How can NO and HNO3 be removed during the lab preparation of dinitrogen?
  • Thread starter Thread starter peeyushkant
    Lab Preparation
The discussion revolves around the preparation of dinitrogen gas (N2) from ammonium chloride (NH4Cl) and sodium nitrate (NaNO3), specifically focusing on the removal of byproducts such as nitric oxide (NO) and nitric acid (HNO3) to achieve a purer product. The scope includes theoretical considerations and practical laboratory methods.
  • Some participants propose that the reaction between NH4Cl and NaNO3 produces NH4NO3, which may lead to the formation of byproducts like NO and HNO3.
  • One participant suggests that gently warming the mixture could yield N2O instead of N2, while another emphasizes that heating NH4NO2 could produce N2.
  • A participant mentions that if NO is formed, it could be converted to NO2 by passing it through oxygen, followed by dissolution in water to yield nitrous and nitric acid.
  • There is a suggestion that heating alkali metal azides could provide a higher yield of dinitrogen gas.
Participants express differing views on the methods for producing dinitrogen and the implications of byproducts, indicating that multiple competing approaches and uncertainties remain in the discussion.
Participants have not fully resolved the specifics of the reactions involved, including the conditions under which byproducts are formed or removed, and the potential hazards associated with the materials discussed.
peeyushkant
how are NO and HNO3 produced during the preparation of Nitrogen using NH4Cl and NaNO3 removed so that purer product could be obtained
Chemistry news on Phys.org
Can't say I understand what the question is about. Try to reword it.
I think he is asking how to increase the purity of Dinitrogen gas produced as of reaction of NH4Cl with NaNO3, and he stated that he need to remove the byproducts.
I conjecture that if we mix NH4Cl and NaNO3, the resultant compound will yield NH4NO3, which, is an explosive I suppose. Gently warming the mixture will produce N2O, not N2.
If you want to produce N2, try making NH4NO2.
you are right
it will be NH4NO2 but small amounts of NO and HNO3 are also produced in this reaction.
I wanted to know which reagent might be used and equation of the reaction that will take place on using that reagent
Just gently warm the above mentioned compound, as it is not an innocent compound. In fact, it is an explosive material.
Heating it gently will yield N2 and water. If NO is formed (I don't know how), you can pass this gas first through a supply of oxygen. Oxygen will convert NO to NO2. Now pass this mixture through water. NO2 is soluble in water, yielding Nitrous and Nitric acid.
Nitric acid formed in the reaction will just stay in the solution, no need to worry except when handling the solution. You got yourself a good yield of Dinitrogen.
In my opinion, if you want high lab yield of Dinitrogen gas, you should heat alkali metal azides.
18K
  • · Replies 19 ·
11K
