| New Reply |
Heat transfer with a plate heat exchanger. |
Share Thread | Thread Tools |
| Sep3-12, 02:17 PM | #1 |
First off, I can't believe I never decided to search for a forum like this, I love smart people! lol.
Anyways I am working on a Liquid cooling project for a highly overclocked computer system. Originally I wasn't going to use a heat exchanger(Matter of fact, until I stumbled across one on a website, I didn't even know they made them for PC applications). So I made a crude diagram to better explain. I am planning on running one side with mineral oil or synthetic motor oil and the other with water/PC coolant. My question is would I use to oils in the initial heat area (south) or in the secondary (north) side? My first plan was to use Isopropyl Alcohol and water/coolant, but with evaporation and not wanting to seal the system I scrapped that idea. Also would I want the heat exchanger before or after the radiator? Where would it be most effective at removing heat? Any thoughts or comments would be much appreciated thank you.
| Sep3-12, 05:15 PM | #2 |
I find myself asking is that really necessary. Damm cool though. Have you done any calcs to see what the required heat transfer is to cool it to the required temperature? Do you know what the maximum temperature it will heat upto? That'll help with determining the fluids required. Good old thermo tables.
| Sep3-12, 05:41 PM | #3 |
At the moment it's all theoretical, necessary? Maybe. When setting records, even the littlest bit helps. Not saying that I'm going for records, but I am doing something that as far as I can tell has never been done. Though it looks like there will be some redundant cooling going on, won't know until I try. "Trial and Error" way of the scientist right? Though this is just a rough diagram, it doesn't show the whole project. All of this and more will be in a cabinet directly cooled with a 6,000 btu air conditioner, a few copper coils for extra cooling, though its not known for its insulating properties the cabinet is going to be made of Acrylic. Only thing that will be in the PC case will be the water blocks and hoses. I want the unit to be stand alone as possible. Should look pretty cool when all said and done.
| Sep6-12, 02:24 AM | #4 |
Can I ask the purpose of the two separate ciruits? Why not just make it one circuit?
| Sep6-12, 08:51 AM | #5 |
I would think you'd be better off with a water chiller (thermoelectric cooler) for the liquid and/or a TEC on the CPU itself. Why are you doubling up on the liquid cooling circuits? If you're worried about the cooling capacity of your "south" radiator, you should get a bigger one, and put big fans on it.
| New Reply |
| Thread Tools | |
Similar Threads for: Heat transfer with a plate heat exchanger.
| Plate heat exchanger design help | Mechanical Engineering | 1 | ||
| Spiral/Plate heat exchanger design help | General Engineering | 0 | ||
| Heat Transfer in a heat exchanger. | Engineering, Comp Sci, & Technology Homework | 9 | ||
| Plate and Frame Heat Exchanger | Materials & Chemical Engineering | 0 | ||
| Is the overall heat transfer coefficient constant for a certain heat exchanger? | Advanced Physics Homework | 0 | ||
