Solving Particle Mechanics Equation: V(x)=-A|x|^(n)
  • Thread starter Thread starter Cognizant
    Mechanics
The discussion centers on the particle mechanics equation V(x) = -A|x|^(n), where A is a positive constant and n represents the power of the position variable x. The problem posed is to determine the values of n for which a particle, influenced by this potential, reaches x = 0 in finite time. The solution involves equating kinetic energy (KE) to energy (E) minus potential (V), leading to the differential equation that describes the particle's motion over time. The key takeaway is that understanding the constants A and n is crucial for solving the mechanics problem effectively.
  • Understanding of basic mechanics concepts, including kinetic energy and potential energy.
  • Familiarity with differential equations and their applications in physics.
  • Knowledge of the significance of constants in mathematical modeling.
  • Basic grasp of particle motion and forces acting on particles.
  • Study the derivation of kinetic energy and potential energy equations in classical mechanics.
  • Learn how to solve differential equations related to motion, particularly in physics contexts.
  • Research the physical significance of power laws in potential energy functions.
  • Explore examples of real-world systems that can be modeled using similar potential functions.
Students of mechanics, physics enthusiasts, and anyone interested in understanding the dynamics of particles under potential influences.
Cognizant
I'm attempting to understand an issue that a mechanics student is having, and I was wondering if someone could break down this particle mechanics equation for me so I know where it fits in:
V(x)=-A|x|^(n)
The exact problem that they are dealing with is:
A particle moves towards [x = 0] under the influence of a potential V( x ) = -A|x|^(n) (assume n > 0). The particle has barely enough energy to reach x = 0. For what values of n will it reach x = 0 in a finite time?
Precisely, I need to know what values A, x, and n are supposed to represent. I'm not specifically a mechanics student, but these sort of things always spark my interest in a self-teaching direction.
A is a (positive) constant, which is just there to show this is an abstract, generalized problem; in a real world situation you would experimentally determine constants like A so you could make actual numerical predictions. When you ask what n means, I assume you know about powers, and are asking for its physical significance? If so, there are some real potentials that can be approximated by certain powers of x, but in this case it's probably just a textbook problem; for practice, nothing more. And x is the position of the particle.
To solve the problem, you would equate KE=E-V. Since it will just barely pass, I assume E=0, so KE=A|x|^n. Then use KE=1/2 m v^2, where v = dx/dt, and solve the resulting differential equation to get x(t), which can then be inspected to see if it crosses 0 in a finite time.
You are correct. I understand the basic mathematical principles, but since I'm not familiar with these types of physics, I was not sure if the A and n were arbitrary (I had assumed x is a variable in this case, and representative of some aspect of the particle, but was not clear on which), or if they were a significant constant. V(x), as I would understand it, is simply the calculated potential of the particle in x position.
[tex]KE = \frac {1}{2}m (\frac {dx}{dt})^2[/tex]
I'll work with it a bit, and see what I can come up with. Thanks for the starting point! :)
  • · Replies 21 ·
