Proof: Number of different subsets of A is equal to 2^n?
by SMA_01
Tags: equal, number, proof, subsets
SMA_01
SMA_01 is offline
#1
Sep12-12, 10:49 PM
P: 218
Prove that if a set a contains n elements, then the number of different subsets of A is equal to 2n.
3. The attempt at a solution
I know how to prove with just combinatorics, where to construct a subset, each element is either in the set or not, leading to 2n subsets. I want to know how to prove it with mathematical induction though. How would I start?
I figured this using summation notation:
[itex]\sum^{k=0}_{n}[/itex] (n k)=2n
Phys.Org News Partner Science news on Phys.org
Better thermal-imaging lens from waste sulfur
Hackathon team's GoogolPlex gives Siri extra powers
Bright points in Sun's atmosphere mark patterns deep in its interior
LCKurtz
LCKurtz is online now
#2
Sep12-12, 11:03 PM
HW Helper
Thanks
PF Gold
LCKurtz's Avatar
P: 7,189
Quote Quote by SMA_01 View Post
So the proposition you want to prove is that the number of subsets of a set with n elements is ##2^n##. Start with ##n=1## A set with a single element, call it ##S_1 = \{a\}## has two subsets: ##\{a\}, \Phi## which is ##2^1##. Now you need to prove the induction step: Assume a set with ##k## elements has ##2^k## subsets and use that to show a set with ##k+1## elements has ##2^{k+1}## subsets. That's how you start. It's easy and you don't need binomial coefficients to do it.
SMA_01
SMA_01 is offline
#3
Sep13-12, 09:13 AM
P: 218
Thank you. The part with k+1 elements is confusing me. I went through a long process of trying to make one side equal to the other, and it's not really working.
LCKurtz
#4
Sep13-12, 11:29 AM
HW Helper
Thanks
PF Gold
LCKurtz's Avatar
P: 7,189
If you start with a set with ##k## elements and ##2^k##subsets, and add another element, all the subsets of the original set are subsets of the larger set. What additional subsets are there?
SMA_01
SMA_01 is offline
#5
Sep13-12, 05:46 PM
P: 218
The additional subsets will be the ones formed using the new element? As if this new element is either in the subsets or not...
LCKurtz
#6
Sep13-12, 06:57 PM
HW Helper
Thanks
PF Gold
LCKurtz's Avatar
P: 7,189
Quote Quote by LCKurtz View Post
Yes, so.....?
SMA_01
SMA_01 is offline
#7
Sep13-12, 11:11 PM
P: 218
So, 2*2^k=2^(k+1), is that right?
LCKurtz
#8
Sep14-12, 11:32 AM
HW Helper
Thanks
PF Gold
LCKurtz's Avatar
P: 7,189
Are you asking me if ##2\cdot 2^k = 2^{k+1}##? Of course, you know it does. Do you understand how to put this all together to make a well written induction proof of your theorem?
SMA_01
SMA_01 is offline
#9
Sep15-12, 10:51 AM
P: 218
Yes, thank you. I just thought I would have to go through the long, tedious process of proving both sides are equal using the summation formula. Thanks for all your help
Register to reply
Related Discussions
subsets of a set such that no two have two equal elements Calculus & Beyond Homework 0
Number of even/odd subsets. Set Theory, Logic, Probability, Statistics 2
The intersection of an empty collection of subsets of X is equal to X? Set Theory, Logic, Probability, Statistics 2
Proof that 1/2 +2/3 + 3/4...does not equal a whole number Linear & Abstract Algebra 22
The Number Of Proper Subsets is 2^n - 1 Introductory Physics Homework 9
