Quick Chemical kinetics question
The discussion revolves around determining the order of a chemical reaction based on the units of the rate constant, which are given as concentration/time. Participants are exploring the relationship between the rate constant and the reaction order in the context of chemical kinetics.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants are attempting to relate the units of the rate constant to the order of the reaction, with some suggesting that the order can be inferred from the formula involving concentration and time. Others are questioning the assumptions made in the reasoning and the application of the relevant formulas.
The discussion is active, with various interpretations being explored regarding the relationship between the units of the rate constant and the reaction order. Some participants are providing formulas and reasoning, while others are challenging the conclusions drawn and encouraging a review of the underlying principles.
There appears to be some confusion regarding the application of the rate law and the dimensions of the rate constant, with participants referencing both the formula and first principles to clarify their reasoning.
Link
The rate constant for a certain reaction has the units concentration/time. What is the order of the raction?
A. 0
B. 1
C.2
D.3
My reasoning:
K = [A]^m x ^n
Since the concentration/time is to the power of one, both m and n must be one i think which give an overall order of one?... since if they were zero there would be no reaction?
There is a formula for this.
[tex]k=\frac{\left(\frac{L}{mol}\right)^{\mbox{order}-1}{\mbox{units of time}}[/tex]
EDIT: for some reason the latex is not working.
k=[(L/mol)^{order - 1}]/(units of time)
Do you mean that in order to have the unit as concentration/time, it should be:
K = C^(2-1)/t
which gives the answer C? :confused:
Use the formula. If K must be in units of concentration over time, what must the order be in the formula?
Here's the fixed latex:
[tex]k=\frac{\left(\frac{L}{mol}\right)^{\mbox{order}-1}}{\mbox{units of time}}[/tex]
So its C i suppose
Thank you for the help!
How did you get C? That's incorrect.
if the unit is concentration/time it should be:
(Concentration^1) = K
time
So i think it's :
[Concentration]^[2] - 1
time
(Concentration^1)
------------------- = K
time
the order should be: [2]
Thats how i reasoned.
Review the formula. What are the units for concentration? What are the units in the formula?
A. 0
B. 1
C.2
D.3
My reasoning:
K = [A]^m x ^n
From your reasoning above where would you get the dimensions of time from ? The error is in that your equation is for the rate, not the rate constant.
You solve this problem, you can either remember the formula provided by Sirus, or simply work it out from first principles. The order n, of the reaction determines the rate law :
[tex]rate = -\frac {dX}{dt} = kX^n[/tex] where X is a concentration.
So [tex]-k = X^{-n} \frac {dX}{dt}[/tex]
So the dimensions of k will be [tex]\frac {[X^{1-n}]}{[T]}[/tex]
In this particular case, the fact that k has the same units as the rate, makes it all the more easy and negates the need to go beyond the first step.
Just focus on the equation rate=kX^n, the units for the rate will always be in terms of concentration/T. The right side of the equation, besides k, will be in terms of concentration, concentration squared, etc...depending on the order number (you should be able to see this). Thus if we have k in terms of concentration/time (M/s), and rate=concentration/time (M/s), dividing the rate by k will give you 1, meaning zero order.
  • · Replies 54 ·
12K
  • · Replies 46 ·
