Infinity: Square of Infinity + 2 Infinity
  • Thread starter Thread starter chound
    Infinity
The discussion centers around the mathematical concept of infinity, exploring its properties and implications in various operations such as addition and multiplication. Participants engage with theoretical aspects, conceptual clarifications, and some informal reasoning regarding infinity in relation to numbers and mathematical operations.
  • Some participants propose that infinity plus infinity equals either 2 infinity or simply infinity, drawing parallels to finite numbers.
  • One participant discusses the idea that infinity multiplied by infinity results in the square of infinity, but later suggests that it remains infinite.
  • A participant raises a question about the operation of infinity minus infinity, expressing confusion about its implications.
  • Another participant introduces the concept of different "degrees" of infinity, suggesting that infinity is a proper subset of infinity plus infinity.
  • Several participants emphasize that infinity is not a number but a mathematical concept, which complicates its use in arithmetic operations.
  • There is mention of the extended reals and how they relate to infinity, noting that while operations can be extended to include infinite values, they should not be treated as standard arithmetic.
  • Some participants engage in playful mathematical reasoning, presenting paradoxes and humorous observations about division by zero and infinity.
Participants express a range of views on the properties of infinity, with no consensus reached on the operations involving infinity. Some agree on the conceptual nature of infinity, while others contest specific arithmetic interpretations.
Limitations include the ambiguity surrounding the definition of infinity in mathematical operations, as well as the unresolved nature of certain mathematical steps and assumptions made by participants.
This discussion may be of interest to those exploring foundational concepts in mathematics, particularly in relation to infinity, as well as students grappling with the implications of mathematical operations involving infinite quantities.
chound
x + x = 2x
infinity + infinity = 2 infinity (or) infinity
x-x=0
infinity * infinity = square of infinity (or) infinity
:-p :devil: :blushing: :approve:
0 + 0 = 0.
Absolute nothingness + This thread = ...
have though a lot about zeros and infinities... not a very high level maybe, but hey, I'm just 17...:)
about infinity + infinity = 2*infinity ?
see it like this.. in a 1cm line, there are infinite many points ...
in a 2cm line there is also infinite many points...
so if you have 2 1cm lines they will have infinite+infinite points, which is also infinite as the 2cm line also had infinite many points...
hope I wasnt confusing...
and infinity * infinity = square of infinity ?
you have a line of any length with infinite many points.. say 1cm again
if you have four lines forming a square with, then, the area of 1cm^2 you will have infinite many points in the area...
so the lines of infinite many points, make a square with infinite * infinite many points in the square, which as said earlier his infinite..
so infinity * infinity = infinity..
I have some problem with infinity - infinity though...
I have infiinity... I add another infinity and get.. infinity.. so If i subtract infinity now, I should get ack to my original number or?
so x+x-x = x or??
in case of infinty we get
x+x-x != x
weird.. but however.. its interesting stuf... have some other stuff i have thought of.. will post it another time...
since infinity is a proper subset of infinity+infinity, they can be put in one-to-one correspondence to each other, and are then the same "degree" of infinity, am I right?
Head... hurting... :cry:
None of this makes any sense until you adopt some definitions... and then once you have, it's clear how things work.
Infinity is not a number, it is a mathematical concept. The reason it isn't a number is because for ever number at 'infinity' there is always a number that is greater than it. It doesn't make very much sense to use the concept of infinity as a mathematical operator.
Limits are the best way to show this correlation. If something is unbounded then it is useless to try to find a maximum number for Infinity.
x=.9999999...
10x=9.999999....
10x-x=9x=9.000000000000
x=1 thus 1=.99999999.....
1/3=.33333...
3(1/3)=3(.333333...)
1=.999999999999999...
also how about this one:
construct a right triangle, say a triangle with sides=1 and with hypotenuse sqrt(2). obviously sqrt(2)>1, how then can all the points on the side that has length of sqrt(2) be matched to all the points on the line that has length 1 like shown in the picture? this problem mystified Leibniz
sorry, gravenewworld bu t i didnt umderstand...
I believe he tried to illustrate that a line twice as long can be projected down on the first line as if two sides of a triangle, and you can match up each point on one line to each one on the other... therefore, they must have equal number of points?
Precisely kerbox
[tex]\mathbb{Z} \subset \mathbb{R}[/tex], no ?
2x-x=0
2x=x
2=1 ?
-1=0 ?
