New Reply
Positioning Device Based On Thermal Expansion
Share Thread Thread Tools
Sep17-12, 03:11 PM   #1
In an experiment, a small radioactive source must be moved at extremely slow speeds. A positioning device based on thermal expansion was devised where the radioactive source is attached to one end of an aluminum rod and a heating coil is wrapped around a selection of the rod as shown in the picture below. The rod is fixed on the other end. If the effectively heated section is 5.0cm, at what constant rate do you need to change the temperature of the rod so that the source moves at a constant speed of 50nm/s?
2. Relevant equations
ΔL = αL0ΔT (linear thermal expansion)
If a body has length L0 at temperature T0, then its length L at a temperature T = T0 + ΔT is:
L = L0 + ΔL = L0 + αL0ΔT = L0(1 + αΔT)
αAluminum = 23 × 10-6/°C
3. The attempt at a solution
This is a very difficult question due to the fact that we're not given many variables to substitute into an equation. In addition, I have to manipulate the equation so I can introduce "rate" into the equation (length/time). Lastly, we're not given any temperature values either.
That is why I don't really comprehend where and how to start this question. My attempt at the solution so far was brainstorming and analyzing the question but I don't know how to move on. The slightest help with this question will be of great use.
Thank you.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Sep17-12, 11:25 PM   #2
Recognitions:
Homework Helper Homework Help
Quote by CallMeShady View Post
Differentiate both sides of this wrt time. Show your working...
Sep18-12, 03:00 PM   #3
Quote by NascentOxygen View Post
Thank you NascentOxygen; however, I managed to solve this problem yesterday night after doing some critical thinking.
You are correct. What I needed to do was differentiate both sides with respect to time and then simply plug in the known values after converting the "length units" to meters (or any other unit as long as all length units are the same and consistent).
For anyone who has a similar problem, the differentiated equation looks like this:
dΔL/dt = α(L0)(dΔT/dt)
Make sure that your constant, α, is correct/accurate. I have a few friends who accidentally substituted the wrong value for the constant; hence, getting the wrong answer. Not sure how making this mistake is common, but it does occur.
New Reply
Thread Tools
Similar Threads for: Positioning Device Based On Thermal Expansion
Thread Forum Replies
Thermal Physics question regarding the thermal expansion coefficients Introductory Physics Homework 1
coefficeint of thermal expansion of the ice was the same as coeffiecient of thermal c Introductory Physics Homework 1
Cumulative expansion based on H0 since T = 0 Special & General Relativity 14
expansion-based cooling during Big Bang Cosmology 2
