Identifying parallel elements in a circuit
by Pi Face
Tags: circuit, elements, identifying, parallel
Pi Face
Pi Face is offline
#1
Sep12-12, 11:16 AM
P: 75
In the following circuit, a) identify all combinations of 2 or more circuit elements that are connected in series and b) Identify pairs of circuit elements that are connected in parallel.
http://imgur.com/keorO
a) Seems easy enough, the 4 and 6 ohm resistors are in series, and so are the 5 ohm resistor with the 20 V volate source. Did I miss any?
b) Here the question says "Identify pairs" not "all pairs" so I'm not sure if I have to find all of them...aren't there a lot? I think I'm having trouble finding every last parallel pair. This is what I have so far.
1 ohm is in parallel with 2 ohm
4 ohm "" 5 ohm
4 ohm "" 20 V
6 ohm "" 5 ohm
6 ohm "" 20 V
3 ohm "" 5 ohm
3 ohm "" 20 V
1 ohm "" 3 ohm (?)
2 ohm "" 3 ohm (?)
I feel like I have too many or too little pairs...
SIDE QUESTION:
In a circular circuit where all the elements are connected in a single loop, are the elements in series or in parallel?
Phys.Org News Partner Science news on Phys.org
Going nuts? Turkey looks to pistachios to heat new eco-city
Space-tested fluid flow concept advances infectious disease diagnoses
SpaceX launches supplies to space station (Update)
gneill
gneill is offline
#2
Sep12-12, 11:29 AM
Mentor
P: 11,416
Parallel components have leads that share exactly two nodes.
Serial components have leads that exclusively share exactly one node (no other connections by other components to that node).
Not every pair that you've identified are in parallel.
Pi Face
Pi Face is offline
#3
Sep12-12, 11:32 AM
P: 75
Quote Quote by gneill View Post
So say we have a square circuit, with one resistor on the top and 3 resistors in series on the bottom (nothing on left and right)
Only the outer 2 of the 3 bottom resistors would be parallel with the top? Not the middle one?
edit:
also, going by what you said my answer for series seems to be correct, but only the 1 and 2 ohm resistors are in parallel?
gneill
gneill is offline
#4
Sep12-12, 11:48 AM
Mentor
P: 11,416
Quote Quote by Pi Face View Post
You mean like this:
There are NO resistors in parallel in this circuit; no two resistors share exactly two nodes. That is, you must have one lead from each component connected together at one node, while the other leads of the two components connect together at another (separate) node.
edit:
Yes, that;s good.
Pi Face
Pi Face is offline
#5
Sep12-12, 11:52 AM
P: 75
Okay I see, thank you very much for clarifying that for me.
Register to reply
Related Discussions
Maxwell elements in parallel Advanced Physics Homework 0
Simplifying and identifying parallel circuits Introductory Physics Homework 14
A circuit of four elements. Which are in series and which are in parallel? Introductory Physics Homework 2
identifying elements in V(x)W, V,W V.Spaces Linear & Abstract Algebra 4
Identifying Unknowns in a circuit Introductory Physics Homework 1
