Register to reply
Kayaker paddling across a harbor
by magic-400
Tags: angle, degree, direction, triangle, vector
Share this thread:
magic-400
#1
Sep14-12, 03:39 PM
P: 1
A kayaker needs to paddle north across a 105 m wide harbor. The tide is going out, creating a tidal current that flows to the east at 1.5 m/s. The kayaker can paddle with a speed of 3.4 m/s.
(a) In which direction should he paddle in order to travel straight across the harbor? (degrees west of north)
(b) How long will it take him to cross? (seconds)
2. Relevant equations
c^2= a^2 + b^2
3. The attempt at a solution
I divided 105m by 3.4 m/s to determine how long it would take to go straight across the harbor. Then I multiplied that number (30.88) by 1.5 m/s to get the distance he would have ended up downstream. 46.32m.
Then, I attempted to set up a right triangle and solve for the angle but that's where I got confused.
Phys.Org News Partner Science news on Phys.org
Experts defend operational earthquake forecasting, counter critiques
EU urged to convert TV frequencies to mobile broadband
Sierra Nevada freshwater runoff could drop 26 percent by 2100
PeterO
#2
Sep14-12, 07:29 PM
HW Helper
P: 2,318
Quote Quote by magic-400 View Post
c^2= a^2 + b^2
The kayaker will take longer than [30.88] that to cross the harbour, since he/she is not paddling directly towards the opposite side.
azizlwl
#3
Sep14-12, 07:55 PM
P: 963
Yes you can use a right triangle to solve the problem.
This is a vector problem and using a right triangle geometry is one of the methods.
Kayaker speed with direction is one vector.
The tide speed and direction is another vector.
You can do operations on this 2 vectors and in this example adding the two vectors.
The sum of the two vectors will result in the kayaker paddling straight across the habour.
CWatters
#4
Sep15-12, 04:20 AM
P: 3,151
What azizlwl said.
If still stuck post your attempt at the vector diagram.
Register to reply
Related Discussions
Gleise 581g; does it exist and could it harbor life? Cosmology 12
Harbor Loop Introductory Physics Homework 7
Dragonboat Paddling Techniques Mechanical Engineering 1
Minor Earthquake near Bar Harbor, Maine General Discussion 1
What do you all think about this (US Aid to nations that harbor terrorists) Current Events 6
