Trapping the exact value of the integral
  • Thread starter Thread starter DivGradCurl
    Integral Value
The discussion focuses on the relationship between the Trapezoidal Rule (T_n) and the Midpoint Rule (M_n) for estimating the integral of a positive function f, where f''(x) < 0 for a ≤ x ≤ b. It establishes that T_n < ∫_a^b f(x) dx < M_n, confirming that the Midpoint Rule provides a more accurate approximation than the Trapezoidal Rule under these conditions. The conversation references "Calculus: Concepts and Contexts" by James Stewart, specifically page 419, which illustrates the geometric interpretation of these rules.
  • Understanding of integral calculus
  • Familiarity with numerical integration techniques
  • Knowledge of concavity and its implications on function behavior
  • Ability to interpret mathematical notation and expressions
  • Study the Trapezoidal Rule and Midpoint Rule in detail
  • Explore the implications of concavity on numerical integration
  • Review geometric interpretations of integration techniques
  • Practice deriving bounds for integrals using different numerical methods
Students of calculus, educators teaching numerical methods, and mathematicians interested in the accuracy of integral approximations.
DivGradCurl
If [tex]f[/tex] is a positive function and [tex]f^{\prime \prime}(x) < 0[/tex] for [tex]a\leq x\leq b[/tex], show that
[tex]T_n < \int _a ^b f(x)\: dx < M_n[/tex]
where:
[tex]T_n[/tex] is the Trapezoidal Rule.
[tex]M_n[/tex] is the Midpoint Rule.
In my textbook (Calculus: concepts and contexts / James Stewart. --- 2nd ed. --- page 419), there is a figure with the following caption:
"The area of a typical rectangle in the Midpoint Rule is the same as the trapezoid [tex]ABCD[/tex] whose upper side is tangent to the graph at [tex]P[/tex]. The area of this trapezoid is closer to the area under the graph than is the area of the trapezoid [tex]AQRD[/tex] used in the Trapezoidal Rule."
In other words, provided that the concavity remains the same, we can trap the exact value of the integral between the trapezoidal and midpoint sums for any number of subdivisions.
Maybe, it can be used as the answer. However, I think I'd be better to express that in mathematical terms. So, here's what I've got:
[tex]\frac{h}{2}\left\{ f(a) + 2f(a+h) + 2f(a+2h) + \dots + 2f\left[ a + (n-2)h \right] + 2f\left[ a + (n-1)h \right] + f\left( a + nh \right) \right\}[/tex]​
[tex]<[/tex]​
[tex]\int _a ^b f(x)\: dx[/tex]​
[tex]<[/tex]​
[tex]h \left\{ f\left( a + \frac{h}{2} \right) + f\left( a + \frac{3h}{2} \right) + f\left( a + \frac{5h}{2} \right) + \dots + f\left[ a + \frac{(2n-3)h}{2} \right] + f\left[ a + \frac{(2n-2)h}{2} \right] + f\left[ a + \frac{(2n-1)h}{2} \right] \right\}[/tex]​
which can be written as
[tex]\frac{1}{2} f(a) + f(a+h) + f(a+2h) + \dots + f\left[ a + (n-2)h \right] + f\left[ a + (n-1)h \right] + \frac{1}{2} f\left( a + nh \right)[/tex]​
[tex]<[/tex]​
[tex]<[/tex]​
[tex]f\left( a + \frac{h}{2} \right) + f\left( a + \frac{3h}{2} \right) + f\left( a + \frac{5h}{2} \right) + \dots + f\left[ a + \frac{(2n-3)h}{2} \right] + f\left[ a + \frac{(2n-2)h}{2} \right] + f\left[ a + \frac{(2n-1)h}{2} \right][/tex]​
Am I on the right track? What should I do next?
Any help is highly appreciated.
Hello, I cannot provide much help in terms of getting to the desired result using symbols but I have got the solution for that question. I can post it here or PM it to you if you want. In any case the solution does not necessarily have to be presented symbolically as you have done. The solution my solution manual has is relatively concise. As a hint I think you should draw a diagram, consider a general curve(that is, sketch it on the diagram) and use the fact that f''(x) < 0. This means that the curve is concave down. The diagram on page 419 should help you get started.
Hey Benny, I'm sorry I wasn't able to get back to you sooner. My instant notification by email probably didn't go through. Anyway, it seems that the graph in page 419 along with its caption (found in my 1st post) already give the answer. If you have anything else that I miss, please let me know.
Thanks
  • · Replies 17 ·
  • · Replies 21 ·
  • · Replies 29 ·
