applications in physics, with some asserting that physicists do not equate division by zero with infinity in a formal sense.
Participants express disagreement on the validity of calling division by zero infinity, with some asserting it is incorrect while others argue for its utility in physics. The discussion remains unresolved regarding the appropriateness of this terminology across different fields.
Participants note that definitions must be consistent with other mathematical principles, and there are unresolved questions about the implications of using infinity in practical applications.
sambarbarian
In most cases division be zero ends up with not defined , but why do people sometimes call it infinity ?
Mathematics news on Phys.org
Maybe they are being loose. It seems like a bad idea to me.
You should probably read the FAQs.
Your question is bad. In most cases? What does that mean.
Look. Dividing by 0 is not defined in the Real numbers. PERIOD.
People who call it infinity are either,
1) Don't know what they are talking about and are wrong.
-or-
2) Doing very high level math, using a different number system.
-or-
Or 3), they are being loose with terminology and mean it in a limit sense, e.g., ##\lim_{x \rightarrow 0^+} 1/x = \infty##
Infinity is not a defined number within the reals..
i think that's it
"In most cases"? Division by zero is not defined. Period. Certainly some people use to write things like
[tex]\lim_{n\to\infty}\frac{1}{n}=\frac{1}{\infty}=0[/tex]
but this is either a huge mistake (if the writer isn't aware of what he's doing) or else just an agreed shortwriting.
DonAntonio
Why doesn't someone just define it! ;)
Because your definition has to be consistent with your other definitions, and there's no definition you can pick to make it consistent, at least in the usual number systems we work with.
Before you can define division by zero you have to define division.
Can you do this?
However the question of why is the subject not properly treated in maths classes when they reach a level to appreciate the answer is moot.
In math it's not defined, but in physics division by zero is infinity. And it's not that physicists don't know what they're talking about, it's just that limits make for incredibly useful approximations, which you need to apply in order to get things done within the human lifespan.
This isn't really an issue of limits.The limit of 1/x as x tends towards zero is not the same thing as 1/0. It is a fundamental property of the reals that zero does not have a multiplicative inverse; you can't add one without altering the behaviour of the entire system.
That's not really my point, my point was that using the approximation 1/0 = ∞ leads to observable predictions which agree with experiment, so even if mathematically it is incorrect, in physics and other sciences it's enormously useful to define 1/0 to be infinity.
(And one can argue about what's more important, mathematical soundness or physical observation, but at the end of the day planes still fly and bridges don't fall down).
Physical things deal with quantities that are measureable: you can't measure infinity or make sense of it in a tangible/physical sense so in terms of observation or physical quantification of some kind (for things like science and engineering), it's not useful in that regard.
I myself studied some physics while at undergraduate school, and all my best friends were physicists: division by zero is not defined
as infinity in physics, and that's a fact that can be pretty easily checked in any decent physics textbook (in mechanics, optics or whatever).
Now, some physicists can write [itex]\frac{1}{0}=\infty\,[/itex] , just as they can write [itex]\,\frac{dy}{dx}=dy\cdot\frac{1}{dx}\,[/itex] or
absurdities like these: it still is wrong, both within mathematics and within physics, unless there exists an a priori
agreement on what some weird notation may mean, just as writing "s.t." means nothing to anyone not knowing this is usually
taken to means "such that" in mathematics (and perhaps in some other areas as well)
DonAntonio
No: what is enormously useful is to understand the concept that "medium / tiny = huge".
  • · Replies 47 ·
  • · Replies 40 ·
  • · Replies 36 ·
