New Reply
The Sun is very spherical - allegedly
Share Thread Thread Tools
Aug25-12, 05:22 AM   #18
Recognitions:
Gold Membership Gold Member
Quote by Drakkith View Post
Nope. Vega is spinning VERY fast. It spins at 87.6% the speed that would tear it apart.
http://en.wikipedia.org/wiki/Vega#Rotation
How spherical is Vega? Has the spin affected its shape? Does it have much mass around it in the form of a solar system (which could have pinched some of its angular momentum)?
Aug25-12, 06:13 AM   #19
Vega is also a very young star, still surrounded by its proto-stellar cloud of dust and gas. It could be stars have initially high spin which slows over time through interaction with their own nebular disk.
For our Sun, it implies that there is still quite a bit more to learn about whats really going on inside :)
Aug25-12, 10:31 AM   #20
Recognitions:
It is generally believed much of the solar angular momentum is carried off via the solar wind. It is also likely some of it is lost via the accretion process during the protostar phase. Magnetic angular momentum transport is also favored by most models. For discussion see http://farside.ph.utexas.edu/teachin...es/node69.html and http://arxiv.org/abs/0911.1121
Aug25-12, 12:37 PM   #21
Recognitions:
Quote by sophiecentaur View Post
Vegas equatorial radius is about 19% larger than its polar radius. So it is VERY bulgy!
Aug25-12, 03:32 PM   #22
Quote by H2Bro View Post
Planets that experience tidal effects from the Sun's gravitation slowly increase their period of orbit, i.e. get further away. At a further distance they take up more of the systems total angular momentum, thus the Sun slows its spin.
This is true, but I'm near-certain that it's a vanishing contribution.
The characteristic time to tidal lock is, scaled to the Earth-Moon case for convenience, something like
Tlock ~ (10^10 years) / ((T in days) (Ftidal/Ftidal|lunar)^2)
where T is the period of rotation of the body undergoing tidal lock and Ftidal the tidal force exerted upon it. The tidal forces exerted upon the Sun are bound to be dominated by either Venus (close and much more massive than even-closer Mercury) or Jupiter (massivest). For the former case, they're at least five orders of magnitude lower than the lunar force on Earth. For the latter, I have to look at the numbers... *looks at the numbers* ... they're also at least five orders of magnitude lower than the scaling value. So, that gives us at least 10^20 years on top, and (T in days) at the bottom, which isn't going to be far away from 1, relatively speaking. As I suspected, this is not going to amount to anything during the entire solar lifetime.
Aug25-12, 10:26 PM   #23
Ah yes, I was not speaking of tidal locking, which indeed would be vanishing, rather that if one has two bodies in orbit around the sun with both the same velocity the furthest body will have more angular momentum (wrt to the sun) than the closest. Therefore a body maintaining constant velocity but increasing it's semi-major axis would draw angular momentum away from the sun's rotation (insert figure skater reference here). Meaning a planetary body that has viscous surface which is attracted by the sun and exhibits tides - in the normal sense - will slowly drift further out as gravitational energy is consumed moving the viscous liquid against the planet's surface friction (This effect is observed with the moon, which is slowly drifting further from the Earth as it pulls the oceans along whoses movements are resisted by the continents).
This is all fine and dandy except, as I realized shortly after posting, that as a body moves further from the Sun its orbital period increases, something Kepler figured out while most of our families were serfs on someone's manor.
Anecdotally, one can note the trivial effect of tidal locking in Sun-planet systems by considering the degree of tidal drag proportionate to the mass of the effecting body. In the case of Sun-Venus, the gravity of the Sun is notably ineffective considering Venus rotates in completely the opposite direction as the Sun's rotation, indeed opposite to the movement of all the other planets. Speculation within reasonable limits would guess Venus has had this rotation since the earlier and more hectic era of our solar system, which is to say a few billion years.
Aug26-12, 05:27 AM   #24
^ At least one of us is misunderstanding the mechanics involved in tidal locking.
As I understand it, in the familiar Earth-Moon case (considering the Moon only as a source of tidal forces and Earth only as their subject, since the Moon is of course already locked), the Moon creates tides on Earth, and the effect of these tides is to gradually dissipate Earth's rotational energy. Part of it goes into accelerating the Moon, which puts it into a higher orbit, part of it is spend as friction heat et cetera. This will continue until Earth is tidally locked (the tidal bulges have to move relative to surface and/or have varying amplitudes to be able to dissipate energy). Or, rather, it would continue until then, if the timescale didn't exceed the remaining lifetime of the solar system in its present form.
So, yes, you were speaking of tidally locking the Sun when you were speaking of increasing the planets' angular momentum, since those two effects are two sides of the same coin and cannot be separated. If you have a timescale for the one, you have a timescale for the other.
[...] insert figure skater reference here [...]
A figure skater is a solid body, meaning all parts of one have to spin with the same angular speed. If they enlarge the "orbit" of their hands, thus lowering the hands' angular speed below their torso's, the physical link between the two parts (the arms) will transmit torques in both directions, with the result of speeding up the hands and slowing down the torso until the angular speeds are the same once more.
A solar system is gravitationally bound, meaning different parts of one have to spin/orbit with different angular speeds. If something were to enlarge the orbits of its planets, thus lowernig the planets' angular speed per Kepler's laws, there are no arms to transmit a torque to the Sun, so its angular speed wouldn't be affected.
If said something is part of the solar system, then its total angular momentum has to be conserved, just as it is for the figure skater. Other than that, though, the two cases have little in common.
Meaning a planetary body that has viscous surface which is attracted by the sun and exhibits tides - in the normal sense - will slowly drift further out as gravitational energy is consumed moving the viscous liquid against the planet's surface friction.
Tidal forces exerted by the Sun upon a planet (which isn't in tidal lock or resonance yet) dissipate the planet's rotational energy without changing the planet's orbit, as far as I know. There is simply no mechanism to do this. I suppose that if the planet in question is Jupiter, one could consider the Sun's orbit about their common centre of mass in this regard. If the tidal bulge on Jupiter leads or lags, that orbital distance could be affected, and the planet's orbital distance would have to change in turn to compensate. I'm having a bit of trouble fathoming this particular situation, to be honest. Maybe someone else can explain.
Now, tidal forces exerted by a planet upon the Sun (which definitely isn't in tidal lock or resonance yet) dissipate the Sun's rotational energy, and part of that energy can indeed be transferred to the planet's orbit.
That's what I gave you an order-of-magnitude estimate for in the previous post.
It is, but you have to think the analogy through very carefully to draw conclusions about the Sun-planet case: Which body takes the place of which?
Aug27-12, 05:23 PM   #25
Recognitions:
So where does this all take us in the "why is it so damned spherical?" question? Would all stars be the same, do you suppose?
After skimming the latest NAS decadal report on solar/space physics discoveries and problems, I found no reference to this specific question. However, surmising from the regularity with which the term appears throughout their text, they might say "magnetism" plays a prominent role. Since they consider our sun a variable magnetic star, it seems likely that stellar sphericity would vary with magnetism.
Respectfully submitted,
Steve
New Reply
Thread Tools
Similar Threads for: The Sun is very spherical - allegedly
Thread Forum Replies
Potential of spherical and non-spherical mass distributions? Introductory Physics Homework 3
Why does a spherical lens/mirror have spherical aberration. Introductory Physics Homework 2
Non spherical solutions of a spherical potential well? Quantum Physics 1
Vector Spherical harmonics/spherical coordinates question General Physics 0
Since protons are not spherical, are their charge fields non-spherical? Quantum Physics 8
