New Reply
Can a magnet's magnetic field perform work on another magnet?
Share Thread Thread Tools
Aug18-12, 07:43 AM   #35
Recognitions:
Gold Membership Gold Member
Quote by DaleSpam View Post
The ideal gas law for the pressure inside the balloon, Hookes law for the tension in the balloon, and Newton's laws for the force on the can. Maxwell's equations don't figure in that kind of a scenario, at least not classically.
I'm not touching the can in any way. It moves only electrostatically. It's a textbook example of an electric field, Dale.
Respectfully,
Steve
Aug18-12, 09:25 AM   #36
Mentor
Quote by Dadface View Post
My post above refers to definitions,accepted nomenclatures.What word(s) would you use to name the force on the paperclip or the current carrying wire?The "magnetic" force seems to be a preferred description according to searches I have made so far.See,for example,the MIT lectures on the subject.
If we were not to call it the magnetic force then I have suggested that the electromagnetic force may be a better description,but is this being too fussy?.I imagine that most text books(at least up to A level standard)would still continue to refer to the "magnetic" force so as to distinguish it from the electric force between stationary charges.
Force is different from work. I would call it a magnetic force or a Lorentz force. But the magnetic part of the Lorentz force does no work, at least not directly.
Aug18-12, 09:29 AM   #37
Mentor
Quote by Dotini View Post
The balloon is charged and has an E field, but since the can is a conductor it won't exert a net force on it. At least, I think not. Do you have a reference?
To Q-reeus, see, I do ask other people to provide references, not just you.
Aug18-12, 09:32 AM   #38
Mentor
And vice versa any work done by E and j is only through its impact on B.Chicken and egg or a comprimise by calling it electromagnetic?
No, not vice versa, but the compromise wording is fine.
Aug18-12, 09:42 AM   #39
Recognitions:
When an uncharged object is placed near a charged object its charges rearrange themselves. Those charges attracted to the charged object move towards the charged object and those charges repelled move away. This effect is known as polarization.
Since the balloon is negatively charged and the Coke can is acting as if it is positively charged, the Coke can is attracted to the balloon. The force of attraction is so strong, in fact, that the Coke can begins to roll towards the balloon
http://phun.physics.virginia.edu/dem...rostatics.html
Respectfully submitted,
Steve
Aug18-12, 09:56 AM   #40
Mentor
Cool reference, thanks. I will go back and re answer the earlier post you made now that I understand what you were saying.
Aug18-12, 09:59 AM   #41
Mentor
I can create a charged object by rubbing a balloon on my hair. And then do work with it by rolling an aluminum can around on the floor. No magnet is required in this instance, as the work is done by an electric field.
Is this agreeable?
Yes, the work is done by the E field, given by E.j as usual.
Aug18-12, 10:41 AM   #42
Tell me how I am twisting this out of shape:
Originally Posted by Q-reeus: "So a long straight magnetized rod enclosed within a similarly shaped solenoid should completely demagnetize when the solenoid generates a B field Bs equal in magnitude and of the same sign as that of the magnet's initial B field Bm. ... This manifestly does not happen."
For the same manifestly obvious reasons as before - you take it out of context and proceed to give it an erroneous slant. You failed to quote both the preceding and following portions of my entry there. Do that, and the claim I am trying to 'overthrowing Maxwell's eqn's' is seen as distortion at best. Anyway, how about you explaining the stability of atoms using just Maxwell's eqn's - or are you indeed ignorant of the classical prediction that electron's must in-spiral to the nucleus in a very brief time? ME's really do have their limitations.
Aug18-12, 10:41 AM   #43
Q-reeus: "Electrical interactions of the E.j type simply do not and cannot apply in that wholly QM regime."
I agree.
But do you really? Then what of this from #18 (a quote from your own earlier posting):
Q-reeus: "I just managed to find the following, which might give pause for thought: http://physics.stackexchange.com/que...agnetic-dipole"
The derivation there is for force density, not power density. If you go through the next step then you get E.j. As I said in in my point 4 both E and j depend on B, so it does work indirectly.
That link to elsewhere was all about magnetic interaction with a fundamental magnetic dipole - i.e. electron's magnetic moment. You there claimed it still was explainable in terms of E.j energy interactions 'in the final step'. But now you agree with me? I'm confused - over where you really stand on this. Please clarify.
