Finding the Value of m and k to Reach an Average of 7.3
  • Thread starter Thread starter preet
    Average Value
The problem involves determining the values of integers m and k that, when added to a list of integers from 1 to 9, result in an average of 7.3. The original poster has set up the equation based on the average but is unsure how to proceed from that point.
  • Participants discuss the method of cross-multiplying and the implications of the numerator being a whole number. There are mentions of solving systems of equations and the potential for trial and error versus algebraic methods. Some participants suggest graphical methods to visualize the solutions.
The discussion includes various approaches to solving the problem, with some participants expressing confusion about the algebraic method while others assert that a systematic approach can yield results. There is no explicit consensus on the best method, but several productive lines of reasoning are being explored.
Participants note that the solution must yield natural numbers for m and k, and there is a focus on ensuring that the denominator in the average calculation is a multiple of 10 to maintain integer results. The original poster's initial equation and the constraints of the problem are central to the discussion.
preet
The integers from 1 to 9 are listed on a blackboard. If an additional m eights and k nines are added to the list, the average of all of the number is the list is 7.3. The value of k+m is
a)24 b)21 c)11 d)31
I got as far as (45+8m+9k) / (9+m+k) = 7.3
What do I do now?
TiA!
Cross multiply and use the fact that the "old" numerator must be a whole/integer number.That should tell u something about the "old" denominator.
U'll have to solve simple 2-2 algebraic systems...In N.
Daniel.
You mean to say that there is a method for solving this other than trial and error?
AM
I am doing a unit on such systems in math. I do not see a solution that does not involve simplifying the equation you have and solving with the equations the answers suggest and seeing which one works out.
AM
In this case it's a finite sequence of 2-2 systems of (simple) algebraic equations.If you want to call it trial & error,b my guest. :smile: To me those words mean something like "guessing"... :-p It's not the case here.
Daniel.
One way of doing this without guessing is to draw a solution of the equation (in this case: .7m + 1.7k = 20.7) on graph paper (with each graph line representing one unit of k or m). The solution lies where m > 0, k>0 and the line passes through an intersection of vertical and horizontal graph lines (which represent points where m and k are natural numbers).
AM
Sure,Andrew,you're right.Such method would work.But I'm sure the OP's initial idea was to solve this problem by an algebraic method... :wink:
Daniel.
a)24 b)21 c)11 d)31
What do I do now?
TiA!
Well, only four choices. Just enter them into your calc. and see which one is correct. You couldn't get an easier question than this.
That is: Check which answer gives allowable values for m and k.
That's an EVIL answer... :-p 666 posts... :rolleyes:
Daniel.
P.S.You should do something about it,pretty fast... :-p
dextercioby said:
That's an EVIL answer... :-p 666 posts... :rolleyes::
MUHAHAHAHWAHAHAHWHAWHAHWAWAAAAAAAAAAAAAAAAAAAAAAAAAA! :devil: :devil: :devil: :devil: :devil: :devil: :devil: :devil: :devil:
I still don't understand what to do... I don't really care for the calculation method (checking the answers), but I don't know how to do that either. How do I solve it algebraically?
I've already told u.See post #2.Basically,the denominator has to be a multiple of 10,because,when multiplied with 7.3,it would yield a natural number,as the numerator is.So you have to set the denominator equal to 10,20,30,...For each equation,u'll get one for the numerator as well,since the ratio must be 7.3
In this way you generate a series of simple systems 2 (eq.)-2 (unknowns).
Daniel.
I don't think there is a way of doing it algebraically. The solution is the set of values of k,m belonging to the set of natural numbers, that satisfy the relation: 7m + 17k = 207 Algebra will give you the set of all real numbers - ie. all points on the line. The solution is a subset of the points on that line that belong to the set of natural numbers.
The only way I can see of doing it is to draw the relation on paper (with m as the horizontal and k as the vertical axes, say). It is a line with slope k/m = -7/17. If you do it on graph paper, the intersection of the line with the intersection of any of the graph lines, will provide a solution.
AM
AM
What?
1.Denominator 10,numerator 73.System:
[tex]m+k=1;8m+9k=28[/tex]
Doesn't have solution:
2.Denominator 20,numerator 146.Sytem:
[tex]m+k=11;8m+9k=101[/tex]
k=13,m=-2.Doesn't work.
3.Denominator 30,numerator 219.Sytem:
[tex]m+k=21;8m+9k=174[/tex]
k=6;m=15.Does work."21" is a valid solution.
4.Denominator 40,numerator 292.Sytem:
[tex]m+k=31;8m+9k=247[/tex]
Doesn't have solution in N.
If this ain't algebraic solution,then WHAT IS...?
Daniel.
dextercioby said:
What?
I'd call it 'trial and error'.
AM
Your call.I'd call it the most rigurous nongeometric solution one might get.
Daniel.
Thanks for the help
  • · Replies 20 ·
  • · Replies 100 ·
13K
