Is it possible to have perfect white or mirrors?
  • Context: Graduate
  • Thread starter Thread starter LastTimelord
    Mirrors
The discussion centers around the possibility of creating a surface that reflects all visible light without absorbing any, and whether such a surface would violate the second law of thermodynamics. Participants explore the complexities of surface reflectivity, the nature of mirrors, and the implications of various physical principles.
  • Some participants propose that a surface reflecting all visible light without absorption is theoretically impossible, suggesting that some absorption of wavelengths is inevitable.
  • Others mention materials like TiO2 and ZnO, which achieve high reflectivity but do not claim perfection.
  • A participant recalls that perfect reflection for one wavelength can be achieved through interference methods, but questions the applicability of this to all wavelengths.
  • There is a suggestion that a perfect mirror would experience recoil from reflected light, potentially leading to a red-shift in the reflected light.
  • Some participants argue that while high reflectivity can be achieved, it may contradict the Kramers-Kronig relations, which link absorption and reflectivity across different wavelengths.
  • One participant mentions that total internal reflection can lead to 100% reflection under specific conditions, but clarifies that this is an average behavior rather than a strict rule.
  • Another participant discusses the limitations of superconductors as reflectors, noting experimental challenges that prevent perfect reflection.
Participants express multiple competing views on the feasibility of perfect reflectivity and the implications of thermodynamic laws. The discussion remains unresolved, with no consensus on the existence of a perfect reflective surface.
Participants highlight the dependence on definitions and the complexities of physical principles such as the Kramers-Kronig relations and Snell's Law. There are unresolved mathematical steps regarding the implications of these principles on reflectivity and absorption.
LastTimelord
Is it possible for a surface that reflects all visible light, and absorbs absolutely none to exist, Or would that violate the second law of thermodynamics?
Science news on Phys.org
I think it's more that the color of a surface is more complicated than the simple model you are using will allow for.
But you will always get some absorption of some wavelengths.
To get something very white - look at TiO2 and ZnO spectra.
Visible light, while only a small part of the electromagnetic spectrum, is still quite a range so I don't see how you could EVER have a material that could reflect all the frequencies perfectly. I think I'm saying the same thing Simon said.
As for a perfect mirror ... good question. I THINK I remember reading that there is some reason it's impossible for any mirror to be perfect, but I don't recall what the rationale for that statement was, and don't know if it's true.
iirc: classically you can get perfect reflection for one wavelength by interference methods - and, then, there is total internal reflection if we call the inner surface a "mirror".
On the scale of photons - all bets are off: there is no such thing as a "surface" the way we are used to thinking of it. See the Feynman QED descriptions of reflection ... you can increase the total reflection from a surface by removing more than half of it.
You could argue that an otherwise perfect mirror would have to recoil under the momentum of the light that it is reflecting and that this would red-shift the reflected light.
Of course not- you also can't fabricate a perfectly flat surface or a frictionless surface. Some real materials (for example, Spectralon and InfraGold) provide >99% reflectivity over a reasonably broad wavelength range:
http://www.pro-lite.co.uk/File/spectralon_material.php
http://www.labsphere.com/products/reflectance-materials-and-coatings/infragold.aspx
Can a black hole send a beam of light back to its source if the beam comes in at the right angle? Without changing the light?
Sure, but from an infinitely narrow crossection, so any real light beam will get at least somewhat scattered.
Superconductors are excellent reflectors for low-frequency photons. But even there, you have some experimental limits - the superconductor material has some border, it might have small hot areas which are not superconducting, and so on.
You specified reflectivity at visible wavelengths. However, your question about thermodynamics implies broader conditions. So I think you were asking if it was possible for a mirror that reflects all the energy from electromagnetic waves completely. I don’t think there are any theoretical limits for such reflectivity restricted to the visible wavelengths. However, I would need to examine the Kramers-Kronig relationship more closely to determine if what you say is true restricted to the visible wavelengths.
The existence of a mirror that reflects 100% of the electromagnetic wave energy from its surface does not contradict any law in thermodynamics. Or at least I haven’t seen any such theorem which says a mirror that completely reflects violates thermodynamics.
However, the existence of such a mirror probably contradicts the Kramers-Kronig relations. The Kramers-Kronig relations relate the spectrum of the index of refraction to the spectrum of the absorption.
According to the Kramers-Kronig relationships, the reflectivity is high when the absorptivity is strong. The converse is not always true. However, there is always a strong absorption somewhere in the frequency spectrum when there is a high reflectivity somewhere in the reflectivity spectrum. You can’t have a high reflectivity without a strong absorption, somewhere.
The indices of refraction of two media at a surface between them determine the reflectivity. In order to reflect 100% over any spectral range, the index of refraction of one of the media has to be infinite. When you apply the Kramers-Kronig relations to such high index of refraction, one would get rather high oscillations in absorption at high frequencies. A high index of refraction over a spectral range implies that the material has a high absorptivity toward the higher frequencies of this range.
I suspect that you are intuiting this type of relationship. So you should look into the Kramers-Kronig relations to see if you are right.
The Kramers-Kronig relations have a physical basis in a property called “macroscopic causality”. However, here are links to introduce you to Kramers-Kronig relations.
http://en.wikipedia.org/wiki/Kramers–Kronig_relations
“The Kramers–Kronig relations are bidirectional mathematical relations, connecting the real and imaginary parts of any complex function that is analytic in the upper half-plane. These relations are often used to calculate the real part from the imaginary part (or vice versa) of response functions in physical systems because causality implies the analyticity condition is satisfied, and conversely, analyticity implies causality of the corresponding physical system.[1] The relation is named in honor of Ralph Kronig[2] and Hendrik Anthony Kramers.”
http://media.wiley.com/product_data/excerpt/26/04700219/0470021926.pdf
“thus. the reflectance is substantial while absorption is strong.”
http://en.wikipedia.org/wiki/Refractive_index
“The real and imaginary parts of the complex refractive index are related through the Kramers–Kronig relations. For example, one can determine a material's full complex refractive index as a function of wavelength from an absorption spectrum of the material.”
I just read an article about "Total internal reflection", and it said something about a light being 100% reflected if it strikes a surface at an angle smaller than the "critical angle". Am I understanding this correctly?
That is correct ... that is what Snell's Law predicts.
However: Snell's Law is only obeyed on average.
  • · Replies 19 ·
  • · Replies 19 ·
  • · Replies 26 ·
  • · Replies 207 ·
16K
