A couple of questions regarding AREAS (and getting the formulas,etc.)
  • Thread starter Thread starter mathzeroh
    Areas Couple
The discussion revolves around optimizing the area of a garden enclosed by a fence, given a total length of 80 feet. Various configurations are considered, including a barn on one side, a garden with dividers, and an L-shaped barn. Participants are exploring how to derive the area formulas for these setups.
  • Participants are attempting to formulate the area equations for different garden designs and are questioning the correctness of their expressions. There is discussion about using the quadratic formula and finding the vertex of the area functions.
There is ongoing dialogue about the validity of the area equations derived by participants. Some have provided guidance on correcting the equations, while others express confusion about the implications of their calculations. Multiple interpretations of the area functions are being explored.
Participants are grappling with the implications of their equations and the potential for different variable definitions affecting their results. There is a noted concern about typos and misunderstandings in the mathematical expressions presented.
mathzeroh
OK this problem has been giving me nonstop headaches and nightmares for over 4 days! :cry:
I just can't seem to understand something here! :frown:
Here's the actual problem:
Suppose that you have 80 feet of fence to enclose a garden. For each garden design below, find the dimensions of the garden which produce the maximum area. The "bold" lines indicate where the fence must go. Note: diagrams below not to scale.
1. Barn on one side. No fence necessary there.
max area = _______________
2. Garden with fence divider in the middle, barn on one side.
3. No barn, fence on all four sides, and two center dividers.
4. L - shaped barn used for one side and 10 ft. of the other side. No fence required for 3 ft. gate.
And here is the image for the fourth question:
For number one, the width let's say is w, that would make the length of the side that is not connected to the barn:
80-2w
So the area is:
A=w(80-2w)
A=(2w^2)-80w <----***TYPO! it should say: (-2W^2)+80W
And I'm sure that can go into the quadratic formula. that would give us the value for w and from there, we can find the missing side. BUT, if we find the vertex of the graph of this problem using this formula:
V=-b/2a
is this the same thing as getting the value of w using the quadratic formula?
And for nmber 2. this is what i got:
A=w(80-3w)
A=(-3w^2)+80w
Vertex:
V=-80/(2(-3))
V=40/3
And then i plugged that number (40/3) into the original equation to get the value for the Area. Which was: 533.333333333333...
so was that right? i highly doubt it! :cry: BUT WHY IS THAT WRONG? :confused:
and number 3:
well let's just say that it was a total distaster, so I'm not even going to put that one up. and just for the record, i gave up after that and number four wasn't even attempted. :frown:
80-2w
So the area is:
A=w(80-2w)
A=(2w^2)-80w
That's incorrect.You shouldn't have multiplied with "-1",because u changed the whole thing... :wink: Now your area function will have a minimum and not a maximum... :wink:
A=w(80-3w)
A=(-3w^2)+80w
Vertex:
V=-80/(2(-3))
V=40/3
It's correct... :smile:
Daniel.
OK, let's try and stop your nightmares...
For the first question, I think you have the wrong equation. What you need to do is come up with an equation for the area (which will be quadratic), complete the square and find the vertex (the x value, that is).
You know the sum of the 3 sides will be 80 feet. 2 of the sides will have the same length (according the the attachment). So the sides will have the following lengths: x, x, 80-2x. Now try and find an equation for the area. Let me know what you got. :smile:
could you please elaborate a bit further on that? i mean if its no trouble for you. i just don't know where i multiplied with -1. :confused:
thank you! :smile:
Daniel.
REALLY?! :bugeye: thanks man! :cool:
Find the "x" & "y" for the vertex of the following parabola
[tex]y(x)=x(80-2x)[/tex]
There's been a missunderstanding.I chose another variable to be the "x"...
Daniel.
EDIT:This is not the function u'll need to solve the problem #1.
Disregard this EDIT...
Daniel.
Thanx for giving the answer to my question to him... I was trying to get him to think... :devil:
For the forst problem your equation.It should be
[tex]A(x)=x(80-\frac{x}{2})[/tex]
Maximize this one...
Disregard my previous post (the EDIT,of course).
Daniel.
