Torque needed to overcome friction and move object
  • Context: Undergrad
  • Thread starter Thread starter tien87
    Friction Torque
The discussion focuses on calculating the torque required to move an object horizontally when subjected to a force P. The setup involves a horizontal lever connected to a vertical shaft, with the lever either hinged or sliding against the object, which has varying friction coefficients. The torque must account for both the applied force P and the frictional forces present in the different connection scenarios. Understanding these dynamics is crucial for accurately determining the necessary torque in each case.
  • Basic principles of torque and rotational mechanics
  • Understanding of friction coefficients and their impact on motion
  • Knowledge of lever systems and their configurations
  • Familiarity with force diagrams and free-body analysis
  • Study the equations governing torque calculations in mechanical systems
  • Research the effects of different friction coefficients on motion
  • Explore the mechanics of hinged versus sliding connections in lever systems
  • Learn about free-body diagrams to visualize forces acting on objects
Mechanical engineers, physics students, and anyone involved in designing or analyzing systems that require torque calculations for moving objects.
tien87
I need to calculate the torque needed to move an object in horizontal direction. The object is subjected to a force P also in horizontal direction. The general situation is as follows: a (hor.) lever is connected to a (vert.) shaft which will provide the torque. The other end of the lever is connected*to the object. Now, my problem lies in understanding the torque needed to move the object for different types of connection between lever and object. There are 3 situations: connection is a hinge* or there is no fixed connection but the lever can slide against the surface of the object with a high* friction coefficient or very low* coefficient. So, apart from the force P applied to the object, the lever also has to overcome the force due to friction with the object surface or the force on the hinge.
Where does the friction of the object occur?
Can you add a sketch of your setup(s)?
At least for me, the problem is quite unclear.
  • · Replies 21 ·
  • · Replies 37 ·
  • · Replies 52 ·
  • · Replies 32 ·
  • · Replies 52 ·
  • · Replies 60 ·
