Electron Drift Speed: Find Current Density & Current in a Gold Wire
The electron drift speed in a gold wire is established at 3.0 * 10^-4 m/s. To calculate the current density (J) and current (I), the formulas J = I/A and I = nqva are utilized. The charge of an electron (q) is 1.6 * 10^-19 C, and the number of free carriers per unit volume (n) for gold is 5.9 * 10^28 m^-3. However, the cross-sectional area (A) of the wire, which is necessary for these calculations, is not provided, preventing the determination of both current density and current.
  • Understanding of electron drift speed in conductors
  • Familiarity with the formulas for current density and current
  • Knowledge of the charge of an electron and free carrier concentration
  • Basic geometry to calculate the cross-sectional area of a wire
  • Calculate the cross-sectional area of a wire given its diameter using A = π(d/2)^2
  • Learn about the relationship between current density and electric fields in conductors
  • Explore the effects of temperature on electron drift speed in metals
  • Investigate the conductivity of different materials compared to gold
Students and professionals in physics and electrical engineering, particularly those focusing on electromagnetism and material properties of conductors.
kyang002
The electron drift speed in a gold wire is 3.0 * 10^-4.
1. What is the current density in the wire?
2. What is the current if the wire diameter is 0.50 mm?
J = I / A
and I = nqva
What is the answer?
J = I / A
and I = nqva
What is the answer?
You get from your formulas that the current density is J = nqv.
You should know the meaning of the letters.
n is the number of free carriers in unit volume. q is the charge of the free carriers and v is their drift speed.
Is anything you do not know from these?
ehild
1. To find the current density in the wire, we can use the formula J = I/A, where J is the current density, I is the current, and A is the cross-sectional area of the wire. We can rearrange the formula to solve for I, which is the current density in this case. So, I = JA. Since we know the electron drift speed in the gold wire is 3.0 * 10^-4, we can substitute this value for v in the formula I = nqva. We also know that the charge of an electron, q, is 1.6 * 10^-19 C, and the number of electrons per unit volume, n, for gold is 5.9 * 10^28 m^-3. Finally, the cross-sectional area of the wire, A, is not given in the question, so we cannot calculate the current density without this information.
2. Similarly, we cannot calculate the current without knowing the cross-sectional area of the wire. The current, I, is equal to the product of the current density, J, and the cross-sectional area, A. So, I = JA. Without knowing the value of A, we cannot solve for I. Therefore, we need to have the cross-sectional area of the gold wire in order to calculate both the current density and the current.
11K
10K
