I am asked to find ∫xf(x^2)dx if ∫f(x)dx = 9 ?
  • Thread starter Thread starter LearninDaMath
The problem involves evaluating the integral ∫xf(x^2)dx over the interval from -4 to 0, given that the integral ∫f(x)dx from 0 to 16 equals 9. Participants are exploring the relationship between these integrals and the implications of a substitution method.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster expresses uncertainty about how to start the problem and questions the relevance of the given integral of f(x). A participant suggests using a u substitution with u = x^2 to transform the integral. Another participant reflects on the implications of the limits of integration and the structure of the problem.
The discussion is active, with participants providing hints and exploring the implications of the substitution method. There is recognition of the specific structure of the problem, but no consensus on a final solution has been reached.
Participants note that the relationship between the limits of integration in the original problem and the given integral may be crucial for finding a solution. There is also mention of potential difficulties if the functions or limits were different.
LearninDaMath
Find [tex]\int_{-4}^0 xf(x^2) \, dx[/tex] if [tex]\int_0^{16} f(x) \, dt =9[/tex]
[tex]\int_{-4}^0 xf(x^2) \, dx = ?[/tex]
Are there any? All I know is that [tex]\int_0^{16} f(x) \, dt = F(16) - F(0) = 9[/tex], but does that property come into use for this problem?
I do not know how to begin this problem.
Hint: Try the u substitution ##u=x^2## in$$
\int_{-4}^0 xf(x^2) \, dx$$Don't forget to take the limits through the substitution too.
letting [itex]u = x^{2}[/itex] [itex]\frac{du}{2}=xdx[/itex]
[tex]\int_{-4}^0 xf(x^2) \, dx[/tex] => [tex]\frac{1}{2} \int_{-4}^0 f(u) \, du[/tex][tex]- \frac{1}{2} \int_0^{16}f(u) \, dx = - \frac{9}{2}[/tex]Wow, for the problem to work out the way it did is mindblowingly coincidental. For the first integral's upper and lower limits to match the second integral's limits, the relationship between the the u substitute and the upper and lower limits had to be deliberately structured. So if I wanted the final result to be 9 instead of -9/2, the evaluated integral would have to become:
[tex]\int_0^4 2xf(x^2) \, dx[/tex] = [tex]\int_0^{16} f(u) \, du = 9[/tex]
So there is really not evaluating occurring, just getting the first integral to match the second integral. So if I'm not mistaken, if the limit values in the first integral could not be made to perfectly match the second integral then finding a value for this problem would be rendered impossible. And on the same note, if the function in the first integral was such that after substitution yielded a differing function, say ∫(u^2)f(u)du, then the problem would also be rendered impossible.
Thanks for the boost on this problem LCKurtz. Are my conclusions about this problem on track here?
Yes, you have it. The problem was cooked up to work just right and give you practice with the u substitution. Remember whenever you express an integral with du you must also use the u limits.
  • · Replies 105 ·
13K
  • · Replies 23 ·
