Spin and the violation of the speed of light
The discussion revolves around the concept of electron spin and its implications regarding the violation of the speed of light. Participants explore the nature of spin, its interpretation beyond classical models, and the historical context of the electron as a charged sphere.
  • Exploratory, Technical explanation, Conceptual clarification, Debate/contested
  • Some participants reference a historical model of the electron as a charged sphere, which leads to the implication that its surface velocity would exceed the speed of light if considered to be spinning.
  • Others clarify that electron spin is not a literal rotation but a vector quantity defined by a spin quantum number, challenging the classical interpretation.
  • A participant presents a calculation suggesting that if the electron were treated as a rotating sphere, it would imply a velocity greater than the speed of light, raising questions about the validity of this model.
  • Some participants argue that the problem of speed of light violation remains unresolved, while others contend that the classical model leading to this issue is incorrect, thus negating the problem.
  • There is a discussion about the intrinsic nature of spin angular momentum, which does not involve physical rotation, and how this affects the understanding of electron properties.
Participants express differing views on whether the issue of speed of light violation is still a problem. Some believe it remains unresolved, while others argue that the classical model is flawed and thus the issue is no longer relevant.
The discussion highlights the limitations of classical models in explaining quantum properties and the ongoing challenges in reconciling classical and quantum perspectives on angular momentum.
g.lemaitre
this is from Omnes' book Understanding QM
There was an older preconception according to which the electron was an electrically charged sphere with a radius of the order of 10^-15 m (for which the electrostatic energy is [itex]m_ec^2[/itex]). If spin means a rotation of that sphere, the velocity at the sphere surface would have to be greater than the velocity of light. So accepting the idea of spin meant giving up the only model of the electron and, perhaps worse, the idea that angular momentum accompanies a rotational motion.
Has this problem been resolved or is it still outstanding?
The spin of an electron is not meant in the literal sense (ie like some sort of spinning top or rotating sphere). Instead, it is a vector quantity and we define a spin quantum number.
I believe a sort of rough calculation goes as follows:
[tex]\tau = \frac{dL}{dt} = Iα[/tex]
If we define [itex]L = m_l\hbar = \frac{\hbar}{2}[/itex] and [itex]I = \frac{2}{5}mr^2,[/itex] an electron as a solid sphere with [itex]r ≈ fm[/itex]
Then, [tex]L = Iω = \frac{Iv}{r} => v = \frac{Lr}{I} = \frac{5Lr}{2mr^2}.[/tex]
Simplifying and inputting known data gives v ≈ 1011 ms-1, which is 1000 times the speed of light.
So in other words the problem of the violation of the speed of light has not been resolved, right?
The above calculation assumes that the electron is behaving like a rotating sphere and so it is meant to demonstrate why we should not think of spin as a classical concept here.
well if the electron is not spinning then what is it doing?
Just to be a little clear on the question:
What do you mean by 'what do they do?'
The electron is observed to be pointlike, which means its size, if it has one, is smaller than we have so far been able to detect. (10-16 cm). As a particle, it has a number of properties: mass, charge and angular momentum. Angular momentum comes in two varieties: orbital angular momentum (r x p) and spin angular momentum. There is no motion associated with spin angular momentum, and so the electron does not rotate. The angular momentum it carries (ħ/2) is simply an intrinsic property.
The model (small, rotating sphere) which produced this prediction was wrong. Therefore, it is not a problem any more.
Spin is just another particle property, like its mass and charges (not just the electromagnetic charge).
  • · Replies 21 ·
  • · Replies 24 ·
  • · Replies 39 ·
  • · Replies 45 ·
  • · Replies 58 ·