How about them mathimatics! :approve:
derekmohammed said:
2x-x=0
2x=x
2=1 ?
-1=0 ?
sorry to ruin your fun but your example doesn't work.. :biggrin: :-p
2x=x is ONLY true for 0 and infinity...
so when you have 2x=x and divide by x to get 2=1,
you actually divide by 0 or infinity. And as divison by 0 and infinity is undefined your conclusion is invalid...:)
just rememebered a quote by J.Baylock...
"If you want someone to hate you, explain to them, logically and politely, why they are wrong"
a funny thing of division of 0's can be demonstrated in this way (thought it myself, but someone else may have done it)
0*0=0
divide by 0 at both sides and you get
0=0/0
so is 0/0 equal to 0?
nonono :-p
1*0=0
1=0/0
hihi
:smile:
2*0=0
2=0/0
hihi
:smile:
3*0=0
3=0/0
hihi
:smile:
can cnotinue as long as I want... (or maybe not til infinity..) :biggrin:
chound said:
x + x = 2x
x-x=0
I was referring to this... They give nonsence I give nonsence! :smile:
derekmohammed said:
2x-x=0
2x=x
2=1 ?
-1=0 ?
I prefer to think of it like this:
ax=x => a=1 or x=0 or x=infinity.
so 2x=x => a=2 => x=0 or x=infinity.
However, there is no number called "infinity", so "x = 0 or x = infinity" is equivalent to "x = 0"!
Infinity
chound said:
x + x = 2x
x-x=0
Infinity is not a number.
Dirac.
Does x always have to be a number in maths?
You are using operations like multiplication and addition which are only defined on a set of numbers.
I think someone posted something about "extended reals" somewhere but I can't find the link and I got no matches on my web search. Can you tell me anything about that, or is it bad maths?
The extended reals are to the reals as [0, 1] is to (0, 1) -- the extended reals complete the real numbers as a topological space by adding two "endpoints" (+∞ and -∞). This topological space cleans up a great deal of calculus. For example, you no longer need to have a separate definition for when a limit diverges to +∞.
However, the key point to note is that the extended reals aren't an arithmetic structure -- we can extend the functions +, -, *, and / to take (some) infinite values, but this extension is via continuity as opposed to any arithmetic meaning.
Another example of an extension via continuity is extending the function (x-1)/(1-x) to equal -1 at x=1, or extending the function (sin x)/x to equal 1 at x=0.
These extensions of +, -, *, and / now need to be thought of merely as functions -- it is generally wrong to try and treat them as arithmetic operations when they take on infinite values.
As an example, the function f(x) = 2x - x cannot have +∞ in its domain, because if we try to evaluate, we run into (+∞) - (+∞), which is undefined.
Why is it undefined? Because no matter what value we assign to it, it would render the - operation discontinuous there. For example, consider:
[tex] (+\infty) - (+\infty) = (\lim_{x \rightarrow \infty} x+1) - (\lim_{x \rightarrow \infty} x) = \lim_{x \rightarrow \infty} ((x + 1) - x) = 1[/tex]
[tex] (+\infty) - (+\infty) = (\lim_{x \rightarrow \infty} x) - (\lim_{x \rightarrow \infty} x+1) = \lim_{x \rightarrow \infty} (x - (x + 1)) = -1[/tex]
If - was continuous at (+∞, +∞), then both of these statements would be true -- the first equality by definition of continuity, and the rest as properties of limits.
(This is very closely related to the concept of an "indeterminate form")
Whoops, I made a slight mistake. What continuity says here is:
[tex] \lim_{(x, y) \rightarrow (a, b)} (f(x) - g(y)) = \left( \lim_{(x, y) \rightarrow (a, b)} f(x) \right) - \left( \lim_{(x, y) \rightarrow (a, b)} g(y) \right)[/tex]
when the appropriate conditions are satisfied (existence, domains, etc). But, you can still make that proof by contradiction.
derekmohammed said:
2x-x=0
2x=x
2=1 ?
-1=0 ?
I'd rather think of it as only x=0, as "infinity" isn't a well defined number or digit..
chound said:
x + x = 2x
x-x=0
Do you mean:
for all x, x+x=2x, THEREFORE ∞+∞=2∞=∞?
What does the minus mean in x-x when x=∞?
Are these infinities the extended real numbers or infinite sets or something else?
  • · Replies 30 ·
9K
10K