Q-reeus: "And it carries over to a permanent magnet as a QM glued ensemble of such."
I do not agree. If this were correct then classical mechanics would never be valid as every classical object is a "QM glued ensemble". As long as the energies and masses in your system are all much larger than the Planck scale then you are in the classical limit of QM and classical physics applies.
More nonsense. Have you not noticed my reference in #10 to the supercurrent situation? You do believe in the existence of quite macroscopic superconductivity (let's not forget superfluidity and one or two other more delicate phenomena like BE condensates)?
Q-reeus: "I notice you still haven't supplied any kind of coherent rebuttal to either #5 or #10."
Correct, and I will not until you provide some solid supporting evidence. The burden of proof is on you, not me; I will not accept it simply because you cannot be bothered to support your own claims. I have supported mine.
You only claim to. Actually, having taken a long time to make your public declaration of a 'final decision' here: http://physicsforums.com/showpost.ph...&postcount=348, it is only to be expected you now find it so hard to face up to having made a wrong decision. And btw, having accused me of 'wanting to overthrow established mainstream science' back in your #9, I find it a particularly ironic statement given, as my trawling backwards through that earlier thread has found, this choice opening position of yours there: http://physicsforums.com/showpost.ph...2&postcount=54. Having yourself adopted my current 'heretical' position (for the wrong reasons though) right up to that later posting linked above, one might have expected a little more understanding - you know, a "Hey, I can understand that view - it had been mine life-long right up till a short while ago!" Nothing of the kind. So, evidently you believe in a life principle of being especially kind, gentle, and understanding toward yourself, but it's ok to put the boot in to one's opposition via regular misquotes and innuendo. All's fair in love (or hate) and war seems your abiding motto DaleSpam.
Aug18-12, 10:41 AM   #44
Quote by gabbagabbahey View Post
Classically, permanent dipoles are modeled as the limiting case of a current loop shrinking to zero size, but in a way that leaves its magnetic dipole moment constant.
That can be done sure, but it's not the whole story.
As you point out, this model is not entirely accurate ( for one there must somehow be some mysterious energy source which keeps the magnetic dipole moment constant when subjected to external field, not to mention that elementary particles like electrons have a dipole moment associated with them that only comes in quantized values), but it does correctly predict the net force and torque on permanent dipoles without introducing an additional axiom to theory (one treating magnetic dipoles as fundamental and different from the other two types of fundamental sources, point charges and currents).
I respectfully disagree. There *must* be a fundamental break from classical behavior just in order that those 'point dipoles' have unchanging magnitudes during magnetic interactions. It is the central point of my #5 and #10.
Aug18-12, 10:41 AM   #45
Quote by vanhees71 View Post
Dotini, there is no contradiction between the quote you give and the fact that magnetic fields don't do work. Of course, if you compare the final state (paper clip attached to the magnet) with the initial state (paper clip separated from the magnet), you of course find that the change in magnetic-field energy is given by the work necessary to pick up the paper clip, attaching it to magnet.
This is precisely the content of Poynting's theorem, nicely explained at DaleSpam's link. This epxlains the the work is done by induced currents and electric fields during the transient (i.e., time-dependent!) situation when picking up the paper clip!
Missed responding to this before but address now - given your weight here as currently the thread's only expert/authority figure. If your claim that -dA/dt E fields acting on induced currents explains the above, I invite you, as someone familiar with both classical and QM regimes to apply that to what I brought up in #10. Do you disagree with my observation there that flux quantization in wholly superconducting circuits directly implies the failure of dW = E.j dv over an interval of magnetic interaction where supercurrent Is is forced constant, despite a changed increment of enclosed flux and thus a changed A.Is dl, where dl is an incremental length along the thin supercurrent? This despite that *on average* that quantity is invariant in a superconducting circuit - i.e. *on average* enclosed flux is an invariant? Moreover that as the superconducting circuit is shrunk smaller, so the interval of applied external B field variation over which Is = constant grows in inverse proportion to enclosed area? Do you further agree or not with my observation that an electron is in a sense the ultimate endpoint of shrinking, not a classical, but a superconducting, loop current re it's magnetic interactions? And that in that case there are precisely zero conditions in which E.j is relevant to electron-as-magnetic-dipole? And that a permanent magnet is an ensemble of such fundamental dipoles - notwithstanding that *quantized* electron orbital motion contributes to magnetization here, though generally to a minor degree? (Earlier I had specified fully magnetized when referring to interactions involving permanent magnets owing to it simplifying things, but that restriction can be dropped with no consequences for the argument here.) And that induced eddy currents - which may be treated as behaving entirely classically, are in general a very minor consideration - especially for slow relative motions and for certain materials such as 'hard' ferrites? I shall be interested to see how or whether you choose to deal with hopefully all of the above questions.
