Relationship between changing a wire's diameter and change in temp
The relationship between the diameter of nichrome wire and the temperature change (ΔT) of water it is submerged in has been established through mathematical reasoning. Resistance (R) is inversely proportional to the diameter squared (d²), leading to the conclusion that ΔT is proportional to d² when power (P) is constant. The derived equation shows that ΔT is influenced by the wire's diameter, with a direct relationship to the energy (E) transferred to the water over time. This analysis assumes a constant voltage source and neglects temperature-induced resistance changes in the wire.
  • Understanding of electrical resistance and its relationship to cross-sectional area
  • Familiarity with Joule's law and heat transfer principles
  • Basic knowledge of proportionality in mathematical equations
  • Concept of specific heat capacity and its role in temperature change calculations
  • Explore the derivation of Joule's law in detail
  • Investigate the effects of wire material properties on resistance and heat generation
  • Learn about the principles of heat transfer in insulated systems
  • Study the mathematical modeling of thermal systems and their applications
Students in physics or engineering, educators teaching thermodynamics and electrical principles, and researchers exploring material properties and heat transfer dynamics.
alanajames
Hello! I have a problem where I need to develop and justify a hypothesis surrounding the relationship between the thickness (or diameter) of a nichrome wire and the temperature of water that it's submersed in over a time of 5 minutes. (proportionality statement and equations)
So far, I know that resistance is inversely proportional to cross-sectional area, and therefore:
R ∝ 1/A
R ∝ 1/∏r^2
R ∝ 1/∏(d/2)^2
and because 2 and ∏ are constant
R ∝ 1/d^2 (resistance is inversely proportional to diameter squared) (I think!)
Now, I've also researched Joule's law, which eventuates into:
Heat produced = Pt = VIt = V^2/Rt = I^2Rt
Now, I'm trying to get a relationship between diameter and ΔT, and I thought, so I have R ∝ 1/d^2, and P = V^2/R where V is a constant so P ∝ 1/R
and since P is the change in heat:
ΔT ∝ 1/RORsince thickness makes resistance go down
and less resistance makes ΔT (somehow)
then is R ∝ ΔT
and substituting so therefore:
ΔT ∝ 1/d
and I don't have much idea how to reason out what the graph will look like/why...
I think I've tied myself in knots... any help would be much appreciated! Thank you!:)
I think you have to assume the wire is connected to a constant voltage source and I'd also ignore any change in resistance of the wire with temperature.
Therefore your approach is correct..
R ∝ 1/∏(d/2)2
R ∝ 1/d2
Then use..
Power = V2/R
Power = V2 * d2........(1)
If the water is in an insulated container then the energy it contains (E) is given by
E = Specific heat capacity * mass * Δ Temperature
Rearrange to give..
Δ Temperature = E / Specific heat capacity * mass
Then..
E = Power * Time
so
Δ Temperature = Power * Time / Specific heat capacity * mass ...(2)
Put (1) into (2)...
Δ Temperature = V2 * d2 * Time / Specific heat capacity * mass
Voltage, Time, Specific heat capacity and mass are all constant so
Δ Temperature ∝ d2
eg The change in temperature over 5min (not the actual temperature) is proportional to d2
Temperature = Initial Temperature + Δ Temperature
So actual temperature is proportional (but not directly proportional) to d2.
http://en.wikipedia.org/wiki/Proportionality_(mathematics )
  • · Replies 16 ·
  • · Replies 21 ·
12K