EDIT:See the next post... :-p
dextercioby said:
For the forst problem your equation (function for area is wrong).It should be
Disregard my previous post (except the EDIT,of course).
Daniel.
Correct me if I'm wrong, but wasn't the first equation you posted right,
A = 80-2x(x) ? According to my diagram, it is... :confused:
Daniel.
wait, [tex]\frac{x}{2})[/tex]?? ok now I am totally lost. i thought Area=Length*Width
So its not this?:
A=LW
A=x(80-2x)
A=80x-(2x^2)
I even edited my post up there because of that typo. this is what i'd gotten while working on it and now it looks like its all wrong! :rolleyes:
christinono, i was going to answer to ur post, and i had it edited on the other post, but i guess it was wrong. :frown:
that's what i was thinking too. :rolleyes: :rolleyes:
So its not this?:
A=LW
A=x(80-2x)
A=80x-(2x^2)
I still think we are right...
I remember doing the same type of questions in Math 20IB a couple years ago...
Anyways, do you know how to find the vertex by completing the square (or you could just use your calc)?
THEY ARE BOTH CORRECT AND SHOULD YIELD THE SAME MAXIMUM AREA.
I took another "x" than the OP...
Daniel.
Daniel.
I get it, but still don't understand WHY you'd want to do it that way. It's much simpler to define to of the sides as "x". I guess if you wanted, you could define those sides as [tex]2\pi x[/tex] and solve it that way...
christinono completing the square won't do anything because of this:
b=-2, right?
so you have to add this to both sides:
(-2/2)^2
which is 1, so it would be this:
A+1=(-2x^2)+80x+1
so now u have to subtract the one from that side where the A is and you get the original equation...unless i missed something. this is so time consuming, I am sorry for all the trouble u guys had to go through. :frown:
Yes,of course,there's an infinity of ways of solving the problem correctly...Let's hope the OP finds at least one if them... :-p
Daniel.
b=-2, right?
(-2/2)^2
A+1=(-2x^2)+80x+1
This is your function:
[tex]y(x)=-2x^{2}+80x[/tex]
Complete the square...
Daniel.
dextercioby is the area 800? it has to be.
because y=40
and x=20
and yeah, I'm hoping that's the right answer. :rolleyes:
b=-2, right?
(-2/2)^2
A+1=(-2x^2)+80x+1
What in the world is b, and why does it equal -2? :confused: :confused:
because y=40
and x=20
Yes, that's right :!) :smile:
because y=40
and x=20
Yes,the area is 800 and the sides are 20,20 & 40...
Daniel.
Daniel.
ur right, but I'm hoping i got the right answer not using the completing the square method... :rolleyes:
christinono i was on crack earlier, my equation wasn't in the standard form which as everybody but me knows, is crucial! :-p :biggrin:
THANK YOU BOTH!
i'm going to work on the other ones and i'll get back to u guys. thanks again! wow! that took way less time than 4 days! THANK YOU!
What's that supposed to mean...I'm an IB student...I know what I'm talking about! :mad: :mad:
Take it easy...Slow down... :-p You'll get yourself a "warning"... :wink: :devil:
Daniel.
sorry... :blushing:
christinono said:
sorry... :blushing:
i didn't mean anything offensive. :frown: if i offended u I am sorry.
what i meant was that this is the standard form of a quadtratic equation:
(ax^2)+bx+c
and that's what i meant with "b", the coefficient in front of x.
but what i was doing was mixing up my coefficients, and i was talking about myself. I am sorry if i offended u. :frown:
So here's my answers for number 3:
width=10
length=20
Area=200
Correct? :smile:
(ax^2)+bx+c
width=10
length=20
Area=200
Correct? :smile:
No hard feelings, I was just kidding :-p
As for your answer for number3, I got:
width=10
length=40
Area=400
Aaahhh crap, what did i do wrong this time??
ok here's my work:
x=width
y=length
A=x(40-2x)
A=40x-(2x^2)
then i used the vertex formula to get x:
-40/(2(-2))
=40/4
=10
then:
y=40-2(10)
=40-20
=20
A=20*10
=200
was that wrong?
  • · Replies 16 ·