Aug18-12, 10:48 AM   #46
Mentor
Quote by Q-reeus View Post
So do you or do you not assert that Maxwell's equations predicts the complete demagnetization of any magnet due to an equal applied field? And do you or do you not believe that prediction is contrary to observation?
Just because I quote only a portion of your post does not mean that I am misrepresenting your position.
Aug18-12, 11:01 AM   #47
Not any magnet - a hypothetical 'magnet' comprised of classical perfectly conducting loop currents. And honestly, this was manifestly and clearly evident in my #5 - why do you keep asking the same questions to obvious answers?
I refer you back to #5!
Be honest DaleSpam - this has become a deeply personal thing, spanning a considerable time now over many past threads. You resent my style of 'irreverent' balloon pricking - especially when that balloon(s) are your's.
Aug18-12, 11:03 AM   #48
Mentor
In superfluidity, BE condensates, and superconductivity the thermal energy is small compared to the Planck scale. My comment applies to all of them as well.
The difference between that conversation and this being that vanhees71 actually presented me with good evidence supporting his point, in the form of solid references and good derivations from accepted theory.
That is something you have never done in any of our conversations. Should you ever decide to do likewise then you stand a good chance of changing my mind, but as it is your positions consistently appear to me to be both impervious to and unsupported by any good evidence.
Post some good evidence and then I will resume the discussion with you here, otherwise we are just wasting time and adding unnecessary tension to the forum.
Aug18-12, 11:52 AM   #49
You have shifted ground unannounced, but not enough to salvage that bit: Here's the original passage above bit originally referred to:
A blanket statement - and confused at that. Why do you choose the Planck scale as demarcation point - for both energies and length? It's crazy and excludes everything above fundamental particle if even there. Atoms for instance would far from qualify as a fundamentally quantum object.
Q-reeus: "You only claim to. Actually, having taken a long time to make your public declaration of a 'final decision' here: http://physicsforums.com/showpost.ph...&postcount=348, it is only to be expected you now find it so hard to face up to having made a wrong decision."
I can accept and respect that you believe that position, but...then:
You mean 'not something I accept'. The essence of my position is well enough put - and evidently Lubos Motl is similarly dismissed as 'crackpot'.
Should you ever decide to do likewise then you stand a good chance of changing my mind, but as it is your positions consistently appear to me to be both impervious to and unsupported by any evidence.
Evidence? It is fundamentally a conceptual issue one either 'gets' or not.
If you don't want unnecessary tension then avoid making blanket accusations and distorting my words - you well know I don't take that lying down. And how about you actually dealing with certain questions I posed earlier - answering them may help you.
From #42:
And you know the context to that one - so don't twist it to suit.
Finally, kindly this round, actually do answer my question in the earlier part of #43 - will you now clarify what seems to be a contradictory position?
Aug19-12, 08:49 PM   #50
I'm lost with all this... Please if someone can simply present an answer.
Yes/No, supporting a simple explanation?
I've lost myself with all this confusion.However, noticed that Van & Dale are still referring the same answer used in my previous thread.
Interesting.
Miyz.
Aug19-12, 09:27 PM   #51
Recognitions:
You can pick up a paper clip with a magnet. You can pick up another magnet with a magnet. That much is clear. Beyond that, authorities differ.
Respectfully,
Steve
New Reply
Thread Tools
Similar Threads for: Can a magnet's magnetic field perform work on another magnet?
Thread Forum Replies
Calculating the Magnetic Field due to a Bar Magnet Introductory Physics Homework 4
Magnetic Field of a Bar Magnet Classical Physics 1
Magnetic field of a bar magnet Advanced Physics Homework 3
How do I contain a magnet's magnetic field? General Physics 6
what make the magnet to be magnet with magnetic field? General Physics 23
