TI-89 Basic Physics Settings/Calculations Help
The discussion revolves around the use of the TI-89 titanium calculator for basic physics calculations, specifically focusing on settings and methods to obtain approximate results for projectile motion equations. Participants share their experiences and solutions to issues encountered while using the calculator.
  • Technical explanation, Homework-related
  • One participant expresses frustration with the TI-89 titanium, noting that entering a projectile velocity equation yields an unexpected result involving radicals instead of a numerical approximation.
  • Another participant suggests changing the calculator's settings from Exact/Approx to Approximate to resolve the issue.
  • A third participant proposes using a decimal point in the equation to ensure the calculator returns an approximate value rather than an exact one with radicals.
  • Additionally, a participant mentions using the "Auto" mode for Exact/Approx and pressing the green diamond key followed by enter to display the approximate answer.
Participants generally agree on the methods to obtain approximate results, but there is no explicit consensus on which method is preferred or most effective.
Limitations: The discussion does not address the underlying reasons for the calculator's behavior or the implications of using different modes on the accuracy of results.
Students taking physics courses who are using the TI-89 titanium calculator for their calculations.
TheodorableM
Ok, new to the forum and taking my first real science credit physics course (I have taken one prior but it doesn't count towards the major). I'm in somewhat of a bind here as i just got a TI-89 titanium thinking that more was inherently better, I am now regretting this decision. When i go to do a simple equation such as finding a projectiles velocity in the x direction on a plane, i would enter the equation 950cos(75), (final speed being 950m/s, and the angle being 75deg.) i get this: 475*(√(3)-1)*√(2)/2. Now, I've looked through the manual, and do believe i am on the proper settings. I have also had the professor take a look at it but he couldn't figure it out either. After some extensive googling i figured someone here could help me out.
Thank you.
Issue Resolved
Computer science news on Phys.org
For future reference, for anybody else that has this problem, here are two ways to fix this:
In the Mode settings, change Exact/Approx to Approximate.
Alternatively, if you add a decimal point instead, like 950.cos(75), the decimal value will be returned as opposed to the exact value with radicals.
Another way to get around this is if you use "Auto" as your Exact/Approx mode and you want to see the approximate answer, hit the green diamond key and then enter instead of just enter. This will display the approximate answer.
17K
11K
9K
10K
9K
12K
