Register to reply
2-D Kinematics: Distance of Rocket from Launch Pad
Share this thread:
JohnSwine
#1
Sep4-12, 10:39 PM
P: 2
A model rocket is launched from rest with an upward acceleration of 6.00m/s^2 and, due to a strong wind, a horizontal acceleration of 1.50m/s^2. How far is the rocket from the launch pad 6.00s later when the rocket engine runs out of fuel?
2. Relevant equations
Not sure..
3. The attempt at a solution
I've been trying to figure this out, and I'm still not sure how to approach it.
Phys.Org News Partner Science news on Phys.org
Experts defend operational earthquake forecasting, counter critiques
EU urged to convert TV frequencies to mobile broadband
Sierra Nevada freshwater runoff could drop 26 percent by 2100
azizlwl
#2
Sep4-12, 11:07 PM
P: 963
Sketch a velocity vs. time graph.
You will see that from zero the velocity increases with the rate 6(m/s)/s for 6 secs.
Then it slows down to with rate of g untl zero velocity where it is at the top of the flight
Next it will continue with negative velocity(acceleration g) until it reaches the ground.
The net total area is equal to zero.
The horizontal vector remains constant.
Taking total flight time, you can multiply this to horizontal velocity to find the answer.
ehild
#3
Sep4-12, 11:28 PM
HW Helper
Thanks
P: 10,673
Quote Quote by JohnSwine View Post
Not sure..
You certainly know that you can describe the motion of a rocket as if it moved independently both in horizontal (x) and vertical (y) direction. Both motion happens with uniform acceleration. You certainly learnt how the displacement changes with time during a motion with uniform acceleration? write up the equations both for x and y directions.
ehild
Register to reply
Related Discussions
Calculating the launch speed from a launch angle, distance, and air density Calculus 1
Rocket Launch Introductory Physics Homework 1
The Multiple Launch Rocket System and Rocket Noises General Physics 1
Distance a rocket travels on a launch ramp Introductory Physics Homework 1
Rocket Launch HELP Introductory Physics Homework 1
