Understanding Rotational Motion Problems
  • Thread starter Thread starter darkys
    Homework
The discussion revolves around problems related to rotational motion, specifically focusing on angular displacement and angular momentum calculations. Participants are examining the implications of given parameters in the context of these problems.
  • The original poster questions whether the problem is asking for angular or linear displacement and expresses uncertainty about calculating angular momentum without knowing the radius or angular velocity. Some participants suggest focusing on the circular path traveled by a point on the wheel.
Participants are actively engaging with the problems, with some providing insights about the need for specific parameters like radius. There is a mix of interpretations regarding the assumptions needed for the bowling ball problem, but no consensus has been reached.
One participant mentions common knowledge about the radius of a bowling ball, suggesting that it should not be explicitly included in the problem. Additionally, there is a note about the legality of the bowling ball's weight, which may influence the discussion.
darkys
I'm having some trouble with a few rotational motion problems.
One question says... A wheel 33 cm in diameter accelerates uniformly from 240 rpm to 360 rpm in 6.5 s. How far will a point on the edge of the wheel travel in this time.
Is this asking for the angular displacement or the linear displacement?
The next one says A bowling ball of mass 7.3 kg rolls without slipping down a lane at 3.3m/s. (a) calculate its total kinetic energy. (b) Calculate its angular momentum
I can see how to get the total kinetic energy i think, but how do i find the angular momentum if i don't have the radius or the angular velocity?
Any help would be appreciated
1.There's no linear movement,therefore u should compute the length of the circle the point travels in that time.
2.As for the last,i may be wrong,but you need the radius...
Daniel.
The radius of a bowling ball is common knowledge and shouldn't need to be put into the problem. Virtually everybody knows that the radius of a bowling ball is 10.85 cm (plus or minus .05 cm).
Most people do know that, right? :rolleyes:
BTW, a 7.3 kg bowling ball isn't legal - it's about 44 grams too heavy. Check here for all you want to know about a bowling ball: http://www.bowl.com/downloads/pdf/USBCequipmanual2005_sectionIII.pdf"
Nope,Bob,i never did and never will play bowling.:-p
Daniel.
  • · Replies 21 ·
