New Reply
Civil Engineering: Hydrogeology, Height of a Perched Aquifer Water Table
Share Thread Thread Tools
Sep10-12, 05:22 PM   #1
Heavy infiltration (due to excess irrigation) of 3 cm/d causes a perched water table to form above a low permeable, flow-restricting layer. The top of the restricting layer is at a depth of 2 m, it is 0.4 m thick, and it has a K_v of 0.01 m/day. The material above the restricting layer is a silt loam with a K_v of 0.12 m/day. Coarse sand and gravel occurs below the restricting layer. After flowing through the restricting layer, the water moves as unsaturated flow through the sand and gravel to an unconfined aquifer. What is the height of the perched water table above the top of the restricting layer?
2. Relevant equations
q= constant for all layers
q = K * I = K * (dh/dL)
3. The attempt at a solution
Because of the vertical layering and conservation of mass, the q (unit flow) through each layer should be the same. I tried the following:
q = 0.03 m/day = (0.12)(dh1/dL1) = (0.01)(dh2/0.4)
my goal, I believe is to solve for dL1 (labeled as L in the attached picture). But it appears I have too many unknowns or I am missing some fundamental concept.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
New Reply
Thread Tools
Similar Threads for: Civil Engineering: Hydrogeology, Height of a Perched Aquifer Water Table
Thread Forum Replies
Mechanical Engineering vs Civil Engineering Major? Academic Guidance 4
Bachelors in Civil Engineering then Masters in Mechanical Engineering Career Guidance 0
mechanical engineering graduate transferring to civil engineering Academic Guidance 1
Civil Engineering/Power Engineering combination question Academic Guidance 20
Civil Engineering with specialization in aviation or Aerospace Engineering Academic Guidance 1
