How Much Current Comes Out of a Pole Pig Transformer?
  • Thread starter Thread starter gatzos_barca
    3 phase Phase
The discussion revolves around the current output from a "pole pig" transformer, which steps down high voltage electricity for residential use. Participants explore the relationship between input and output voltages and currents, as well as the subsequent distribution of electricity within homes.
  • One participant inquires about the current output of a pole pig transformer when supplied with 20KV and 4 Amps, suggesting a potential output of 20A at 240V.
  • Another participant notes that most electronic devices use transformers to further reduce 240V to lower voltages, typically between 6V and 25V.
  • A different participant provides details on typical high voltage supplies in the US, mentioning that the secondary voltage is usually 120/240V and that residential units typically do not have three-phase power.
  • This participant also states that the current to a house can vary significantly based on the service size, ranging from 30A to over 400A, and is limited by circuit breakers or fuses.
  • Concerns are raised about the dangers of working with high voltage, emphasizing the risks associated with a 20KV source.
  • Another participant explains that the output current from the transformer will depend on the electrical demand of the houses it serves, and that the current is distributed to each house's switchboard, where further transformations may occur.
Participants express varying views on the specifics of current output and safety concerns, indicating that there is no consensus on the exact current output from the transformer or the implications of working with high voltage systems.
Participants mention various service sizes and configurations, but do not resolve the assumptions regarding the specific current output or the exact nature of transformations within homes.
gatzos_barca
Hi!
I have one question. Assume a source of about 20KV and 4 Amps. This source needs to be connected to a transformer in order to vary the voltage and current into desirable amounts. The ideal transformer takes the input power and gives out the same power as output. My question is: I know that the voltage comes out of the "pole pig" tranformer outside our houses is 240 V, how much is the current? 20A ? Where does the line go after that? into the switch board of each house? Is there any other transformation made within the house?
Most electronics gadgets have a transformer to change the 240 V to a much lower value, somewhere around 6 V to 25 V.
If your in the US your HV supply to the pole xfmr is usually 2K, 4160, or 13.2K.
Your secondary is 120/240V. In a residential situation you cannot have 3 phase. It is usually
only available in commercial residential situations (large apt complex), but no individual unit will have 3 phase, only 120/208 or 120/240 single phase depending on the supply xfmrs. Agriculture, commercial, and industrial areas can have 3 phase.
As for the current it depends on the size of the supply wire to the house, it could range from 30 A (very very old) to 60 A(pretty old- pre 1990's) to 100 A (smallest legal service as per NEC now) to as much as 400A + (very rare but still possible). The current is limited by fuses or circuit breakers.
There are calculations in the NEC to figure this.
Before you play with mains power please consult someone who is trained and educated in the safety procedures if you aren't.
remember if you make a mistake it only hurts 'til you stop breathing.
20KV is seriously high voltage! If you make a mistake with a 20 KV source that gives 4 amps you will kill yourself.
Hello!
I can provide some information about the 3 phase step down transformer you mentioned. This type of transformer is commonly used to convert high voltage and low current electricity into low voltage and high current electricity. In your example, the transformer would decrease the 20KV and 4 Amps input to a lower voltage and higher current output, depending on the desired amounts.
Regarding your question about the current output of the "pole pig" transformer outside houses, it is important to note that the amount of current will vary depending on the electrical demand of each house. The transformer is designed to distribute electricity to multiple houses, so the current output will depend on the number of houses connected to that specific transformer. As for the line after the transformer, it typically goes into the switchboard of each house where it is then distributed to different circuits within the house. There may be additional transformations within the house, such as using a step down transformer to further decrease the voltage for specific appliances or devices. I hope this helps answer your question!
  • · Replies 19 ·
  • · Replies 20 ·
  • · Replies 36 ·
