New Reply
Why is copper tubing used to make high q antennas?
Share Thread Thread Tools
Sep3-12, 11:06 AM   #1
My question is just what the title says. Why is copper tubing used instead of normal wire or enameled wire to make antennas and coils at high frequencies? Does it offer less resistance than normal wire?
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Researchers use light projector and single-pixel detectors to create 3-D images
>> GPS solution provides 3-minute tsunami alerts
>> Single-pixel power: Scientists make 3-D images without a camera
Sep3-12, 01:26 PM   #2
rbj
copper has higher conductivity than nearly any other metal than silver (and silver is only marginally better). at high frequencies, there is a lot of "skin effect" where the great majority of the current flows in the outside layer of the conductor and the internal part of the conductor has nearly no current.
but i always thought that these high-frequency antennas were made out of tubular aluminum, because Al is light and, in a tubular shape, it is strong, to stand up to wind, etc.
i don't think copper is used too much, simply because it tarnishes when exposed to air over long periods.
Sep3-12, 02:19 PM   #3
Mentor
Quote by baconman71 View Post
Tubing is mostly used for strength. Like rbj, I haven't seen much in the way of copper tubing used for antennas, except for J-Pole antennas where you need to weld two pieces of tubing together...
Sep3-12, 02:52 PM   #4
I don't think conductivity play much roll in this. Conductivity goes up, skin depth goes down. It all null out particularly the conductivity is not that big a difference between good conductors. Most common rod antenna like rabbit ear are not copper!!! Skin depth is:
[tex]δ_s=\frac 1 { \sqrt{\pi f \mu σ}}[/tex]
Sep3-12, 06:43 PM   #5
Recognitions:
Gold Membership Gold Member
Quote by rbj View Post
and is substantially more expensive than aluminium!!
Berkeman, I do have one copper tube antenna, a 40m band magnetic loop :)
Dave
Sep4-12, 09:16 PM   #6
Recognitions:
Copper tubing is used instead of copper wire because it has a much lower resistance.
Because of skin effect, the resistance of the tubing or wire depends on the surface area of the conductor and tubing has a much greater surface area than wire, for the same length.
Copper is used instead of aluminum where a reliable electrical contact is needed. It can be easily soldered and connected to a feedline where copper conductors are also used.
Aluminum can be soldered with great difficulty and it corrodes rapidly, especially near the sea.
It is lighter and cheaper than copper, though, and is used for TV antennas where periodic replacement due to corrosion is acceptable.
Sep4-12, 09:24 PM   #7
Quote by vk6kro View Post
Agree, particular aluminum is next to impossible to solder. I was told that you have to scrape the surface under oil and solder under oil after scrapping the surface to prevent oxidation of the surface. Tube for the same weight has a lot more surface area than solid wire.
New Reply
Thread Tools
Similar Threads for: Why is copper tubing used to make high q antennas?
Thread Forum Replies
Does anyone make a small high temperature and high pressure pump? General Engineering 0
How to make a water rocket fly high? Introductory Physics Homework 3
Antennas for a High Altitude Balloon Electrical Engineering 11
Make a motor with: AA battery, copper wire, magnet General Physics 1
modulation in high frequencies and antennas Electrical Engineering 5
