How Do You Solve Cotangent for 4.0527 Radians?
  • Thread starter Thread starter DethRose
    Test Trig
The discussion revolves around a trigonometric problem involving the calculation of cotangent for the angle of 4.0527 radians. Participants express confusion about the question's requirements and the use of calculators for trigonometric functions.
  • Participants discuss the necessity of using a scientific calculator and the definitions of cotangent in relation to sine and cosine. Some question whether the problem can be solved without a calculator, while others explore the conversion of radians to degrees.
The conversation is ongoing, with various participants seeking clarification on the problem and the appropriate tools for solving it. Some guidance has been offered regarding the use of calculators and the relationship between cotangent and tangent, but no consensus has been reached on the best approach to take.
There is mention of potential restrictions on calculator use during tests, which may affect how participants approach the problem. Additionally, some participants express uncertainty about the question's intent and the necessary calculations.
DethRose
trig problem please help test today!
I don't understand what is being asked in these type of questions:
determine the value of cot 4.0527 radians
cot 4.0527=
The're asking you to use a scientific calculator.The one which computes the values of (circular) trigonometric functions.
1.If your computer does not have the function "cotan",then split cotan in sine and cosine according to their definition.
2.If you computer has the function "tan",then use the relation between "tan" & "cotan" to find the result.
Such calculations wannot in general be done "by hand".
Daniel.
i don't get what your saying
I said that u needed a calculator which is able to perform calculations with trigonometrical functions.
Daniel.
cot 4.0527=
I don't quite understand the question
it can be found by using calculator, right?
or you're asking how to find the value without using a calculator or computer?
how do you convert radians to degrees?
Maybe that no.is a nice (like 4\pi/3) multiple of "pi" and the result could be found directly,without a calculator.I didn't bother to check,if it's a test problem,then they're probably not allowed to use such calculators...
Weird,anyway.
Daniel.
IIRC
180°------------------------->[itex]\pi[/itex] radians
x° ---------------------------> 4.0527 radians
Daniel.
i can use a calculator..i just don't understand what the questions asking to be able to use the calculator
Probably.Calculators were invented to spare humans of destructing a large amount of neurons for nonsatisfactory results.So yes,that can be the purpose of an exercise:learning how to handle calculators.
Daniel.
so can you help me out lol
I already did tell you what to do... :-p Check post #2
Daniel.
The problem is asking you to find the cotangent of 4.0527 radians. I can't put it any clearer than that.
I would NOT recommend changing that to degrees. Just be sure your calculator is in "radian" mode. Any calculator that has trig functions has a way to change from degrees to radians and back again. I can't tell you how to do that because I don't know what calculator you have. Either read the manual that came with the calculator (another skill it is good to learn: how to read manuals) or take your calculator to your teacher and ask for help.
I'm editing to add: most calculators do not have a "cotangent" key. cot(x) is defined as 1/tan(x). Find the tangent of 4.0527 radians and then invert it.
ok thanks...my problem was that i wasnt in radian mode lol
cot(x)= 1/tan(x)
  • · Replies 20 ·
  • · Replies 17 ·
  • · Replies 19 ·
  • · Replies 25 ·
  • · Replies 64 ·
