Ball and Bowl and Newton's Second Law
The discussion centers on calculating the kinetic energy (KE) of a sphere rolling down a hemispherical bowl using Newton's Second Law and conservation of energy principles. The participants detail the application of Newton's Second Law, where the net force acting on the sphere is derived as -mg sin(theta), leading to the equation (1/2)w² = (g/R) cos(theta). At the bottom of the bowl, this results in a kinetic energy of KE = mgR. Additionally, the conservation of energy approach confirms this result by equating potential energy at the top with kinetic energy at the bottom, reinforcing the relationship between these two fundamental physics concepts.
  • Understanding of Newton's Second Law and its mathematical formulation.
  • Familiarity with concepts of kinetic and potential energy.
  • Basic knowledge of angular motion and the relationship between linear and angular velocity.
  • Ability to perform integration and apply the chain rule in calculus.
  • Study the derivation of kinetic energy from Newton's Second Law in various contexts.
  • Explore the principles of conservation of energy in mechanical systems.
  • Learn about angular momentum and its relationship with rotational motion.
  • Investigate the effects of friction on rolling motion and energy conservation.
Students of physics, educators teaching mechanics, and anyone interested in the applications of Newton's laws and energy conservation in real-world scenarios.
RIT_Rich
Hello everyone.
I'm having a little trouble understanding the whole "ball and bowl" problem using Newton's Second Law. What I'm talking about involves a small shpere of mass m and radius r, rolling down a "bowl" (more like a hemisphere of radius R). How would one go about finding the KE of the sphere at the bottom of the hemisphere using Newton's Second Law?
Thanks a lot
Science news on Phys.org
Do you really have to use Newton's second law? If I were doing a problem like this, I would use "conservation of energy".
Newton's law says "force is the rate of change of momentum" (which can actually be taken as a definition of force). In the simple case of constant mass, this is "force= mass times acceleration" or
m dv/dt= F.
Model the cross section of the bowl that includes the ball, as it is rolling down, as a circle of radius R. Let theta be the angle formed by the line from the ball to the center of the circle and then to the bottom of the circle. The gravitational force on the ball is -mg, straight down. The ball does not move straight down because the bowl is applying a force toward its center. The net force is tangent to the bowl. Dividing the gravitational force into components parallel and perpendicular to the tangent we see that the angle between perpendicular and vertical lines is also theta. The net force, tangent to the circle, is -mg sin(theta).
Newton's second law now says m dv/dt= -mg sin(theta) (v is the speed along the circumference of the circle). If we measure theta in radians, then the arclength is given by s= Rtheta so
v= ds/dt= R d theta/dt. Newton's second law is now:
R d2theta/dt20= -g sin(theta).
If we let w= dtheta/dt (the angular velocity), then d2theta/dt2= dw/dt. Using the chain rule, dw/dt= dtheta/dt dw/dtheta= w dw/dtheta. Now the equation is R w dw/dtheta= -g sin(theta). We can rewrite this as w dw= -(g/R) sin(theta) dtheta and integrate. That gives (1/2)w2= (g/R) cos(theta)+ C.
At the top of the bowl theta= pi/2 and cos(pi/2)= 0. Also, since the ball started from rest, w= 0 so we have 0= 0+ C or C= 0.
Our equation is (1/2)w2= (g/R) cos(theta).
At the bottom of the bowl, theta= 0 and cos(0)= 1. Therefore,
(1/2)w2= g/R.
We were asked for kinetic energy at the bottom of the bowl. That is (1/2)m v2= (1/2)(Rw)2= R2((1/2)w2)= R2(g/R)= gR.
That's your answer.
Using "conservation of energy", we would have argued that at the top of the bowl, v is 0 and the height is R so the potential energy (relative to the bottom of the bowl) is mgR and the total energy is 0+ mgR= mgR. At the bottom of the bowl, the potential energy is 0 so the kinetic energy must be mgR in order to keep total energy the same. It's that easy!
Actually, if you look at the integral of the equation resulting form Newton's second law, you will see that that IS conservation of energy. If the force, F, depends only on position: F(x), it is a "conservative" force. Newton's second law is m dv/dt= F(x). Again, we can use the chain rule to write this as m v dv/dx= F(x) and rewrite that as m v dv= F(x) dx. Integrating, (1/2)mv2= integral(F(x)dx)+ C or (1/2)mv2- integral(F(x)dx)= C.
The first part of that is kinetic energy. The (negative) integral is the work done against the force: the potential energy. That just says that the total energy is a constant: conservation of energy.
Thanks. Thats the answer I got as well. I just needed to know because it got marked wrong on a webassign HW. I probably just didn't write it the right way...but it had to be right.
Thanks
  • · Replies 20 ·
  • · Replies 31 ·
10K
