Finding the General Solution to Inverse Function Equations
The discussion revolves around finding the general solution to the equations f(g(x))=h(x) and g(f(x))=h(x). Participants explore the relationships between the functions f, g, and h, considering specific examples and general forms of h(x) that allow for the existence of g(x). The scope includes theoretical reasoning and mathematical exploration.
  • One participant provides specific examples with f(x)=x+1 and h(x)=x, leading to g(x)=x-1, and explores other forms of h(x) such as h(x)=3x, noting inconsistencies.
  • Another participant suggests making the substitution x = f(z) to explore the relationships further.
  • A later reply expresses frustration with the substitution approach, indicating difficulty in making progress.
  • One participant proposes applying operations and substitutions to derive g-1(x) and suggests that this solution checks out if it exists.
  • Another participant emphasizes that the existence of g(x) depends more on the properties of f than on h, stating that if f has an inverse, then g(x) can be expressed as g(x)=f-1(h(x)).
  • There is a challenge to this claim, with a participant providing a counterexample using f(x)=x^3 and h(x)=2x, arguing that the initial conclusion does not hold under certain conditions.
  • Another participant argues that the conclusion can be reached from the equation f(g(x))=h(x) alone, regardless of the relationship between g(f(x)) and f(g(x)).
Participants express differing views on the relationships between the functions and the conditions under which g(x) exists. There is no consensus on a general solution, and multiple competing perspectives remain throughout the discussion.
Some participants note that the existence of g(x) may depend on specific properties of f, such as having an inverse, and that the relationships between the functions can lead to different conclusions based on the chosen forms of f and h.
StephenPrivitera
What is the general solution to the equations f(g(x))=h(x) and g(f(x))=h(x), or how do you find the particular soltuion to the equations given a function f (given any f what is the general form of h(x) such that g(x) exists)?
My thoughts on the topic:
Specific example:
Suppose we have f(x)=x+1 and h(x)=x. Then g(x)=x-1.
Suppose instead h(x)=x+2. Then,
f(g(x))=g(x)+1=x+2
g(x)=x+1
g(f(x))=x+1+1=x+2 so it checks.
Now suppose h(x)=3x
f(g(x))=g(x)+1=3x
g(x)=3x-1
g(f(x))=3(x+1)-1=3x+2 doesn't check.
More general case:
Suppose now f(x)=x2
f(g(x))=[g(x)]2=h(x)
g(x)=sqrt(h(x))
g(f(x))=[squ]h(x2)=h(x)
So g(x) exists for a given h(x) if
h(x2)=[h(x)]2
I don't think I can solve this any further. I feel resigned to the fact that I must check to see that this holds for some specific h(x) rather than finding the general solution.
Certainly, h(x)=xk works. Any further thoughts?
Edit:
Oh by the way, h(x)=x of course works for all f provided that f has an inverse. So any general form should be able to reduce to h(x)=x.
Mathematics news on Phys.org
Try making the substitution x = f(z)
On the verge of tears... can't make substitution work... must change major...no more hints...
Hrm, while that substitution is interesting, it doesn't seem to help as much as I had hoped...
(it only let's me prove that f, g, and h all commute)
Ok, here's the next suggestion! See if you can apply some interesting operations and substitutions to solve each of the initial two equations formally for g-1(x). I get:
g-1(x) = h-1(f(x)) = f(h-1(x))
and this solution, if it exists, checks out.
With the information given, I doubt you can make a much stronger statement than this.
You are asking "given any f what is the general form of h(x) such that g(x) exists? " (such that f(g(x))= h(x)).
It doesn't depend of h so much as f: If f has an inverse, then
f-1(f(g(x))= f-1(h(x)) so
g(x)= f-1(h(x)).
g(x)= f-1(h(x)).
Your answer doesn't check out. I've come up with several expressions that did something similar. The tricky part is that you have to utilize both f(g(x))=g(f(x)) and f(g(x))=h(x). In your answer you don't utilize the first one.
Choose f(x)=x3, h(x)=2x
f-1(x)=x1/3
g(x)=(2x)1/3
but g(f(x))=x*21/3
(false therefore true) is a true implication.
Note that Ivy's conclusion began with "If f has an inverse".
But f(x)=x3 does have an inverse. In fact I purposely chose this one rahter than
f(x)=x2 for that exact reason.
Say we have f(x)=ex and h(x)=2x. Then g(x)=ln(2x) but g(f(x))=ln(2ex)=ln2+x.
Anyway the point is you can reach Ivy's conclusion from just the fact that f(g(x))=h(x). Simply apply the inverse of f on both sides. But this is true regardless of the fact that g(f(x))=f(g(x)). A solution should be dependent on this fact.
  • · Replies 19 ·
