Determine the # of solutions to the equation
  • Context: Undergrad
  • Thread starter Thread starter hamface
The discussion revolves around determining the number of solutions to the equation sin(ax) = b within the domain 0 ≤ x ≤ 2π, where a is a positive integer and b is a real number. Participants explore various cases based on different values of a and b, including specific examples provided in the initial post.
  • One participant outlines specific solutions for various values of a and b, noting the solutions for sin(x) = 0, sin(2x) = 0.2, and others.
  • Another participant questions the clarity of the problem, particularly regarding whether a and b are constants or variables, and points out that 0.5 is not a positive integer.
  • A different participant suggests that if b < -1 or b > 1, there are no solutions, and discusses the number of solutions based on the value of b when a = 1.
  • It is proposed that for a > 1, the number of solutions increases with each additional trip around the unit circle, but the case for b = 0 is noted as particularly tricky.
  • One participant introduces a calculus approach using the Maclaurin series to approximate sine values, although this seems somewhat tangential to the main question of the number of solutions.
Participants express differing views on the interpretation of the problem, particularly regarding the nature of a and b, and the conditions under which solutions exist. There is no consensus on the number of solutions or the approach to take, indicating that multiple competing views remain.
Some participants highlight limitations in the problem's formulation, such as the ambiguity regarding whether a and b are constants or variables, and the implications of the domain restrictions on the solutions found.
hamface
THE QUESTION:
determine the # of solutions to the equation...
sinax=b
for the domain 0 (less than or equal to) x (less than or equal to) 2pi, for the values of a. a is a pos. integer and b is a real #.
Then it gives examples:
value of a ... value of b
...1 ... ... 0
... 2 ... ... 0.2
...3 ... ... -0.2
... 4 ... ... 1
...0.5 ... ... 0.5
... 1 ... ... 2
MY ANSWER:
sin (ax) = b
From a = 1 and b = 0:
sin x = 0
x = {0, pi, 2(pi)}
From a = 2 and b = 0.2:
sin (2x) = 0.2
2x = approximately {0.2014, 2.9402, 6.4845, 9.2234}
x = approximately {0.1007, 1.4701, 3.2423, 4.6117}
From a = 3 and b = -0.2:
sin (3x) = -0.2
3x = approximately {3.3430, 6.0818, 9.6261, 12.3650, 15.9093, 18.6482}
x = approximately {1.1143, 2.0273, 3.2087, 4.1217, 5.3031, 6.2161}
From a = 4 and b = 1:
sin (4x) = 1
4x = {(1/2)(pi), (5/2)(pi), (9/2)(pi), (13/2)(pi)}
x = {(1/8)(pi), (5/8)(pi), (9/8)(pi), (13/8)(pi)}
...But I am not sure how to explain what I did out. And also, I didn't do the last two options, because they messed me up.
Can anyone help?
I need help.
Originally posted by hamface
THE for the values of a. a is a pos. integer and b is a real #.
...1 ... ... 0
... 2 ... ... 0.2
...3 ... ... -0.2
... 4 ... ... 1
...0.5 ... ... 0.5
... 1 ... ... 2
0.5 isn't an integer.
Besides I don't understand the question. Are a and b constant? If not, then of course there are either 1 or 2 solutions for any pair of a and b. But from the examples above, it appears that a and b are not constant. In which case, what do you mean by number of solutions? Do you mean the number of pairs of a,b such that the equality holds for some x between 0 and 2pi? Do you mean the number of x values that saitify the equation for at least one a,b pair?
Also,
___
sin (4x) = 1
___
5/2(pi) is not in the domain. Nor is 13/2(pi). You said 0<x<2pi or x=0 or x=2pi
You need to consider a lot of different cases:
If b < -1 or b > 1, there are no solutions regardless of the value of a.
For other possible values of b, first figure out the number of solutions for sin x = b (a = 1).
There are 3 possible cases to consider:
If b = -1 or 1, then there is only one solution to this equation.
If 0 < b < 1 or -1 < b < 0, there are 2 possible solutions to this equation.
If b = 0, there are 3 solutions.
For a > 1, if x is to be between 0 and 2Pi inclusive then ax must be between 0 and 2aPi inclusive. I visualize solutions to this sort of equation as angles in standard position that intersect the unit circle. (The angles can be graphed in the x-y plane with the vertex as the origin and the initial side along the positive x-axis). For x between 0 and 2Pi this amounts to making one complete "trip around the circle" and finding all possible solutions. Thus, each time a is increased by 1, there will be additional solutions to the equation -- "for every trip around the circle" there will be angles co-terminal to the solutions already found that are also solutions to the equation. I think you are being asked to generalize this for any integer value of a. The trickiest case is that for b = 0 since 1 additional "trip around the circle" will only yield 2 new solutions -- not 3.
Hope this helps.
for any sine,cosine of a constant number ( like 6, 7, 9, 3.7) we can use calculus...we can use the Malcaurin series ...as follows...
example1)- what is the sin of (.4)?
ans cos(x)=1-x^2/2! + x^4/4!...and then we the the tangent can be expressed as tan=sin/cos=x-x^3/3!+x^5/5!-.../ 1-x^2!+x^4/4-...=x+1/3x^3=2/15x^5+...
hence, sin(x)=x-x^/3!+x^5/5!-x^7/7!+...(-1)^n-1 x^2n-1 /(2n-1)+...since this is a infinity series we let ... go on..
now since it goes on forever, i want to find the fifth degree of the malaurin series,...hence, P5 of x (not times x)= x-X63/3!+x^5/5!= ( since this is a limited function of the maclaurin series, we don't need a ...) f(x)=f(.4)=P5(.4)=.4-(.4)^3/3!+.4^5/5!=.378352
(note) ain(x)=x-x^3/3!+x^5/5!-x^7/7!+...=sigma ^infinity n=0 (-1)^2 x^2x+1/(2n+1)! since the interval is infinity, sigma must have an infinity...
  • · Replies 52 ·
10K
