Calculating Piston Velocity Using the Law of Cosines
  • Thread starter Thread starter courtrigrad
    Piston
The problem involves calculating the velocity of a piston in an engine using the Law of Cosines, given specific dimensions of the connecting rod and crank, as well as the angular position of the crankshaft.
  • Participants discuss the application of the Law of Cosines to relate the crank angle to the piston height and velocity. There are questions about the use of implicit differentiation in this context.
Some participants have provided guidance on how to set up the relationship between the crank angle and piston height using the Law of Cosines. There is ongoing exploration of the differentiation process and its implications for finding the piston speed.
The original poster expresses uncertainty about the question and the approach to take, indicating a need for clarification on the use of mathematical techniques in this scenario.
courtrigrad
In an engine, a 7-inch connecting rod is fastened to a crank of radius 3 inches. The clankshaft rotates counterclockwise at a constant rate of 200 revolutions per minute. Find the velocity of the piston when [tex]\theta = \frac{\pi}{3}[/tex].
I know that I have to use the Law Of Cosines. However I am unclear about the question.
Any ideas and help are appreciated
Thanks :smile:
any ideas?
The question is asking you to figure out the linear velocity of the piston when the crank has rotated, at constant speed, to the angular position is 60°.
how would you use implicit differentiaition?
would i Have to implicitly differentiate using the law of cosines?
Yes, write the law of cosines relating piston height (measured from the axis of the crankshaft) and crank angle. Then differentiate with respect to time (yes, use implicit differentiation). Plug in the values and solve for the piston speed.
  • · Replies 32 ·
